Black wireless keyboard on a wooden desk with monitor stand, mug, and plant in the background.
Logitech’s new Signature Slim Solar+ K980 promises to end the ritual of battery swaps and cable tugs by running exclusively on light — natural or artificial — and packing a battery that the company says is built to last a decade.
Background​
Logitech this year revived a technology long familiar from calculators and a handful of peripherals: harvesting ambient light to keep a keyboard powered. Branded as Logi LightCharge, the Signature Slim Solar+ K980 is a full‑size wireless keyboard with a solar strip across the top edge, a laptop‑style scissor‑switch layout, multi‑device Bluetooth pairing, and deep software customisation through Logi Options+. The hardware is offered in consumer and business variants; the business model adds Logi Bolt receiver support and IT management through Logitech Sync.
At launch the company gave clear headline numbers: the keyboard will recharge from any light source (Logitech specifies it charges under at least 200 lux of illumination), will reportedly run for up to four months in complete darkness once fully charged, and uses a battery the company says is designed for up to 10 years of service life. Logitech positions the K980 as a sustainability play — it uses recycled plastics in its construction, removes the need for disposable cells, and aims to eliminate charging as a daily distraction.
This article tests those claims against available specifications, independent reporting, and engineering reality; it explains how the system works, where the value lies, and the tradeoffs buyers should weigh before trading a USB‑C cable for a solar strip.
How the LightCharge system works​
The basics: solar + artificial light, with a lux threshold​
Logi LightCharge is not magic photovoltaics in the sense of needing full sun. The system uses a narrow light‑absorbing strip along the top of the keyboard that converts ambient light into charge. Logitech’s documentation and product pages explicitly state that the K980 requires at least 200 lux of illuminance for continuous charging from artificial or natural sources.
  • 200 lux is roughly the brightness of a well‑lit office or a room lit by typical ceiling lights.
  • Under bright direct sunlight (many thousands of lux) the keyboard will also charge, but Logitech warns against leaving the device in direct outdoor sun for prolonged periods because of potential overheating.
If the ambient light falls below the threshold, the device will stop gaining charge; if the battery is already full, it will continue to function for a period based on stored energy.
Claimed endurance: four months in darkness, battery life up to 10 years​
Logitech states the K980 will operate for up to four months in total darkness on a full charge. Separately, the built‑in battery is described as having an expected lifespan of up to 10 years before needing replacement. Both are manufacturer claims: the four‑month figure gives a useful sense of reserve capacity for users who occasionally work in dim conditions, and the 10‑year longevity is a lifecycle projection tied to typical charge cycles and battery chemistry.
Those assertions are consistent across Logitech’s product release and third‑party coverage, but they remain claims. Real‑world performance will vary based on typing workload, ambient temperature, how often the keyboard is exposed to light, and power management behaviour in the keyboard firmware and connected host.
Replaceability and serviceability​
A key practical point: the battery in the K980 is user‑replaceable, according to Logitech’s support documentation. That removes one common objection to integrated batteries: if a battery degrades years after purchase, it can be replaced rather than tossing the whole keyboard. Logitech has also discussed spare parts supply, and statements made to press indicate the company intends to make replacement power packs available.
Design and typing experience​
Form factor and materials​
The Signature Slim Solar+ is a full‑size keyboard with a number pad, low‑profile scissor (scissor‑switch) keys designed to mimic a laptop typing feel, and a slim, minimalist chassis. In its graphite finish, Logitech says plastic parts include a high percentage of certified post‑consumer recycled (PCR) plastic, and the aluminum plate uses lower‑carbon manufacturing processes.
The solar strip adds a visible raised edge along the top of the keyboard; that makes the device slightly larger and heavier than some lightweight slim boards, but still compact compared with older desktop mechanical offerings.
Keys, travel, and ergonomics​
  • Key travel is shallow (laptop‑style), tuned for quiet, comfortable typing sessions rather than mechanical‑style clickiness.
  • The keyboard intentionally lacks a backlight. That is a design tradeoff to conserve power and simplify charging.
  • The chassis does not include tall adjustable tilt legs, which some competing keyboards offer to provide a steeper typing angle; this keeps the profile low but reduces ergonomic adjustability for those who prefer a raised angle.
Reviews and hands‑on reports describe the typing feel as serviceable and comfortable for many users, but not a dramatic improvement over Logitech’s established MX Keys family. For buyers prioritising the best possible desktop key action, Logitech’s higher‑end MX Keys line remains the benchmark.
Software, productivity features, and the AI Launch Key​
Logi Options+ and Smart Actions​
The K980 is deeply integrated with Logi Options+, Logitech’s customisation hub for keyboard and mice. Through the app you can:
  • Remap function keys and assign Smart Actions to shortcut sequences
  • Configure the AI Launch Key, which Microsoft Copilot or ChromeOS Gemini will be tied to by default on respective platforms, or remap it to third‑party assistants like ChatGPT, Perplexity, or other web apps
  • Monitor ambient light status through a LightCheck feature to see whether your workspace is delivering sufficient illuminance for charging
The Options+ ecosystem continues Logitech’s focus on productivity automation, enabling users to build macros or multi‑step actions that can be triggered by a single keypress.
Flow and multi‑device workflows​
When paired with a supported Logitech mouse, the K980 supports Logitech Flow, allowing seamless cursor and clipboard sharing across two or more connected machines. That remains a compelling feature for users who juggle a desktop and laptop, or a Windows PC and a Mac.
AI Launch Key: convenience and privacy tradeoffs​
The new AI Launch Key is a one‑press gateway to conversational assistants. It’s convenient for users who frequently summon Copilot, Gemini, or other models, and it reflects the growing role of assistant integrations in daily workflows. That convenience carries a privacy and security tradeoff:
  • The key itself is a launcher; what it triggers runs on the host or in the cloud depending on the assistant.
  • Organisations should assess how preconfigured shortcuts interact with corporate data controls — especially when mapping the key to a cloud LLM that could see clipboard contents or other data.
For enterprise deployments, the business version’s Logi Bolt radio and Sync management give IT teams controls they may need to enforce policies around data access and device configuration.
Sustainability, manufacturing, and lifecycle claims​
Logitech frames the K980 as a sustainability product: recycled plastics in the graphite model, a battery designed to avoid replacement for years, and reduced reliance on disposable alkaline cells. Those steps line up with emerging consumer expectations around low‑impact peripherals.
However, sustainability claims deserve scrutiny beyond headline numbers:
  • The carbon benefits of not using disposables depend on actual lifespan in the field and the end‑of‑life handling of the integrated battery and solar strip.
  • Solar panels and PV strips can degrade; longevity depends on cell quality and environmental exposure. Logitech’s 10‑year battery life claim addresses the energy pack, but photovoltaic conversion efficiency will also decline slowly over time.
  • The device is not repairless; the battery is user‑replaceable, which helps; replacement part availability and ease of service will determine how sustainable the product actually is in practice.
Pricing and availability​
Logitech launched the K980 globally and lists a U.S. MSRP in the consumer press at USD $99.99 for the universal (multi‑OS) variant, with a separate Mac‑focused SKU and a business model at higher price points. Regional retail pricing differs:
  • In Australia the suggested retail price sits near AU$179.95 for the consumer variant and slightly higher for the business SKU.
  • In New Zealand several local resellers report NZ$199.95 as the recommended retail price for the consumer model.
The device became generally available from Logitech’s own storefront and major retailers following the release announcement, with the business variant appearing through enterprise channels and channels that support Logi Bolt provisioning.
Note that prices vary by market due to taxes, duties, and local retail strategies; the U.S. dollar SRP and regional retail tags may not align exactly at launch.
Where the K980 shines — strengths​
  • Zero‑charge convenience: For many users the idea of never needing to plug in a keyboard again is liberating. The keyboard’s ability to top up from ordinary desk lighting removes a small but persistent friction from daily life.
  • Long standby reserve: The quoted four months of operation in darkness gives real flexibility for users who sometimes work in dim environments or who frequently move between offices and meeting rooms.
  • Serviceability: A user‑replaceable battery reduces waste and improves the keyboard’s real‑world lifespan compared with sealed peripherals.
  • Cross‑platform and multi‑device pairing: Full‑size layout, Easy‑Switch for three devices, and multi‑OS key legends make it versatile for mixed ecosystems.
  • Productivity features: Logi Options+ and Smart Actions, Flow compatibility, and the AI Launch Key make the K980 useful to power users who rely on automation and multi‑machine workflows.
  • Enterprise readiness: The business variant’s Logi Bolt receiver and Sync visibility address management and security needs in corporate settings.
Potential risks and real‑world tradeoffs​
  • No wired fallback: There is no USB‑C charging port and no wired operation mode on the consumer K980. If you paint yourself into a low‑light corner and the battery is depleted, you must expose the keyboard to sufficient light (Logitech recommends >1,000 lux if fully depleted for reasonable recharge time) or swap the replaceable battery. For users who want a guaranteed plug‑in fallback, that is an important omission.
  • Dependence on workspace lighting: The 200 lux threshold is achievable in many offices, but not all. Dim home setups, bedrooms, or rooms with minimal artificial lighting may not charge the keyboard reliably, which will shorten the effective uptime in day‑to‑day use.
  • No backlighting: To conserve power the K980 lacks key backlighting. That’s a deliberate tradeoff: if you rely on illuminated keys for low‑light typing, the K980 is not a fit.
  • Ergonomic limitations: Absence of adjustable tilt legs may be a dealbreaker for users who prefer a steeper typing angle; wrist support is also not integrated, and the flattened profile suits some but not all typing styles.
  • Durability of the solar strip: Photovoltaic surfaces can scratch, accumulate oils and dust, and gradually lose efficiency. Logitech designs the strip for everyday use, but long‑term efficiency degradation is a practical reality that will affect charging performance over years.
  • Privacy considerations with AI integration: The one‑press AI key is useful — but operators should understand what the assigned assistant can access. Organisations with strict data handling policies need to control which AI services are allowed.
  • Cost vs. alternatives: The K980’s price sits in a segment where high‑quality, backlit rechargeable keyboards exist. Buyers must decide whether the cableless, solar approach is worth the tradeoffs compared with a wired/wireless hybrid that offers USB‑C backup.
How it compares to competitors​
  • Logitech MX Keys / MX Keys S: Those keyboards offer superior build and a richer typing experience for many users — including backlighting — but they charge via USB‑C rather than solar. For buyers who prioritise typing feel and backlighting, the MX Keys family remains compelling.
  • Lenovo Self‑Charging / Other solar keyboards: Vendors including Lenovo have introduced self‑charging keyboards that pair photovoltaics with supercapacitors or USB‑C emergency ports. Some competitors add tilt legs, spill resistance, or a USB‑C emergency port as a safety net; Logitech’s approach is purer (no charging port) and more minimalist.
  • Older solar peripherals: Logitech itself produced solar keyboards in the past (for example the K760), but the K980 represents a return with updated materials, software, and manageability for business use.
Practical buying guide: is the K980 for you?​
  • If you hate managing cables and battery charge cycles, and your workspace is consistently well lit (or you’re willing to use a desk lamp), the K980 delivers an unusually low‑maintenance experience.
  • If you need backlighting, tilt adjustability, or the absolute best tactile keyfeel for long coding or writing sessions, consider other Logitech models or premium mechanical keyboards.
  • If your work requires guaranteed operation in dim environments (shift work, overnight ops, or basement offices), evaluate whether the lack of a wired fallback is acceptable — or opt for a competitor with USB‑C emergency charging.
  • For enterprise purchasers, the business K980 with Logi Bolt and Sync is attractive because it reduces device maintenance and integrates with asset management — but IT teams should validate connectivity, firmware policies, and privacy considerations around mapped AI actions.
Final verdict​
The Signature Slim Solar+ K980 is a thoughtfully executed return to solar‑powered peripherals. It offers a genuinely convenient experience for the right user: someone who values sustainability, wants a cable‑free desktop, and works in a reliably lit environment. Logitech’s serviceable typing feel, integrated software, and enterprise management options make the K980 more than a novelty.
That said, the product is deliberately polarising. It trades the safety net of USB‑C for a clean, light‑only design, removes backlighting to conserve power, and picks ergonomics that favour low profile aesthetics over adjustability. The manufacturer’s claims — four months of darkness reserve and up to 10 years battery lifespan — are plausible and backed by Logitech’s specs, but buyers should treat them as projections that depend heavily on real‑world use patterns.
For users seeking an eco‑forward peripheral that reduces everyday friction and aligns with greener desk setups, the K980 deserves serious consideration. For users who require absolute fallback reliability, specialized typing ergonomics, or illuminated keys, the solar promise will not outweigh the practical compromises.
Logitech’s light‑powered keyboard is a reminder that small, well‑applied engineering choices can meaningfully shift how we interact with everyday devices — turning a minor, recurring annoyance (dead batteries) into a solved problem for many users, while inviting a new set of decisions about tradeoffs and priorities.
