Scientists in white coats gather around a long table with tablets in a blue-lit L'Oreal lab.
L’Oréal’s Americas team has quietly turned Microsoft’s Power Platform into a production-grade ingredient in a larger Beauty Tech transformation — shipping low‑code apps that solve real operational pain, cut costs, and scale beyond pilot projects into enterprise‑grade services used across the globe. The company’s Tech Factory is training and enabling makers to build everything from a mobile lab reservation system to SAP‑integrated purchasing apps, and the early results show material time savings, better equipment uptime, and a clear path from local innovation to global rollouts.
Background​
L’Oréal’s ongoing digital transformation is part of a long game: modernize core systems, accelerate innovation at the edges, and convert product and process knowledge into software that drives the business. The Americas organization — backed by an enterprise migration of SAP to Azure and broader cloud investments — created the Tech Factory to empower internal makers and shorten the path from idea to production. That shift is explicitly anchored on the Microsoft Power Platform family: Power Apps, Power Automate, and Dataverse. This story matters because it’s not another pilot. L’Oréal has turned maker activity into repeatable value: the Tech Factory supports apps that have cleared enterprise security and architecture reviews and are now candidates for global adoption. The approach blends low‑code speed with centralized governance — a practical pattern that other large enterprises are watching closely.
Overview: what L’Oréal built with Power Platform​
The Tech Factory model​
The Tech Factory acts as a regional center of excellence and delivery hub. Its remit is to:
  • Enable business teams and "makers" to prototype and ship low‑code apps quickly.
  • Provide reusable components, templates, and governance that make those apps enterprise‑ready.
  • Integrate low‑code solutions with L’Oréal’s core platforms — notably SAP running on Azure.
This hybrid model — rapid local innovation plus centralized standards — is central to scaling low‑code without producing a shadow IT problem. It demonstrates that a well‑executed maker program can yield scaleable, secure apps that complement rather than replace core IT systems.
Signature solutions: Open Bench and Sign & Order​
Two solutions illustrate the approach:
  • Open Bench — a mobile‑friendly Power Apps solution for reserving shared lab equipment in L’Oréal’s “flex lab”. The app exposes a map of stations, supports barcode scanning to jump to reservation pages, and shows device status (free, reserved, being repaired) in real time. Repair reporting is integrated: maintenance tickets feed back into the app via Power Automate flows so current and future users are alerted when equipment becomes unavailable. Usage and repair metrics are stored in Dataverse for analytics and uptime tracking.
  • Sign & Order — a purchasing front end built on Power Apps with automated approval flows in Power Automate that orchestrate legal and finance reviews and produce CSV uploads into L’Oréal’s SAP system. The app improves auditability and reduces manual steps; one team reported up to 90% reduction in time to process purchase orders, producing material cost savings. L’Oréal is already moving toward RPA and the Power Platform SAP connector to automate cart creation in SAP as a next step.
Both apps embody the same pattern: a user‑centric front end combined with automated orchestration and a governed data model in Dataverse. That architecture keeps the user experience lightweight while centralizing operational logic and telemetry.
Technical anatomy: how the solutions work​
Stack and integration patterns​
The common technical stack is intentionally simple and repeatable:
  • Power Apps (Canvas + mobile) — primary UI surface for end users (scan barcode, pick map icon, submit form). The canvas model delivers rapid UX iteration for non‑developers.
  • Power Automate — cloud flows orchestrate approvals, notifications, and external system lookups (including maintenance system ticket lookups and notification fan‑outs). These flows also implement the logic that ensures data consistency across systems.
  • Dataverse — the canonical data store for app entities (equipment, reservations, repair tickets, usage metrics). Dataverse enables governed access, built‑in security roles, and telemetry for analytics.
  • Connectors / RPA — for back‑end integration with SAP (upload of CSV carts, future use of SAP connector and RPA for automation) and the lab maintenance system. Microsoft’s SAP connectors and RPA tools make these integrations predictable to implement and maintain.
This architecture favors modularity — the UI, orchestration, and data layers are separate but tightly integrated. That separation reduces risk when underlying core systems change and makes it easier to re‑use components.
Data and governance considerations​
L’Oréal’s Enterprise Architect team approved the Open Bench app for global use only after assessing security, governance, and compliance criteria. That step is critical: low‑code speed without governance produces risk. Using Dataverse as the canonical store helps centralize data access, enforce role‑based permissions, and generate metrics for governance dashboards. Governance isn’t only about locks and policies — it’s also about making developer patterns repeatable. The Tech Factory supplies templates, common Dataverse tables, and approved connector patterns so makers don’t have to reinvent secure integrations for each project.
Business impact and measurable outcomes​
Productivity and cost savings​
The most striking business metrics reported by L’Oréal are:
  • An estimated up to 90% time saving on PO processing for the team using Sign & Order, driven by automated approvals and bulk upload to SAP. That efficiency translated into “hundreds of thousands of dollars” in annual processing savings for the U.S. division, per the customer story. These figures are company‑reported and should be treated as such.
  • Improved equipment uptime and maintenance responsiveness through Open Bench: centralized usage and repair history drives faster fixes, and feedback features (e.g., reporting how a device was left) have raised maintenance standards in the lab. The app’s telemetry is now used to prioritize repairs and plan capacity.
Faster integration with SAP on Azure​
L’Oréal’s broader cloud program — moving SAP workloads to Azure — laid the foundation for these Power Platform integrations. SAP on Azure improved transaction performance and lowered operational overhead in prior phases of the migration, which makes it practical to build UX layers on top of SAP that rely on timely back‑end responses. Power Platform’s SAP connectors and Microsoft’s cloud pattern make these integrations less brittle than legacy screen‑scraping approaches.
Why this approach works for L’Oréal​
  • Domain knowledge + maker autonomy: product teams and lab technicians know the problems. The Tech Factory reduces the friction to convert that knowledge into apps. That closeness to domain experts keeps solutions pragmatic and tightly targeted.
  • Governed reuse: by offering approved components (Dataverse tables, connectors, processes), the Tech Factory standardizes good practice and reduces technical debt.
  • Cloud foundation: migrating SAP to Azure created a reliable, scalable back end for the Power Platform front ends — avoiding the all‑too‑common trap of low‑code front ends built over fragile legacy systems.
Risks, limitations, and cautionary notes​
No transformation is risk‑free. The L’Oréal case shows clear wins, but also surfaces common enterprise hazards that other organizations must manage deliberately.
  • Vendor and platform concentration risk: L’Oréal’s pattern ties UX and orchestration to Microsoft’s Power Platform and to SAP on Azure. That stack brings clear integration and governance benefits, but it concentrates operational risk — changes in licensing, feature deprecation, or contract terms can have outsized impact. Organizations should plan for contingency paths and maintain exportable data models.
  • Shadow app proliferation: rapid maker productivity without a robust CoE (Center of Excellence) can create dozens of lightly governed apps. L’Oréal mitigates this by requiring Enterprise Architect approval for global use and by centralizing common assets — a pattern other enterprises should copy.
  • Data governance and compliance: Dataverse simplifies role-based security, but enterprises must still define data lifecycle, retention, residency, and audit practices — especially across multi‑country deployments where privacy laws differ. L’Oréal’s global rollouts will need careful legal and security alignment.
  • Operational ownership and SLAs: low‑code apps can become mission‑critical quickly. The organization must assign operational owners, incident response procedures, and capacity planning for flows and connectors so production service levels are predictable.
  • Unverifiable claimed savings: several cost and time‑saving figures are reported in the customer story (including the “hundreds of thousands” saved and the “up to 90%” PO time reduction). These are valid business signals but are company‑reported metrics; independent verification or audit of the underlying methodology would be advisable before extrapolating those gains across other units.
Lessons for IT leaders and practitioners​
L’Oréal’s experience surfaces a replicable blueprint for scaling low‑code innovation in large enterprises:
  • Build a regional Tech Factory or CoE that provides templates, governance, and hands‑on delivery support.
  • Standardize a canonical data model in Dataverse and require that apps persist operational telemetry there.
  • Use Power Automate to decouple business orchestration from the UI; keep flows testable and monitored.
  • Integrate deliberately with core systems (SAP, ERPs) using supported connectors and RPA where necessary; verify security approval before production rollouts.
  • Institute an enterprise approval gate (security, architecture, compliance) for any app that will be rolled out beyond a pilot scope.
  • Treat maker programs as product organizations: assign product owners, define SLAs, and fund a small operational team to maintain roadmaps and technical debt.
These steps preserve the agility of low code while embedding responsible engineering practices that make scaled adoption sustainable.
Wider implications: what L’Oréal’s move signals for enterprise IT​
  • Low code is shifting from “nice to have” to strategic: enterprises that once treated Power Apps as tactical are increasingly using it to build apps that replace manual processes and create material cost savings. L’Oréal’s global approval of Open Bench signals that low code can be enterprise‑grade when paired with governance and architecture oversight.
  • Cloud migrations unlock low‑code value: L’Oréal’s SAP migration to Azure was more than performance optimization — it unlocked a reliable back end that lowered friction for UX layers built using low code. Other enterprises should see migrations as enablers for downstream productivity, not endpoints in themselves.
  • Power Platform + SAP is now a mainstream integration pattern: Microsoft’s documentation and tooling for Power Platform and SAP show this is a supported, intentional scenario — not an ad‑hoc workaround. Using the official connectors and RPA tools reduces long‑term maintenance risk.
  • Local innovation with global guardrails is the operating model: L’Oréal demonstrates a repeatable way to let domain experts build while ensuring enterprise security and reusability — a model other global organizations should consider.
Quick technical checklist for teams starting similar projects​
  • Use Dataverse tables as the canonical schema for entities that cross apps.
  • Keep Power Apps stateless and delegate heavy logic to Power Automate flows or Azure Functions.
  • Validate external connectors (SAP, maintenance systems) through security and architecture review before production.
  • Instrument flows and Dataverse tables for observability: error rates, flow latency, and usage patterns.
  • Define a deployment pipeline and import/export processes (ALM for Power Platform) and include automated tests for flows and connectors.
Independent corroboration and context​
The Microsoft customer story describing L’Oréal’s Power Platform work provides the primary narrative and quotes used throughout this article. That same Microsoft ecosystem includes a broader account of L’Oréal’s SAP migration to Azure — a move that supplied the technical foundation for many subsequent Power Platform integrations. Microsoft’s own Power Platform documentation outlines recommended integration patterns (connectors, RPA, Dataverse) that match L’Oréal’s architecture choices. Additional partner engagements (local implementation partners building Power Platform solutions for L’Oréal teams) further corroborate that the company is pursuing a multi‑tier, platform‑led approach to business app modernization. Note: financial impact figures and specific percentage improvements cited in the customer story are L’Oréal’s reported outcomes; they are strong early indicators but are company‑supplied metrics and should be validated independently if used for budgeting or benchmarking.
L’Oréal Americas’ work with Microsoft Power Platform is a pragmatic example of how a large, brand‑driven enterprise can use low‑code to drive operational change at scale. The Tech Factory model — pairing maker empowerment with centralized governance, Dataverse as the canonical store, and deliberate SAP integrations on Azure — produces measurable wins while keeping risk manageable. The Open Bench and Sign & Order apps are not flashy experiments; they are operational enablers that free technicians and administrators to focus on core work rather than process friction. For IT leaders, the lesson is clear: low code, when governed and integrated with a solid cloud foundation, can be a strategic weapon rather than a tactical convenience.
  1. L’Oréal Americas is building beautiful enterprise solutions with Microsoft Power Platform | Microsoft Customer Stories Microsoft
