The test came from Japanese outlet PC Watch and was written by Masahiro Yamaguchi. Tom's Hardware picked it up. This article covers what was tested, what the numbers mean, and where the limits are.
What the ADP15 is
The ADP15 is an adapter, not a power bank. It slides onto a compatible Makita battery. The Tom's Hardware report describes it as offering a 105W USB Type-C port and a 12W Type-A port. It was reported to have launched earlier this year in Asia-Pacific countries.
Several retailer and Makita regional pages give the same specs. Makita's Dutch page lists the USB-C port as PD-PPS at up to 105W (21V/5A) and the USB-A port as up to 12W (5V/2.4A). Both ports can run together for a combined maximum of 117W.
The headline figures look inconsistent, but they aren't. PC Watch explains that standard USB PD tops out at 100W (20V/5A). The PPS range of 5–21V at 5A is what gives the 105W figure. So 100W, 105W and 117W are three different limits:
- 100W: the maximum for the standard USB PD profile.
- 105W: the USB-C maximum when PPS is counted.
- 117W: the total for both ports used together.
What PC Watch tested
Yamaguchi used his own 18V BL1830B battery, rated at 3,000mAh. PC Watch reported these results:
- Port check: A USB Cable Checker3 showed PD up to 100W and PPS at 5–21V/5A. A separate tester indicated AVS support. The checker also showed Quick Charge 2.0/3.0 and flagged a 3A rating that the reviewer judged to be a misreading of the port's 5A capability. These are one outlet's instrument readings, not a certification.
- iPhone 17 Pro Max: About 37W at peak.
- ThinkPad X1 Carbon Gen 9: About 60W at peak. The laptop supports up to 65W. PC Watch did not see current above 3A during the laptop test.
- Charge level: The 3,000mAh battery ran out before the ThinkPad was full. Charging stopped at roughly 77%.
PC Watch calculated that Makita's 12,000mAh-class packs could fill the laptop. That is a calculation, not something it tested. Peak wattage is also not the same as total energy. The 60W figure tells you how fast the laptop charged, not how long the battery would last.
Limits to know about
- It can't recharge the battery. You need Makita's own charger for that. PC Watch says the adapter package doesn't include the battery, the charger or the USB cable.
- Check the battery by model number. PC Watch says voltage alone isn't enough. Its own 14.4V BL1415G has a different terminal shape and won't attach. It points readers to the compatible-battery list in the manual. One Dutch retailer's FAQ claims the adapter works with all Makita LXT 14.4V and 18V Li-ion batteries. PC Watch's BL1415G finding suggests checking the list for your exact model.
- Weight and bulk. PC Watch measured the adapter alone at 146g. With a battery attached, the combination exceeds 700g.
- One laptop, one battery. Makita's Japan page says real charging speed depends on the connected device and cable. It doesn't guarantee charging for every laptop. Don't assume any USB-C laptop will pull 60W.
- Protections. Makita's regional pages describe an on/off button, over-discharge protection, and an automatic shutoff after two hours at low load. One Dutch retailer cites that two-hour figure.
Price and availability
PC Watch put the Japanese street price at around ¥7,000. Tom's Hardware converted that to about $44. PC Watch also said stock is thin in Japan and some sellers charge more.
European listings in search results show prices of £37.95 at one UK seller and €47.37 at one Dutch retailer. These are snapshots from single sellers, not a guaranteed current price.
Makita U.S.A.'s listing is for the older ADP05. Its search-result snippet is from a European page, so I can't confirm how the ADP15 is sold in the U.S. The ADP05 has two USB-A ports. Makita's page lists 2.1A per port and 4.2A in total. That is far short of a laptop-charging USB-C output. I didn't verify the Japanese eBay listing mentioned in the Tom's Hardware report, so I'm leaving it out.
Is it worth it?
PC Watch's own verdict was lukewarm. It sees the adapter as best suited to emergencies such as disasters, especially for people who already own Makita batteries. It says the adapter is not well suited to everyday use. Its logic is that a tool battery sitting in the garage is usually fully charged, so you can repurpose it without buying another power bank.
The counterargument is the cost of the full kit. If you don't own compatible batteries and a charger, you'd be buying an adapter, a battery and a charger. That will likely cost more and weigh more than a purpose-built power bank. This test doesn't show the Makita setup is more portable or cheaper than a power bank. The comparison with dedicated power banks is general industry reasoning, not something PC Watch measured.
The one concrete finding is about laptop charging. A 3,000mAh tool battery delivered about 60W to a 65W laptop and got it to about 77%. If you own the batteries, that is a useful backup. Before relying on it, check three things:
- Look up your battery's exact model number in Makita's manual for the ADP15.
- Use a USB-C cable rated for the power you need.
- Test it with your own laptop before you need it in an emergency.
- Makita power tool battery pack adapter tested as portable laptop power solution Tom's Hardware · 2026-11-28T11:30:00+00:00
- ADP15 - USB-adapter LXT 14,4 V/18 V makita.nl
- Makita ADP15 USB-adapter LXT 14,4V & LXT 18V mastertools.nl
