Two laptops sit on a tidy desk, one showing mountain scenery and the other a fantasy game.
MECHREVO has added a new Ryzen configuration to its Wujie 14S 2026 line and listed a new gaming laptop, the Jiguang 16 Pro. Both are China-market listings, with sales scheduled for the end of October. They are a useful look at where mainstream Windows laptop hardware is heading, particularly AMD's newest non-AI Ryzen chip.
Everything below comes from manufacturer-supplied specifications as relayed by listings and news coverage, not from independent testing.
Two laptops sit on a tidy desk, one showing mountain scenery and the other a fantasy game. What was announced​
IT Home reported on October 23 that the Wujie 14S 2026 gained an AMD Ryzen 7 H 449 version. The 24GB RAM and 512GB SSD configuration is priced at 4,799 yuan. A 1TB SSD version costs 5,799 yuan. Both go on sale on October 29.
The same day, IT Home reported that the Jiguang 16 Pro gaming laptop had appeared on JD.com at a listed price of 8,799 yuan. It is scheduled to go on sale October 30. IT Home said the first-sale price had not yet been announced.
Technetbook's dollar conversions ($675, $815 and $1,240) are approximations of the yuan prices. They are not US prices, and nothing in the reporting suggests US availability.
Wujie 14S: the Ryzen 7 H 449 edition​
The chip​
The reported specifications describe a TSMC 4nm, Zen 5-based part with 8 cores and 16 threads, a 5.0GHz peak single-core clock and 24MB of combined L2 and L3 cache. Graphics come from the integrated Radeon 860M. The laptop has three performance modes, switched with Fn+X.
Other reporting offers some context on the chip. VideoCardz describes the Ryzen 7 449 as reportedly a Ryzen AI 7 450 without the NPU. It also says the part uses four Zen 5 and four Zen 5c cores. The Ryzen AI 7 450 reaches 5.1GHz and carries an NPU rated at up to 50 TOPS. The 449's Radeon 860M is limited to 2.8GHz, against 3.1GHz on the AI variant.
Igor's Lab adds that the Ryzen 7 449 has 16 MB of L3 cache and a configurable TDP between 15 and 54 watts. This matters for Windows buyers. The Wujie 14S H 449 is not described as a Copilot+ PC in the material reviewed here, and no NPU is listed. The apparent absence of an NPU is also an inference from AMD's naming, not something MECHREVO's listing states.
Display, battery and ports​
  • Screen: 14-inch matte panel at 2800×1800 and 120Hz. It covers 100% sRGB, reaches 500 nits and uses DC dimming.
  • Weight and battery: about 1.2kg with a 60Wh battery. MECHREVO claims more than 14 hours of office use and a charge to over 50% in 30 minutes.
  • Ports: two full-function USB-C ports (each reported as 10Gbps with DisplayPort 1.4 and power delivery), two 5Gbps USB-A ports, HDMI 2.1, a combined 3.5mm audio jack and a Kensington lock slot.
  • Input and privacy: 1.3mm key travel and a physical camera shutter.
  • Software: the Star Link app is described as covering screen projection, file transfer, remote control and cross-device copy and paste between PCs, phones and tablets. IT Home calls it all-platform. The listing does not say which operating systems or phone brands are supported, so treat compatibility as unverified.
How it compares with the earlier Ryzen version​
IT Home's September 11 report on the R7 H 255 version lists a 1920×1200, 60Hz panel, a weight of about 1.1kg and a price of 4,699 yuan. The H 449 model is 100 yuan more for the 24GB and 512GB configuration. The reported display jumps to 2800×1800 at 120Hz, and the weight rises by roughly 0.1kg.
That is a meaningful upgrade on paper. Whether the two versions share a chassis is not established.
Technetbook's coverage of the earlier launches puts the Intel Core 5 315 version at 4,199 yuan list with 12GB of RAM. The laptop line now spans Intel Wildcat Lake and two AMD Ryzen chips.
Jiguang 16 Pro: a budget-minded gaming laptop​
Core specifications​
  • CPU and GPU: Intel Core i7-13645HX with an RTX 4050 Laptop GPU. The GPU has 6GB of VRAM and a reported 140W maximum power limit.
  • Memory and storage: 16GB of RAM and a 512GB SSD.
  • Display: 16-inch at 2560×1600 and 180Hz, with 500 nits typical brightness, a 92% screen-to-body ratio, 100% sRGB and an average Delta E below 2.
  • Cooling: two Ice Shark fans, four exhaust outlets, six copper heat pipes and phase-change thermal compound. A quiet mode is claimed to hold noise to 43dB.
  • Other features: 1.4mm key travel, full-size arrow keys, 16-million-color RGB backlighting, a physical camera switch, Nahimic audio and a 210W silicon-carbide adapter. It also includes the Star Link app.
Price caveat​
The 8,799 yuan figure is a JD list price. IT Home's JD link preview mentions 8,499 yuan after a 300-yuan coupon. Because the first-sale price was unannounced, treat that as a listing promotion, not a confirmed launch price.
What to make of it​
The two machines are unrelated in purpose. The Wujie is a thin-and-light office laptop with integrated graphics. The Jiguang is a discrete-GPU gaming machine.
The Jiguang uses a 13th-generation Intel HX chip, which is an older generation. Without benchmarks, no performance claims are justified. The 140W GPU limit and the 43dB figure are specifications, not measured sustained performance.
Two practical points stand out for shoppers:
  1. The Wujie H 449's main differentiator over its siblings is the sharper 120Hz screen, not a different feature set.
  2. All battery, noise and color-accuracy numbers are manufacturer claims. Wait for reviews before treating them as results.
No official MECHREVO product page or test data was available at the time of writing. Operating system preinstallation was not mentioned in the material reviewed, so check the listing before buying if Windows 11 matters to you.
  1. MECHREVO Launches Wujie 14S with AMD R7 H 449 and Jiguang 16 Pro Gaming Laptop - Technetbook Technetbook 2026-10-23T21:49:00+00:00
  2. Mechrevo launches first Ryzen 7 449 laptop with RTX 5060, no NPU on board - VideoCardz.com videocardz.com
  3. AMD Ryzen 7 449 in the Mechrevo Wing Dragon 15 Air igorslab.de
