The important buying question is whether those compromises match how you actually use a laptop. There is also a specification detail worth checking before spending more: the RTX 5070 configuration described in the review still has 8GB of graphics memory, despite Nvidia now listing both 8GB and 12GB versions of that laptop GPU. A bigger model number does not automatically mean a bigger memory allowance.
Two configurations, with some important limits
TechRadar lists the following configurations and review-time UK prices. Both use the same processor, display and storage capacity; the higher-priced model changes the GPU and doubles system RAM. These are reported review prices, not a live offer or a guarantee of current stock.
| Specification | Base configuration | Higher configuration |
| Reported UK price | £1,649.99 | £1,899.97 |
| Processor | Intel Core i9-14900HX | Intel Core i9-14900HX |
| Graphics | RTX 5060 Laptop GPU, 8GB GDDR7 | RTX 5070 Laptop GPU, 8GB GDDR7 |
| System memory | 16GB DDR5 | 32GB DDR5 |
| Storage | 1TB PCIe 4.0 NVMe SSD | 1TB PCIe 4.0 NVMe SSD |
| Display | 17.3-inch, 1920 × 1080 IPS, 144Hz | 17.3-inch, 1920 × 1080 IPS, 144Hz |
Configuration details are from TechRadar’s specification table.
TechRadar describes availability as UK-only. Its approximate US-dollar and Australian-dollar conversions should not be mistaken for local retail prices or evidence of a launch in either country.
Intel’s documentation adds useful context to the processor choice. The i9-14900HX is a first-quarter 2024 part with eight Performance-cores, 16 Efficient-cores and 32 threads. Its advertised maximum turbo frequency is 5.8GHz, but Intel explicitly defines maximum turbo as a single-core ceiling—not a promise that all 24 cores will run at that speed together.
That distinction matters when reading a gaming-laptop specification sheet: the headline clock is a capability, not a sustained-performance measurement.
Gaming results need their settings attached
TechRadar’s reviewer, Lewis Maddison, reports approximately 60–70fps in Cyberpunk 2077 using Ray Tracing: Low. Moving to Ray Tracing: Ultra produced roughly 40fps, with heavier scenes dropping into the thirties and below. Those observations support a positive gaming assessment, but not an unconditional promise of smooth Ultra-preset ray tracing.
There are limits to the available evidence. The specification table identifies the RTX 5070 machine as the review configuration, but the performance passage does not spell out resolution, DLSS settings or frame-generation status alongside those frame rates. Nor does it provide a corresponding RTX 5060 result. The figures should therefore remain attributed observations rather than a controlled comparison between the two models.
Why GPU power deserves a place on the checklist
Nvidia lists GPU subsystem power ranges of 45–100W for the RTX 5060 Laptop GPU and 50–100W for the RTX 5070 Laptop GPU. Those are family-level specifications, not confirmed power settings for this Medion.
The practical implication is straightforward: ask for the exact configuration’s GPU power specification before comparing it with another laptop carrying the same graphics badge. TechRadar’s review does not establish the P10’s GPU power limit, so there is insufficient evidence to call it a maximum-power implementation or assign a reliable performance advantage over a similarly named rival.
The memory distinction is equally useful. Nvidia’s current comparison lists both 8GB and 12GB RTX 5070 laptop variants, while TechRadar specifies 8GB for this P10. Buyers choosing the higher configuration are getting more system RAM, but not more graphics-memory capacity than the reviewed base specification. Check the full listing, not just “RTX 5070” in the headline.
A large screen without a high-resolution premium
The P10’s panel is Full HD—1920 × 1080—rather than the lower resolution sometimes implied by the loose label “HD.” It combines a 17.3-inch diagonal with a 144Hz refresh rate. Maddison found it vibrant, with acceptable contrast, although reflections and some loss of fine detail were apparent. The review does not supply measured color coverage, response times or brightness results.
That leaves a sensible but bounded conclusion: the reviewer liked the screen for games and general content, but the evidence does not establish suitability for color-critical work.
Likewise, a 144Hz panel should not be read as a promise of 144fps in demanding games. The review’s Cyberpunk results illustrate the difference between the display’s refresh capability and the frame rate a particular workload delivers.
Cooling comes with an audible invoice
Maddison praised the cooling but found the fans quick to activate in Performance mode, with noticeable, persistent noise. He did not consider the sound especially harsh. These are useful hands-on impressions, although the review supplies neither decibel measurements nor recorded component temperatures.
The chassis receives a similarly qualified assessment. TechRadar describes a mostly solid, functional body, but noticeable flex around the keyboard. The reviewer ultimately found that movement cushioning rather than unpleasant; prospective owners should still treat it as a matter of preference, not evidence of an engineered suspension system for enthusiastic WASD work.
The keys themselves earned praise for their light, tactile action. Smaller irritations included a short-feeling space bar during gaming, occasional missed touchpad taps and initial palm contact triggering the pointer.
Connectivity is more accommodating. The tested layout puts power, Ethernet, HDMI and one USB-C connection at the rear, with additional USB connectivity and a headset jack on the sides. Both USB-C ports reportedly support DisplayPort 1.4; one also supports Power Delivery. However, the review does not establish USB-C charging wattage or whether that connection can sustain full gaming performance, so it provides no basis for leaving the dedicated power adapter behind.
Battery life makes this a desk-first machine
TechRadar recorded five and a half hours of continuous movie playback, with a full recharge taking approximately one to one and a half hours. Its comparison puts the P10 about 40 minutes ahead of the Erazer Major 16 X1, but well behind the Asus V16’s roughly 13-hour result. These are video-playback findings—not gaming-runtime estimates—and the review does not detail every power or brightness setting.
At approximately 2.7kg and 397 × 286 × 26.5mm, the P10 also asks for a substantial bag. The evidence points toward a laptop that moves between desks more comfortably than it accompanies an outlet-free working day.
The verdict: sensible compromises, for the right owner
TechRadar’s four-out-of-five assessment makes sense on its own terms: a large gaming laptop with capable hardware, pleasing everyday controls and cooling the reviewer liked, balanced against noise, flex and limited endurance. Its alternatives underline the choice: the Erazer Major 16 X1 offers a sharper 1600p screen and higher specifications at a higher reported price, while the reviewed Asus V16 sacrifices graphics capability for a lower price and much longer movie-playback endurance.
For a desk-based buyer, the P10 deserves consideration. Before committing, confirm three things: the exact GPU memory capacity, the configured GPU power limit and the actual selling price. Those details will tell you more about value than the Core i9 and RTX badges alone.
The corners Medion has cut may be acceptable. The trick is making sure they are not the corners you personally needed.
- Medion Erazer Defender 17 P10 review: Cutting corners in the right places TechRadar · 2026-11-17T09:47:00+00:00
- Intel® Core™ i9 processor 14900HX (36M Cache, up to 5.80 GHz) Specifications intel.com
- Compare GeForce RTX Laptops | NVIDIA nvidia.com
