What Montech actually launched
Montech is marking its 10th anniversary with the King 95 3D and King 95 3D Pro dual-chamber cases, alongside LINK FAN INF 120 magnetic ARGB fans and LUMI lighting software. Both King 95 3D models launched on November 11, 2026, in black and white.
The design change is simple. The 3D keeps the King 95's 15-degree curved-glass front and adds a top glass panel, which gives a third window. Montech also built in a 118-LED ARGB contour strip that follows the chassis.
Pricing: Standard versus Pro
- King 95 3D: Montech lists a US recommended price of $119.90 for the standard case. You choose your own fans.
- King 95 3D Pro: at $199.90, it ships with seven pre-installed LINK FAN INF 120 fans and a LUMI HUB.
- The bundle maths: Buying the seven fans and hub separately would cost US$144.50, which makes the Pro package US$64.50 cheaper than the standard case plus those parts.
That comparison comes from Montech, not from an independent price survey. Prices and availability will vary by region.
One outlet disagrees. KitGuru's review text states a price of $199.99 for the plain "King 95 3D". That appears to conflict with Montech's own figures, so treat it with caution. I would trust the manufacturer's $119.90 and $199.90 split until retail listings settle.
Specs that decide whether your parts fit
Figures below are from Montech's product page, as supplied for this report:
| Item | Spec |
| Case size (L×W×H) | 480 × 300 × 534 mm |
| Motherboards | ATX, Micro-ATX, Mini-ITX (back-connect supported) |
| CPU cooler clearance | 172 mm |
| GPU clearance | 450 mm |
| PSU | Up to 220 mm ATX |
| Drives | One 3.5-inch, two 2.5-inch |
| Fans | Up to ten 120 mm (3 top, 2 side, 3 bottom, 2 rear) |
| Radiators | Top 120/240/360 mm; side 120/240 mm; rear 120 mm |
| Front I/O | 20 Gbps USB-C, two USB-A, headset jack |
| Warranty | One year |
Tom's Hardware adds three limits. It does not support E-ATX motherboards. Montech says vertical GPU mounting is not supported. And although the case supports several radiators, only one of them is a 360 mm unit.
The reviewer lists the USB-A ports as 5 Gbps USB 3.2 Gen 1. Montech's page only labels them USB 3.0 and confirms the USB-C port at 20 Gbps.
Radiator discrepancy: KitGuru says the 3D is 90 mm taller than the original King 95 to fit a 360 mm AIO on the right-hand side. Amazon's listing also mentions a 360 mm side AIO. Montech's own spec lists 360 mm at the top and 240 mm at the side. If you plan a big AIO, check the manufacturer's manual before buying.
The Pro's fans, hub and lighting
According to Montech, the Pro's seven fans are five reverse-blade intake fans and two standard-blade exhaust fans. The standard case has no fans installed. The bottom fan bracket tilts through an 8° range, so you can aim incoming air.
On the hub, Montech says one 7-pin cable links up to seven fans, and one hub supports up to 14 LINK FANs. Tom's Hardware says 13. I'm not sure which is right, and the difference only matters if you plan a very large fan array. The LUMI HUB is required for LUMI software control, which offers 20 lighting effects.
Tom's Hardware found a quirk: the hub ships with both versions but is loose in the Pro box and pre-installed on the standard model.
What the review found
The reviewer tested the Pro out of the box with its seven fans and an air cooler. The write-up is qualitative. No temperatures, noise figures or test hardware are given in the text I could inspect, so I won't rank the case numerically.
In favour:
- Three-pane views and a clean, curved look. The reviewer calls it "one of the better-looking panoramic cases on the market."
- Seven fans and a controller included in the Pro.
- A tool-less adjustable GPU support strut.
- Generous cable space behind the tray, with Velcro straps. The top area is offset, which eases EPS cable routing.
- A bottom dust filter that slides out from the front.
Against:
- The fans' RGB and infinity-mirror styling is polarizing. The reviewer wanted a non-RGB pre-installed option.
- Fans can get noisy at full speed. In normal use they ran relatively quietly.
- GPU temperatures ran a bit warmer in noise-normalized testing.
- Side-panel dust filters can't be removed on their own. You have to take off the whole panel.
- The top glass takes extra steps to remove. You open the main panel for a retaining screw, undo it, loosen the rear thumbscrews, slide the glass back, then remove more screws. The reviewer didn't need to do this during the build.
- Motherboard-tray grommets pull out easily while routing cables.
- Glass shows fingerprints.
Who should buy which version
If you want a coordinated look with little fuss, the Pro bundle is the better value on Montech's own numbers. If you prefer non-RGB fans or have a favourite brand, the $119.90 standard case is the more sensible choice. That extra cost matters less than it did, since the Pro saves money only if you actually want those fans.
Air-cooled builders should note that the large empty space above the motherboard looks unfinished unless you fill it with fans. An AIO radiator would fill it neatly.
Check your parts against the limits before you buy. The 172 mm cooler limit, the 450 mm GPU limit and the single 3.5-inch bay are the likely snags. The lack of vertical GPU mounting rules out some showcase layouts.
Bottom line
The King 95 3D line is a good-looking, fairly priced showcase case, and the Pro's fan bundle is competitive. The caveats are all in the details. Thermal results are described only in general terms, the side-radiator and hub specs disagree between sources, and the top glass is fiddly to remove. Wait for more independent testing if airflow is your priority.
- Montech King 95 3D Pro case review: The King has returned – bigger, and now with three-pane panoramic views Tom's Hardware · 2026-11-11T14:00:00+00:00
- Montech KING 95 3D Cases Launch With Seven-Fan PRO Model - Techtroduce techtroduce.com
- MONTECH Launches KING 95 3D Cases and LINK FAN Magnetic Fans montechpc.com
