A gaming laptop with a colorful screen and RGB keyboard sits on a desk among headphones, a controller, and camera gear.
The MSI Stealth 16 AI+ is a thin laptop that looks like an ordinary work machine. PCWorld contributor Mattias Inghe's review of it carries the headline "A powerful gaming laptop in disguise." MSI's own page lists up to 16 cores and 50 NPU TOPS for the Core Ultra 9 386H. The review is a translation of a piece first published by PC för Alla, and it gives the laptop 4 out of 5. The review, MSI's specifications and retailer listings don't always agree. A buyer needs to check the exact model number before spending $2,300 or more.
A gaming laptop with a colorful screen and RGB keyboard sits on a desk among headphones, a controller, and camera gear. What was tested​
The review unit is the MSI Stealth 16 AI+ B3WG-038NEUNN, tested in October 2026. Its spec table lists:
  • Intel Core Ultra 9 386H
  • Nvidia GeForce RTX 5070 with 8GB of graphics memory
  • 16GB of LPDDR5x memory
  • A 1TB SSD
  • Windows 11 Home
  • A 16-inch glossy OLED panel at 2560 × 1600 and 240Hz, rated at roughly 360 cd/m²
  • Wi-Fi 6E and Bluetooth 5.3
The reviewer wanted more memory than the 16GB in his unit. He says the same model comes with 32GB or 64GB, and that on paper it goes up to 128GB. The review also names a US configuration with the same CPU and GPU but 32GB of RAM at $2,299.99, listed at Micro Center. A second listing on the page showed $3,099.99. Those are listings captured when PCWorld published, not guaranteed current prices.
Where the sources disagree​
Several details in the review don't match other sources. Treat the following as open questions, not settled facts.
  • Core count. The review text says the processor has twelve cores. MSI lists the 386H as up to 16 cores: 4 P-cores, 8 E-cores and 4 low-power E-cores. Notebookcheck also describes it as a 16-core chip. The review's own spec table lists the same 4 + 8 + 4 core layout, which adds up to 16. The "twelve cores" line looks like a slip.
  • Memory and upgrades. The review lists LPDDR5x memory and one M.2 slot. A Micro Center listing for a US model shows DDR5 in two SO-DIMM slots, with a 128GB maximum and 1TB of NVMe storage. MSI's page promotes dual PCIe Gen4 SSD support for the B3W line. The 16GB review unit may be a regional SKU with a different memory design. If you plan to upgrade RAM or add a second SSD, confirm that for your exact model.
  • GPU memory. The review says 8GB for the RTX 5070. The Micro Center listing for a US RTX 5070 model says 12GB GDDR7. Regional variants differ, so don't assume the review's 8GB applies to a US purchase.
  • Wireless and thickness. The US Micro Center listing shows Wi-Fi 7 and Bluetooth 6.0, while the review unit lists Wi-Fi 6E and Bluetooth 5.3. The review quotes 0.8 inches closed. MSI quotes 16.65 mm, about 0.66 inches, at the thinnest part. Those two figures can both be true.
Performance​
The review credits the Core Ultra 9 386H with handling video conversion, code compilation and large video projects with many filters and effects. The reviewer says the system only starts to feel sluggish after that. He says the RTX 5070 holds high frame rates in most demanding games at the native 2560 × 1600. He would have liked a 5070 Ti or 5080.
The review includes benchmark scores:
TestResult
Cinebench 2026, multi-thread4,427
Cinebench 2026, single-thread495
Geekbench 6, multi-core / single-core14,404 / 2,813
Geekbench 6 GPU124,232
3DMark Time Spy14,047
3DMark Port Royal8,972
Storage read / write7,059 MB/s / 5,918 MB/s
These are single runs on one unit. The review gives no game-by-game frame rates, so "high frame rate" is the reviewer's impression. I'd also be careful with the 50 TOPS NPU figure. The reviewer calls TOPS a vague measure, because there's no sensible general way to compare AI performance across platforms.
Display, sound and cooling​
The OLED panel is the review's standout feature. The reviewer praises its color accuracy and brightness control. He also likes the built-in presets for Adobe RGB, DCI-P3 and sRGB, and the support for calibration with an X-Rite device. The laptop can switch display profiles automatically depending on the foreground application. It supports G-Sync and is certified for VESA DisplayHDR True Black 600, though the reviewer couldn't always activate HDR where he expected to.
The speakers get a more mixed verdict:
  • They are loud and fine for games and films.
  • Detail is lost, and they turn shrill at high volume.
  • Nahimic software helps with an equalizer and surround sound.
The cooling is a strength. The reviewer says the fans become audible during demanding games or heavy video export, but there is no "jet-engine" roar. In low-performance mode for web browsing the laptop stays mostly silent. The spec table lists a noise level of 0–39 dBA.
Design, ports and software​
The Stealth name fits the design. The lid is aluminum, and the only obvious sign of a gaming machine is the four-zone RGB keyboard. The keyboard is comfortable but has no numeric keypad. There are some caveats on the ports:
  • The laptop has two Thunderbolt 4 ports, two USB-A Gen 2 ports, HDMI, a headphone jack and wired networking.
  • The Thunderbolt ports do not support power delivery.
  • Charging goes through a separate proprietary connector. The charger is thicker than the laptop itself.
MSI Center handles performance modes, cooling, RGB lighting and backups. The reviewer's main complaint is that you have to install each module by hand, and they run strangely sluggishly. An AI mode adjusts performance and cooling over time. The review also lists microphone noise filtering and network optimization. It reports no measured gains from any of these, so don't treat the "AI" label as proof of better performance.
Battery life​
The battery is rated at 90Wh. Under heavy CPU and GPU load, the reviewer says it lasts about an hour. His spec table lists 1 hour 5 minutes at high load and brightness, and 16 hours 30 minutes at low load and brightness. In everyday use with AI mode on and the screen dimmed, note-taking and occasional browsing lasted a full day. Those figures come from different workloads, so none of them is a universal expectation.
Who should buy it​
It suits people who want one machine for creative work and gaming, and who don't want it to look like a gaming rig. The review's listed drawbacks are MSI Center, the speakers and the price. I'd add three practical points:
  1. Match the model number. The review unit's memory, GPU memory and wireless specs differ from the US listings above. Compare the part number, not just the "Stealth 16 AI+" name.
  2. Prefer 32GB or more. The reviewer says 16GB is thin for creative work and modern games. The US configuration he found has 32GB.
  3. Expect a heavy brick. The slim body comes with a bulky proprietary charger, and USB-C charging isn't available.
Overall, this is a capable, quiet, good-looking laptop with an excellent screen. Because the configurations vary so much, the spec sheet on the exact SKU matters more than the review headline.
  1. MSI Stealth 16 AI+ review: A powerful gaming laptop in disguise PCWorld 2026-10-21T11:00:00+00:00
  2. MSI Stealth 16 AI+ B3WH - Reviews and Specs - Notebookcheck Reviews Collection notebookcheck.net
  3. MSI Stealth 16 AI+ B3WGX Copilot+ PC OLED 16" Gaming Laptop Computer - Charcoal Black; Intel Core Ultra 9 386H 1.6GHz - Micro Center microcenter.com
