A wired Xbox controller sits on a gaming desk beside a monitor displaying polling-rate settings and component close-ups.
Nacon’s Revo X Max puts adjustable stick tension and micro-switch controls into a wired Xbox and Windows controller listed at $69.90. GamingTrend’s review finds responsive controls alongside some decidedly budget-feeling details—but for PC players, the most consequential caveat concerns what happens when polling rates climb.
A wired Xbox controller sits on a gaming desk beside a monitor displaying polling-rate settings and component close-ups. What the Revo X Max offers​
Nacon lists compatibility with Windows, Xbox Series consoles and Xbox One, with a release date of October 28, 2026. Connectivity is strictly wired through an included detachable, braided, three-meter USB cable. There is a headset jack, but no wireless mode or storage case. That makes cable reach a buying consideration, not an accessory footnote.
The standout customization feature is a ring around each joystick that changes its resistance. Nacon confirms the mechanism; GamingTrend reviewer Henry Viola describes minimum-to-maximum markings that help users adjust the feel. This is physical tension adjustment, rather than simply another sensitivity preset.
Nacon’s specifications also include:
  • Hall-effect sensing in both joysticks and triggers.
  • Micro-switch face buttons and D-pad.
  • Adjustable instant triggers.
  • Four vibration motors, divided between the grips and triggers.
Hall-effect sensing should not, however, be treated as proof that the entire controller is immune to wear. GamingTrend’s review does not establish long-term durability; its enthusiastic drift claims go further than its short-term testing can demonstrate.
The PC polling-rate trade-off​
Nacon advertises 1,000 Hz polling and 1 ms latency specifically on PC. Those are manufacturer claims, not independently measured results from this review, and they should not be carried across to Xbox performance.
GamingTrend reports a default polling rate of 250 Hz and says impulse-trigger vibration stops working above 500 Hz. That limitation is attributed to the reviewer rather than confirmed in Nacon’s inspected specifications. For buyers, it raises a useful question: is the highest polling setting worth losing trigger feedback? The biggest number on the box is not automatically the best setting for every game.
Nacon also advertises a mode that removes joystick dead zones, calling it “Shooter Pro” on the product page and “Pro Shot” in its range comparison. The naming wanders; the stated purpose is consistent.
Responsive, but not uniformly premium​
Viola found the controls smooth and responsive in No Rest for the Wicked, while explicitly noting that he was not evaluating them as a competitive esports player. His more tangible criticisms concern tactile buttons that nevertheless felt somewhat cheap, a finish that collected fingerprints and dust, and a deeply recessed USB-C port that could reject bulkier replacement plugs.
That last observation gives owners a practical precaution: keep the supplied cable, and check connector clearance before buying a replacement. A detachable connection is useful only when the replacement plug can actually reach it.
GamingTrend also reports an included month of Game Pass Ultimate. Its suggestion that the code may not stack with an existing subscription is speculative, so buyers should not assume either eligibility or redemption behavior from that review alone.
What the Max premium actually buys​
Nacon’s official comparison supplies an important distinction: Hall-effect sticks and triggers are not exclusive to the Max. The Revo X, Revo X Pro and Revo X Max all have them, along with four vibration motors.
FeatureRevo XRevo X ProRevo X Max
Hall-effect sticks and triggersYesYesYes
Instant micro-switch triggersNoYesYes
Two programmable rear buttonsNoYesYes
Dead-zone-removal modeNoYesYes
Adjustable stick tensionNoNoYes
Micro-switch face buttons and D-padNoNoYes
These differences come from Nacon’s model comparison, rather than assumptions based on the product names.
With the base Xbox Revo X listed at $39.90, the Max costs $30 more in Nacon’s U.S. catalog. The strongest justification for that premium is its additional control customization—not Hall-effect sensing alone.
The resulting buying case is straightforward: consider the Max if adjustable resistance and micro-switch inputs matter, but weigh its wired-only design and GamingTrend’s reported high-polling feedback limitation first. This is a controller whose appeal rests on specific features, not a blanket promise of “pro” superiority.
  1. Nacon Revo X Max controller review - GamingTrend GamingTrend 2026-10-28T02:14:33+00:00
  2. REVO X MAX Hall Effect Pro controller for Xbox & PC - Nacon nacongaming.com
  3. Revo series controllers for Xbox and PC - Nacon nacongaming.com
