A Nacon Revolution X Max Xbox controller is shown with close-ups highlighting its textured grips and adjustable analog sticks.
Nacon's Revo X Max is a wired controller for Xbox and Windows that puts a physical stick-tension adjustment into a mid-priced pad. TheSixthAxis reviewed it on 20 November and scored it 7/10. The verdict is "good value, with caveats", which is a fair summary.
One naming note first. The review headline says "Revo X Max Pro", but the review body and Nacon's product listing call it the Revo X Max. Nacon's separate "Pro Shooter" mode is a software behaviour, not a model name. Nacon has also confirmed a Revo Pro for 2027, according to KitGuru, so the "Pro" label is easy to mix up.
A Nacon Revolution X Max Xbox controller is shown with close-ups highlighting its textured grips and adjustable analog sticks. What it is and what it costs​
TheSixthAxis describes the Revo X Max as a wired pro-styled controller for PC, Smart TV and the Xbox family of consoles, with a £59.99 RRP. Nacon's listing gives the compatibility as Windows, Xbox Series and Xbox One, with a release date of 28 October 2026.
Prices depend on the region:
  • GBAtemp gives €69.90 (£59.99) and says that is just £5 more than an official Xbox wireless controller.
  • Nacon's US storefront lists $69.90.
  • Nacon's European Revo series page shows €69.90.
KitGuru reported a slightly different UK launch price of £59.90 for the Revo X Max. That is a rounding-level difference from the review's £59.99.
The headline feature: stick tension you can twist​
The Revo X Max's distinguishing feature is physical stick tension. Nacon says you rotate the ring around each stick to find the balance between speed and control. TheSixthAxis says the rings run from very loose to tight, with a lot of steps in between. The reviewer found a setting that felt effortless while staying precise.
This changes the physical resistance of the stick. It is not an electronic sensitivity or dead-zone setting. Anyone who has fought a stiff stick in a shooter, or overshot with a floppy one, will see the appeal. Experienced players tend to have strong, personal preferences here, and Nacon lets you tune them without tools or software.
TheSixthAxis names GameSir's Cyclone and Super Nova as the main rivals at this price. The reviewer says they lack adjustable stick tension but may offer other features that matter more to you. The review doesn't compare them in detail or give their prices.
Hall Effect, switches and the "instant triggers"​
On paper, Nacon's spec list covers most of what pro-style pads advertise:
  • Nacon says the joysticks and triggers use Hall Effect technology. Nacon markets this as ending stick drift. Treat that as a manufacturer claim. A short review can't confirm it, and TheSixthAxis only says the sticks were precise and responsive in testing.
  • Nacon lists micro-switch action buttons and a micro-switch D-pad.
  • Instant triggers use trigger locks, which the reviewer says feel very good in shooters.
  • Nacon lists four vibration motors, a 3.5 mm headset jack and a detachable 3 m braided USB-C cable. TheSixthAxis doesn't evaluate the vibration or headset audio, so these are listed features, not tested benefits.
  • Nacon's specification sheet says Software: No. Customisation is done on the pad itself.
Where the review finds compromises​
The review's complaint is consistency. TheSixthAxis says the mechanical switches cover the face buttons, the D-pad and the locked triggers. The shoulder buttons and rear pro inputs don't get them, and the reviewer found them plasticky. The reviewer also found the full-range triggers light in response. The overall build doesn't feel premium and falls short of Xbox's own controller. The reviewer tested with Gears of War and Overwatch, and the mismatch was noticeable.
Other outlets are broadly positive, with some different complaints:
  • COGconnected calls it a great value for competitive players who don't want to spend big on an Elite-level controller. It also says the controller is fairly large and its shape never quite feels natural.
  • AOL's review lists button combinations that take time to learn and a D-pad whose feedback feels too soft.
  • GBAtemp praises the in-hand feel but also warns the controller is "diabolical for dust".
Comfort and feel are subjective, and the reviewers disagree. TheSixthAxis found the build cheap, while GBAtemp found it sleek and light. If you can, try one in hand before buying.
PC and Xbox: read the fine print​
Nacon says its dedicated PC mode gives 1 ms latency. The spec list says the 1000 Hz polling rate and 1 ms latency apply on PC only. A Windows gamer can use the figures. An Xbox console owner shouldn't expect them.
A 1000 Hz polling rate means the controller reports its state a thousand times a second. That is a polling figure, not a measured end-to-end latency. In practice, display refresh, game engine and network lag will swamp any millisecond gains. TheSixthAxis suggests the lower latency "could improve" your kill/death ratio, then admits your own reaction time is the limit. There is no controlled testing behind a competitive-advantage claim.
An earlier WindowsForum report, based on GamingTrend, noted a reviewer's observation that trigger vibration stops above 500 Hz on PC. That claim is attributed to the reviewer and isn't confirmed in Nacon's specifications. If rumble in the triggers matters to you on PC, check this before buying.
Where it sits in the Revo family​
Nacon's US storefront lists four controllers: Revo PC, Revo X, Revo PC Max and Revo X Max. The US prices are $29.90, $39.90, $59.90 and $69.90. Nacon's own comparison shows that Hall Effect sticks and triggers are not exclusive to the Max. You are paying the Max premium for the adjustable tension, the micro-switch controls, the instant triggers and the programmable shortcut buttons.
Bottom line​
  • Buy it if: you want a wired pro-style pad for Windows or Xbox and care about adjustable stick resistance.
  • Think twice if: you want wireless, a premium feel on every button, or proven long-term durability. The review calls the Hall Effect sticks long-lasting but can't verify that.
  • Keep it in perspective: Nacon's drift and latency claims are marketing. The review's best evidence is the stick-tension adjustment and the feel of the face buttons and locked triggers.
At roughly £60, the Revo X Max is a controller with one standout idea and some uneven execution. Whether the adjustable tension is worth the plastic is a personal call, but this is the first pad at this price where you can make that call with your thumbs.
  1. Nacon Revo X Max Pro Controller Review – Stick or twist? - TheSixthAxis TheSixthAxis 2026-11-20T09:00:58+00:00
  2. Nacon Revo X Max Review - Feature Packed With a Few Comfort Compromises - COGconnected cogconnected.com
  3. Nacon’s new Revo controllers bring Hall Effect sticks to the budget market | KitGuru kitguru.net
