A neon-lit gaming setup features a curved ultrawide monitor showing sports cars racing along a coastal highway.
Philips says its new Evnia 36M4C5500P is the world's first 36-inch gaming monitor with a 260 Hz refresh rate. The 260 Hz figure comes with a catch. Pricing is also still missing, and so is any independent testing.
A neon-lit gaming setup features a curved ultrawide monitor showing sports cars racing along a coastal highway. What Philips announced​
Philips has added the 36M4C5500P to its Evnia lineup. It is a 36-inch curved ultrawide with a 260Hz overclockable refresh rate. Philips' launch release is dated October 22, 2026, and PC Gamer covered it the next day. "World's first" is Philips' own wording, and PC Gamer reports it as "Philips says". The French site Hardware Cooking also notes that the claim comes from the press release and that it could not verify it independently.
The panel is a 36-inch curved fast VA 1500R panel with Ultra-Wide QHD resolution and a 21:9 aspect ratio. Ultra-Wide QHD here means 3440 × 1440. It is the same resolution as most 34-inch ultrawides, so the extra two inches of diagonal come without extra pixels. That means a slightly lower pixel density.
Specs at a glance​
ItemDetail
Size / curve36-inch, 1500R curved Fast VA
Resolution3440 × 1440, 21:9
Refresh rate260 Hz overclockable (see below)
HDRVESA DisplayHDR 400 certified; Philips quotes 500 nits peak
InputsTwo HDMI 2.1, one DisplayPort 1.4
OtherMultiView, height/swivel/tilt stand, Iconglow rear RGB logo
SeriesEvnia 5000 / M4
The 260 Hz catch​
Philips' own wording calls 260 Hz overclockable. Guru3D reports a different baseline: a 240Hz refresh rate with an optional overclock mode reaching 260Hz. The press release I reviewed doesn't state the native rate. Guru3D does, so treat the 240 Hz figure as that outlet's reporting. If it's right, the headline 260 Hz is a modest step over an already fast native mode. Guru3D's advice is that buyers should wait for independent testing of motion clarity, HDR performance and color accuracy.
The Philips product page also carries a standard warning. You should make sure your graphics card can reach the display's maximum resolution and refresh rate. Philips' material doesn't say which input supports 260 Hz at full resolution, and it doesn't describe how to enable the overclock. I won't guess at either.
Why 260 fps at this resolution isn't trivial​
Here is my own arithmetic from the announced specs, not a benchmark. 3440 × 1440 is 4,953,600 pixels per frame. At 260 frames per second, that is about 1.29 billion pixels a second, before any signal overhead. Holding anywhere near 260 fps takes a strong GPU in demanding games. The monitor's high refresh rate will be most useful in esports-style titles or less demanding games. Upscalers such as DLSS or FSR can help, as the French outlet suggests.
Reading the response-time numbers​
Philips lists 0.3 ms Smart MBR, and its disclaimer says the value is equal to SmartResponse, measured with a one-horizontal-line pattern. Other coverage reports a 0.3ms MPRT response specification and 1ms GtG. These are different measurements. As EGamers.io puts it, read the 0.3ms number as a best-case result. Judge the monitor on 1 ms GtG and on independent reviews.
The "AI" features​
Philips names ShadowBoost, Smart Crosshair, Smart Sniper and Smart MBR Sync. Philips says ShadowBoost brightens dark scenes without blowing out highlights, and that the crosshair and sniper modes target FPS play. PC Gamer's Andy Edser suggests most players can ignore them. There are no measured results behind any of these claims yet. In-game overlays and crosshair tools can also run against competitive-game rules, so check a title's policy before relying on one.
Connectivity​
The display has two HDMI 2.1 ports, one DisplayPort 1.4 connection and a 3.5 mm audio jack. StrongMocha, citing Wccftech's product details, says it has no USB ports for peripherals. I haven't verified that against Philips' own spec sheet. For PC users, DisplayPort 1.4 will probably be the main connection. Whether it carries the full 260 Hz isn't documented in the material I reviewed.
Price and availability​
  • Price: none announced. The announcement does not list a retail price.
  • Region: Philips says this new monitor will be officially released in APAC region. The release names no launch date and no retailers. There is no confirmed U.S. or European release in the sources I found.
  • Affordability: PC Gamer hopes for a lower price, but that is speculation. Wccftech notes the Evnia 5000 series is a monitor family from Philips that mostly has affordable displays. That hints at positioning, not a price.
Who should care​
The 36M4C5500P is aimed at gamers who find a 34-inch ultrawide too small and a 39-inch-plus model too big. Its Fast VA panel, DisplayHDR 400 rating and 500-nit peak HDR claim point to a mainstream product, not a flagship. VA panels typically offer strong contrast, but their motion behavior and HDR performance vary from model to model. I'd hold off judging until reviewers have tested it.
Bottom line: this is a real and unusual product, though not yet a verified one. The claims to watch are the "world's first" label, the 260 Hz overclock, the 0.3 ms figure and the price. For now, the safest summary is a 36-inch ultrawide with a fast VA panel, announced for Asia-Pacific.
  1. In a rare instance of good news, Philips has announced the world's first 36-inch, 260 Hz gaming monitor. So that's nice - PC Gamer PC Gamer 2026-10-23T14:55:41+00:00
  2. Philips Evnia 36M4C5500P pairs 240Hz ultrawide with 260Hz overclock mode guru3d.com
  3. Philips Evnia 36M4C5500P Is Billed As The First 36-inch Curved Gaming Monitor - EGamers.io - P2E NFT Games Portal egamers.io
