Cybersecurity workflow showing a Secure Boot shield protecting servers and PCs in a network.
Microsoft’s Sample Secure Boot E2E Automation guide gives enterprise teams a practical, script-driven playbook to detect, collect, and report Secure Boot certificate readiness across Windows fleets — but it also exposes operational and security trade‑offs that IT must plan for before rolling anything out at scale. The collection scripts, Group Policy deployment helpers, and recommended server-side share configuration simplify inventory and monitoring, yet the approach relies on careful ACL design, secure transport and storage of telemetry, and conservative pilot testing to avoid creating new attack surfaces or causing accidental service disruptions.
Background​
UEFI Secure Boot is a firmware-level trust mechanism that ensures only cryptographically signed code runs before the operating system initializes. Microsoft and OEMs are executing a coordinated certificate rollover — replacing long-lived Secure Boot certificates issued around 2011 with a newer 2023 CA family — because the original certificates begin expiring in mid‑2026. This migration is time sensitive: devices that do not receive the replacement certificates risk losing the ability to accept future Secure Boot updates and to validate newer boot components, creating a degraded pre‑boot security posture. Multiple operational notices and IT playbooks from Microsoft have framed this as a platform-level maintenance event requiring inventory, testing, and targeted remediation.
The Sample Secure Boot E2E Automation content (the “sample guide”) frames a Phase 1: Detection and Status Monitoring approach that helps teams answer simple but critical questions at scale: which devices already carry the new certificate material, which devices remain on the legacy CA, and which devices require intervention from OEM firmware or manual steps. The guide supplies PowerShell collection scripts and a GPO-based deployment helper so organizations can bootstrap a telemetry collection pipeline using existing Windows management primitives.
What the sample guide provides: a high-level inventory and automation toolkit​
The guidance and artifacts included in the sample make it straightforward for IT teams to implement a distributed collection pipeline that reports device-level Secure Boot readiness into a centralized file share and then aggregates results for analysis.
Key components included or referenced by the sample guide:
  • PowerShell collection script(s) that capture Secure Boot state, registry markers, and relevant event log entries. These scripts surface fields like SecureBootEnabled, OverallStatus (Complete, ReadyForUpdate, NeedsData, or Error), BucketHash (a device “bucket” for confidence data matching), and SecureBootTaskEnabled (status of the update task).
  • Server-side instructions to create a dedicated file share and set ACLs that permit device write access while preserving administrative aggregation rights. The example uses a hidden share name (ending in $) and grants “Authenticated Users” change access alongside “Domain Admins” full control.
  • A Domain Controller–side helper script named Deploy-GPO-SecureBootCollection.ps1 which:
  • Creates and links a GPO for startup scripts,
  • Copies the collection script into SYSVOL for distributed availability,
  • Optionally creates a scheduled task on endpoints for periodic collection,
  • Accepts parameters such as domain name, OU selection, collection share path, schedule, and random delay to spread load.
  • Guidance on pilot testing (run the collection on a single machine or small pilot OUs before broad GPO deployments) and fleet-size guidance for rollout delays to avoid hot‑spots and SMB contention. The sample lists delay ranges tied to fleet size (for example, 4 hours for 1–10K devices, 8 hours for 10–50K devices, and 12–24 hours for >50K devices).
Taken together, these assets provide a reproducible path to inventory Secure Boot readiness at scale — a crucial first step ahead of the certificate rollover deadlines.
Technical walkthrough: how the scripts and GPO integrate​
1) Fileshare and ACL setup​
The sample’s recommended pattern:
  • Create a dedicated directory (e.g., D:\SecureBootCollection) and expose it as a hidden SMB share (e.g., SecureBootData$ or SecureBootLogs$).
  • Apply ACL entries that allow Authenticated Users to create files, append data, and write attributes, while reserving FullControl for Domain Admins to facilitate aggregation and troubleshooting.
  • Example PowerShell snippets demonstrate creating the directory, creating the SMB share with New-SmbShare, and creating FileSystemAccessRule entries to apply with Set-Acl.
Why this pattern? Startup scripts and scheduled tasks run in machine context and need a writeable target for per-device telemetry. Granting Authenticated Users the ability to create files is simple and scale-friendly, but it introduces operational security requirements (see the risks section below).
2) Endpoint collection script​
The collection script performs several functions:
  • Reads the Secure Boot state and servicing keys exposed in the registry and UEFI variables.
  • Checks for relevant Event Log entries that indicate certificate update activity.
  • Packages results (hostname, timestamp, SecureBootEnabled, OverallStatus, BucketHash, SecureBootTaskEnabled) and writes them to an endpoint-specific file in the shared directory.
  • Optionally supports scheduled execution to provide periodic heartbeats rather than a single snapshot.
The script’s output model — per-host files written to a central share — simplifies aggregation for teams that can consume flat files, but it also requires robust file-naming conventions and a simple reconciliation process to avoid duplicates and race conditions.
3) GPO and scheduled-task deployment​
Deploy-GPO-SecureBootCollection.ps1 is a Domain Admin–level helper that automates:
  • Creating a named GPO and copying the collection script to SYSVOL.
  • Configuring a Computer Startup Script inside the GPO so the collection runs early in the boot cycle.
  • Optionally creating a scheduled task via GPO preferences or creating a startup-scheduled task on clients for periodic sampling.
  • Linking the GPO to the selected OU(s), either specified explicitly or auto-detected. Parameters include -Schedule, -ScheduleTime, and -RandomDelayHours to manage collection timing and reduce network peaks.
This approach leverages built-in Windows management tooling and scales without third-party agents.
What to verify during testing (short checklist)​
Before wide-scale deployment, validate the following on a single machine and in a small pilot group:
  • Connectivity: Endpoint machine can reach the file share using machine credentials and writes succeed in the intended share path.
  • Permissions: Files are created with expected ACLs and Domain Admins retain aggregated read/write access.
  • Script output fields: Verify SecureBootEnabled, OverallStatus, BucketHash, and SecureBootTaskEnabled are present and carry plausible values (e.g., SecureBootEnabled = True/False; OverallStatus = Complete/ReadyForUpdate/NeedsData/Error).
  • Timing: Scheduled collection respects the configured -ScheduleTime and -RandomDelayHours and does not peak-share bandwidth during business hours.
  • Reboot behavior: If the script runs at startup, confirm it completes before other services depend on its outputs.
  • Resilience: Simulate transient network outage and confirm the script either retries or logs a usable error state.
Run a pilot of at least several dozen devices that represent different OEMs, models, and image variants. Firmware diversity is often the root cause of unexpected behaviors in a Secure Boot certificate rollout.
Strengths of the sample approach​
  • Agentless, low-friction collection: Uses built-in PowerShell, GPO, and SMB; nothing to install beyond what ships with Windows.
  • Reproducible at scale: Using SYSVOL and GPO means the script deployment is resilient and distributed by design, and the helper script can automate OU targeting and scheduling.
  • Practical telemetry model: Per-host flat files are human-readable, easy to parse, and simple to ingest into existing tools or one-off aggregation scripts.
  • Built for an urgent timeline: The sample was designed specifically to support the 2011→2023 certificate rollover effort and reflects the kind of lightweight tooling administrators need to inventory readiness rapidly.
Risks and failure modes — what to watch out for​
The sample guide is practical, but it trades simplicity for security and operational nuance. Below are the most important risks and practical mitigations.
Risk: Overly permissive file-share ACLs​
Granting Authenticated Users write access simplifies per-machine writes but creates attack surfaces:
  • An attacker who obtains a machine account (or can run code in machine context) could overwrite or inject telemetry files, pollute aggregation data, or use the share as a staging area.
  • The $ suffix on the share name only hides it from browse lists; it does not enforce security. Visibility is not security.
Mitigations:
  • Restrict write access to specific computer-based groups (e.g., a security group populated with managed client computer accounts) rather than Authenticated Users.
  • Enable SMB encryption for the share and enforce signing where possible.
  • Use per-machine subfolders and enforce a naming convention. Apply an ACL that only allows the specific machine account (or the Domain Computers group scoped to the OU) to write to its folder.
  • Consider using a secure ingestion endpoint (HTTPS API) or agent telemetry channel for environments where the share model is unacceptable.
Risk: Tampering and integrity of telemetry​
Flat-file telemetry lacks built-in tamper-evidence.
Mitigations:
  • Sign the telemetry payload with a local machine certificate or HMAC keyed by a per-machine secret (this requires more complexity but provides integrity checks).
  • Retain original timestamps and preserve UID mapping for auditability.
  • Use a secure aggregation host that validates incoming files and computes a server-side digest before storing long-term.
Risk: Network and SMB contention at scale​
Large fleets writing simultaneously can overload SMB shares and saturate WAN links.
Mitigations:
  • Use the -RandomDelayHours parameter and per-OU scheduled windows to spread load, as the sample recommends. The guide’s suggested windows scale with fleet size: 4h for 1–10k, 8h for 10–50k, 12–24h for >50k.
  • Consider a tiered aggregation model: regional shares with periodic pull to a central repository, or using an endpoint that posts to a local collector which then proxies to central storage.
Risk: Unexpected firmware diversity and OEM behavior​
Not all OEMs expose the same UEFI variable behavior or respond identically to Windows-servicing updates. Some devices will require manual firmware updates or OEM-supplied packages to accept the new CA family.
Mitigations:
  • Prioritize pilot testing across hardware families and record device-specific remediation steps.
  • Inventory firmware versions and OEM model numbers as part of collection so you can pivot remediation to vendor update channels if needed.
Risk: GPO misconfiguration or SYSVOL replication issues​
A mistyped GPO deployment or SYSVOL replication lag can spread an outdated script or cause inconsistent behavior across domain controllers.
Mitigations:
  • Validate SYSVOL replication status before rollout and use the script’s dry-run or simulation modes where available.
  • Test GPO application on a small OU and use gpresult/Event Viewer to confirm script execution results.
Operational playbook — step-by-step (recommended)​
  • Inventory and plan
  • Run an initial, narrow pilot (5–50 devices) across representative models and update channels.
  • Gather firmware versions, model numbers, and current SecureBoot states.
  • Prepare collection infrastructure
  • Create dedicated file share(s) and a well-named folder per device or per-OU.
  • Apply restrictive ACLs scoped to machine accounts or tightly controlled groups; enable SMB encryption.
  • Validate collection script locally
  • Run the collection script interactively on a test device and confirm output fields: SecureBootEnabled, OverallStatus, BucketHash, SecureBootTaskEnabled.
  • Verify the same machine when executed as a startup script and via scheduled task.
  • Deploy with GPO in staged rings
  • Use Deploy-GPO-SecureBootCollection.ps1 to create the GPO and schedule staggered rollouts; keep initial rings small.
  • Configure -RandomDelayHours and per-OU windows to avoid share contention.
  • Aggregate and analyze
  • Build simple parsers or ingest into your SIEM/CMDB for correlation.
  • Prioritize remediation by OverallStatus buckets: target ReadyForUpdate and NeedsData first, then investigate Error.
  • Remediate and verify
  • For devices requiring firmware updates, coordinate with OEM support channels.
  • For devices blocked by local policies or missing prerequisites, collect logs and escalate to imaging or security teams.
  • Report and schedule follow-up
  • Track progress in a dashboard, and schedule recurring scans until the fleet shows Complete (or equivalent completed states).
  • Keep an audit trail of who changed share ACLs and who ran remediation actions.
Troubleshooting matrix (common failure modes)​
  • Symptom: No files appear in the share from target machines.
  • Check machine account network access to the file server (firewall/NAC).
  • Confirm startup script precedence and that the script runs under System context.
  • Validate New-SmbShare and share permissions; check effective permissions for SYSTEM and Domain Computers.
  • Symptom: Files are present but incomplete or malformed.
  • Run the script interactively with verbose logging to identify missing dependencies or permissions.
  • Look for event log entries related to script execution (Group Policy startup scripts log events).
  • Confirm the script’s PowerShell execution policy or remoting settings are not blocking execution.
  • Symptom: Aggregate data shows suspicious or inconsistent timestamps/files.
  • Check for time skew across domain controllers and endpoints.
  • Verify there’s no automated process cleaning or rewriting files on the share.
  • Symptom: Excessive SMB load or timeouts.
  • Adjust schedule windows and -RandomDelayHours; implement regional aggregation or local caching.
Compliance, auditability, and retention​
Collecting host-level telemetry that may include identifiers and configuration details has compliance implications. The sample guide’s flat-file approach favors speed, but teams must still:
  • Define retention windows and ensure storage meets enterprise retention policies.
  • Apply access controls and auditing on the share (file-create, file-read, file-delete events).
  • Consider encrypting telemetry at rest and in transit, and document the chain of custody for any remediation action taken as a result of the data.
Treat the collection pipeline as a sensitive operational service that must itself be monitored and hardened.
When the approach is not appropriate​
The sample’s SMB-write, GPO-based model is ideal for many Active Directory–centric shops, but there are scenarios where it’s suboptimal:
  • Air-gapped or highly regulated environments where SMB shares are disallowed or where per-host outbound HTTPS is restricted.
  • Mixed-OS fleets where macOS/Linux systems require different ingestion channels.
  • Environments that demand higher tamper evidence and cryptographic integrity; these may be better served by agent-based telemetry that supports signing and tamper-detection.
If you fall into these categories, treat the sample guide as a conceptual blueprint and adapt the telemetry transport layer to meet your constraints.
Why acting now matters (timeline and urgency)​
The certificate rollover is not theoretical: Microsoft’s operational notices and IT advisories make clear that the legacy certificates issued circa 2011 begin expiring in mid‑2026, and Microsoft has published updated guidance and servicing packages to deliver the 2023 CA family to capable devices. Organizations that delay inventory and remediation risk having a non-trivial number of devices enter a degraded Secure Boot state that could limit future firmware or boot-time updates. The sample collection guide — despite its trade-offs — gives administrators a fast path to answer “who is ready?” across thousands of devices, a critical capability when months (not years) separate discovery from compulsory remediation.
Final judgment and recommendations​
Microsoft’s Sample Secure Boot E2E Automation guide is valuable because it reduces the time and complexity required for enterprises to inventory Secure Boot certificate readiness. It is pragmatic and leverages native Windows tooling, making it accessible to most Active Directory environments. However, the sample intentionally prioritizes deployability over hardened telemetry controls; follow-on work is required to harden the pipeline for production use.
Immediate recommendations:
  • Use the sample as a pilot and validation tool — test extensively on pilot OUs and across hardware families.
  • Replace Authenticated Users write permissions with narrowly scoped computer group permissions or per-machine ACLs, and enable SMB encryption and auditing.
  • Stagger rollouts with the recommended delay windows for your fleet size to avoid SMB hot‑spots and minimize the risk of network saturation.
  • Collect firmware and OEM model metadata alongside the Secure Boot state so you can route remediation to the correct vendor channels when firmware updates are required.
  • Consider augmenting the flat-file model with a secured ingestion endpoint or signed telemetry model if you require stronger integrity guarantees.
The clock is real, and the operational deadline for the certificate rotation is not abstract. Treat the sample guide as a fast, pragmatic first step — then harden, audit, and iterate until your fleet shows a consistently Complete posture.
In short: the sample guide gives you a fast, low‑barrier path to visibility — use it to learn where your risks are, not as the final hardened solution. Pilots, strict ACLs, encrypted transport, tamper-evident telemetry, and OEM coordination are the safeguards that turn the sample guide from a quick diagnostic into a safe, enterprise‑grade program.
  1. Sample Secure Boot E2E Automation Guide - Microsoft Support Microsoft Support
