Roadmap timing needs careful reading
Microsoft’s roadmap listing for 577869 records an in-development status, a July 2026 preview estimate, and March 2027 general availability estimate. It lists Web and Worldwide (Standard Multi-Tenant), but those metadata fields should not be read as confirmation that every tenant has access. Microsoft explicitly describes roadmap dates as estimates subject to change.
There is already evidence of preview implementation: Microsoft’s Power Automate for desktop 2608 release notes document improvements to AI-assisted repair. The sensible interpretation is a documented preview with a future GA estimate—not a newly completed general release.
Requirements and the repair workflow
Microsoft Learn specifies these prerequisites:
- Power Automate for desktop 2.70 or later.
- An eligible organization premium account; Microsoft lists no extra charge, while reserving service limits or changes.
- Administrator enablement through Power Platform admin center > Copilot > Settings > Power Automate > Copilot in Power Automate.
- A supported region and cloud. GCC, GCC High, DoD, and sovereign clouds are excluded.
For an eligible desktop flow:
- Open the designer and choose Run with AI-assisted UI Automation Repair.
- When a selector fails, capture the intended interface element.
- Review, edit, and test the proposed selector.
- Accept it, recapture the element, or skip the suggestion.
- Save the flow to retain accepted changes permanently.
Skipping without configured error handling stops the debugging run. Errors unrelated to selectors remain outside the feature’s scope.
What the desktop release notes add
Build 2608 makes the workflow more practical for targeted troubleshooting. Microsoft documents an option to begin AI-assisted debugging at a selected action, a visible element picker during recapture, and an AI-generated selector label in the UI elements repository. Its run summary also clarifies that repairs remain unsaved until the flow is saved.
The same release fixes a problem where a recaptured web element was not highlighted and validated correctly. That is a useful distinction for administrators investigating unexpected preview behavior: the client build matters, not just the roadmap entry.
Debugging repair is not runtime self-healing
Microsoft’s separate Self-healing (preview) capability attempts recovery during console and cloud execution, including attended and unattended runs. It has no effect during designer runs. Its documentation also warns that generative AI can occasionally identify an unintended element. These are different maintenance tools, not interchangeable switches.
Check the failure before repairing the selector
Microsoft’s troubleshooting guidance supplies an important reality check: a missing-element error can also mean the window is unavailable, the action references the wrong element, or the target application runs with higher privileges. A replacement selector is not the universal cure.
For timing problems, Microsoft recommends considering Wait for window content or Wait for web page content. For changed selectors, compare captures and favor stable attributes. Also avoid accumulating unnecessary fallback selectors: Power Automate tries variations sequentially, so failed matches can add delay, particularly inside loops.
The practical takeaway is straightforward: use AI to propose the repair, then verify the target and the resulting business action before treating the flow as production-ready. Faster maintenance is useful; confidently clicking the wrong button is merely a faster mistake.
- Power Automate: AI-assisted UI Automation repair Microsoft 365 Roadmap · 2026-10-27T23:05:02.193936Z
- AI-assisted UI automation repair (preview) - Power Automate | Microsoft Learn learn.microsoft.com
- Self-healing (preview) - Power Automate | Microsoft Learn learn.microsoft.com
