A cloud-based workflow platform routes tasks from multiple applications through a central processing hub.
Microsoft's roadmap lists a Power Automate feature called desktop flow libraries. It would let makers publish shared collections of reusable subflows for use across several desktop flows. The roadmap marks it as in development. Preview is planned for January 2027 and general availability for March 2027. The roadmap says the cloud instance is Worldwide (Standard Multi-Tenant).
Those dates are estimates. Microsoft's roadmap page says nothing here is a commitment... more precisely, it says all information is subject to change, and features can be postponed or cancelled. Treat January and March 2027 as planning targets, not promises.
A cloud-based workflow platform routes tasks from multiple applications through a central processing hub. What Microsoft says it is building​
The roadmap entry (ID 579910) says makers will be able to create and publish libraries of reusable automation building blocks. It calls those building blocks subflows. The stated goals are:
  • Centralize commonly used automation logic.
  • Reduce duplication.
  • Simplify maintenance.
  • Promote consistent automation practices.
Today's workaround is copy and paste. Teams that want the same logic in several desktop flows, such as a login routine, an error handler or a logging step, often duplicate it. A library would replace that with one published source.
How reuse works today​
Subflows already exist in Power Automate for desktop, but they live inside a single desktop flow. Community tutorials describe a subflow as a reusable block you call from the main flow, much like a function or method. They can take inputs and return outputs.
Microsoft's own performance guidance already tells makers to reuse desktop-flow components. It lists child desktop flows, UI elements, and custom actions within an environment. A shared desktop flow can be triggered from other desktop flows with the Run desktop flow action. Custom actions can also be built with the Power Automate for desktop actions SDK in C#.
Libraries would sit between these options. The target seems to be shared subflow logic without the overhead of a separate child flow or a compiled custom action. That is my reading of the gap, not something Microsoft states.
What the roadmap doesn't say​
The roadmap entry is short. It does not describe any of the following:
  • How a library is authored or published.
  • How consuming flows find and import a library.
  • Whether a flow gets a linked reference or a copy of the library's subflows.
  • Whether a library update reaches consuming flows automatically or only when someone chooses to update.
  • Versioning, permissions, governance or admin controls.
  • Licensing requirements and minimum Power Automate for desktop versions.
  • How existing local subflows would move into a library.
The update question matters most. Shared logic that changes everywhere at once is convenient until a bad change breaks production flows. If libraries instead work as copies, teams get reuse but not central updates. Microsoft hasn't said which model it will use, so I won't guess.
What admins and makers can do now​
The feature isn't available, so there is nothing to configure yet. Some preparation is still sensible:
  1. Find duplicated logic. List the subflows that repeat across your desktop flows, such as sign-in, Excel setup, logging and exception handling. These are the likely first candidates for a library.
  2. Standardize names and inputs/outputs. Shared building blocks are easier to reuse when their names and parameters are consistent.
  3. Decide who owns shared logic. Settle who may publish and who approves changes. Microsoft hasn't announced governance controls, so an internal review process is the safest starting point.
  4. Watch for preview documentation. Check the details on versioning, update behavior and environment support before committing production automations.
Why it matters​
Large RPA estates tend to collect copies of the same logic that slowly drift apart. A first-party library mechanism would reduce that, if it ships with sensible versioning. Desktop flows are Power Automate's robotic process automation tool. Microsoft describes them as automation for Windows desktop applications, services, and experiences... in its release-plan page, as automation for Windows desktop applications and services, orchestrated and deployed within Power Platform.
Microsoft's stated benefits are the company's rationale, not tested results. The roadmap has no customer examples or measurements. Judge the feature when preview documentation appears.
  1. Power Automate: Desktop flow libraries Microsoft 365 Roadmap 2026-11-17T18:36:41.967573Z
  2. Optimize end-to-end process performance - Power Automate learn.microsoft.com
  3. Power Automate - Desktop flows | Microsoft Learn learn.microsoft.com
