PowerToys Monitor Control panel above a three-monitor setup with display sliders.
Microsoft’s PowerToys appears to be preparing a native monitor-control module that puts common external-display settings — brightness, contrast, color temperature and even speaker volume — directly inside PowerToys’ settings and flyouts, potentially ending the need to hunt through clumsy on-screen-display (OSD) menus for everyday adjustments. The report, driven by a screenshot shared publicly and a proposed GitHub change, shows sliders for brightness, contrast and volume and mentions color temperature and other VCP (monitor) controls; Microsoft has not announced a release date, and a final build is not yet available to the public.
Background / Overview​
PowerToys is Microsoft’s open-source, modular toolkit for power users on Windows 10 and 11. Over the last few years it has acted as an incubator for small but practical features — from FancyZones window tiling to the Run-like Command Palette and the recently added Light Switch automatic theme scheduler — that Microsoft has not folded into the OS at the system level. That track record makes PowerToys a natural home for a monitor control utility that aims to simplify display adjustments across multiple monitors. Third‑party utilities such as Twinkle Tray and Monitorian have long filled the gap for users who want software brightness/contrast controls for external monitors. These apps talk to displays over the industry standard Display Data Channel / Command Interface (DDC/CI). Twinkle Tray and similar tools work well for many setups, but reliability depends heavily on monitor model, cable, dock hardware and driver stacks — a practical limitation that a first‑party PowerToys module would still face even if it provides a cleaner UI.
What the new PowerToys monitor utility proposes​
UI and controls shown so far​
From available screenshots circulating with the initial report, the planned PowerToys module (proposed as “Power Monitor” in community discussions) presents a compact control surface with:
  • Brightness sliders for each detected monitor
  • Contrast sliders
  • Volume controls for monitors with built‑in speakers
  • Color temperature / white balance controls (appears in proposal or PR diffs)
  • Per‑monitor selection and presumably per‑monitor presets
If implemented as shown, this will mimic the experience of vendor apps but in a single, unified, grant‑managed PowerToys module. The UI intent is to make adjustments accessible from the system tray or a PowerToys flyout rather than forcing users to poke tiny OSD buttons on each monitor.
Under the hood: DDC/CI and VCP commands​
These apps and proposals rely on the Display Data Channel / Command Interface (DDC/CI) and Monitor Control Command Set (MCCS) — the VESA standards that let a host talk to a display and change parameters like brightness, contrast, color temperature and speaker volume. DDC/CI is the industry mechanism most software brightness controllers use; Windows itself exposes monitor configuration APIs but historically didn’t provide a unified consumer UI for external monitor controls. Because DDC/CI is the common plumbing, PowerToys’ proposed monitor module would likely use the same VCP commands Twinkle Tray, Monitorian and other utilities use today — meaning compatibility and limitations will largely mirror those apps’ behavior.
Why this matters: practical benefits for users​
  • Fewer button pushes: Most external monitors still require fiddly OSD navigation to change brightness or contrast. A PowerToys slider would let users do the same from the taskbar or a global hotkey.
  • Unified multi‑monitor control: Instead of opening three monitor menus, a single UI could normalize brightness or apply profiles across displays, useful for evening workflows or color‑sensitive work.
  • First‑party distribution and policy controls: As a Microsoft‑maintained module, a PowerToys monitor utility could be deployed via Microsoft Store, winget or enterprise management policies, which is attractive for admins who avoid unmanaged third‑party tools.
  • Cleaner UX than vendor apps: Manufacturer apps often behave inconsistently and are OS‑version dependent; PowerToys tends to aim for a consistent Windows look and feel.
These benefits map closely to the reasons many users already install Twinkle Tray, Monitorian or DisplayBuddy today — quicker workflows and simpler adjustments without physical buttons.
Compatibility, limitations and real‑world caveats​
A critical part of understanding how useful this will be is recognizing the hardware and software conditions that determine whether an external display is controllable.
1) Not all monitors expose full DDC/CI​
Most modern monitors support at least basic brightness and contrast via DDC/CI, but vendors implement subsets of the Monitor Control Command Set (MCCS) differently — some only expose brightness, others expose extra VCPs, and a few expose proprietary or undocumented commands. That means a PowerToys control slider may work perfectly on one display and only partially on another.
2) Cabling, adapters and docks often break DDC/CI passage​
DDC/CI signals travel over the display cable (DisplayPort, HDMI, DVI) and over USB‑C alt‑mode connections. Many USB‑C/Thunderbolt docks, inexpensive adapters, and certain DisplayLink chains do not forward DDC/CI or do so inconsistently — which is why desktop‑dock setups sometimes show missing monitors in third‑party tools. DisplayLink and hub vendors have improved this over time, but the variability persists. This is a major reason why monitor control tools sometimes “can’t find” a display even when it’s connected and working.
3) Driver and OS interactions​
Graphics driver stacks (Intel, AMD, Nvidia) and Windows updates occasionally change how EDID or DDC/CI queries behave, which can break brightness tools until updated. Community reports show that driver updates or firmware changes can make a previously controllable monitor become “not supported” until the stack is corrected. PowerToys may reduce friction for users, but it cannot fully eliminate driver‑level breakage.
4) HDR, color workflows and professional calibration​
For color‑critical work, changing a monitor’s brightness or color temperature via software can upset calibration profiles used in professional workflows. DDC/CI adjustments are not the same as hardware color profiling with a colorimeter; users performing color grading or print work should continue to use calibration hardware and profiles. Twinkle Tray and others note these caveats in their documentation.
Security, privacy and enterprise considerations​
  • Attack surface: DDC/CI control tools write to a hardware channel (I²C over the video link). While this is low risk for typical users, some community threads note that poorly coordinated writes to I²C by multiple programs could cause problems on rare hardware. Microsoft’s PowerToys code review and secure release pipeline reduces but does not eliminate all risk; the project’s open‑source nature helps community auditing.
  • Enterprise policy controls: If this module arrives in PowerToys as expected, administrators will likely prefer the ability to enable/disable the module via Group Policy or Intune — the same pattern PowerToys already uses for other utilities. That makes deployment in managed environments more predictable than relying on assorted third‑party apps.
  • Telemetry and privacy: PowerToys historically includes minimal telemetry and provides settings to control diagnostics; enterprises concerned about telemetry should verify and lock settings during imaging or via policy.
Alternatives today: what to use if you need monitor control now​
If you can’t wait for an official PowerToys release or your monitor isn’t yet supported by the PowerToys module, the following tools remain the practical options:
  • Twinkle Tray (free): a polished, actively maintained Windows app that uses DDC/CI, supports hotkeys, per‑monitor profiles, contrast controls and some VCP commands. It’s available in the Microsoft Store and from GitHub; the developer documents typical compatibility issues and workarounds.
  • Monitorian (free): a lightweight Windows utility for simple brightness sliders; works well for many setups and is available in the Microsoft Store.
  • DisplayBuddy (commercial with free trial): a more fully featured paid app that targets cross‑platform control (macOS and Windows) and smart monitors; the developer positions it as a premium alternative with presets and extra integrations. The pricing and platform availability vary by storefront and update cycle, so expect to see different prices in different marketplaces.
  • Vendor utilities: Dell Display Manager, LG OnScreen Control, Samsung Smart Monitor apps — useful when available, but these often vary widely in quality and availability. For some models the vendor tool is the most complete option (for example, input switching or power options).
If experimenting, remember to check the monitor’s OSD for a DDC/CI toggle (many monitors let you disable external control if you want) and prefer direct DisplayPort or HDMI connections for best DDC reliability (avoid cheap adapters or legacy VGA/DVI when possible). Intel and other vendors publish troubleshooting guidance for enabling DDC/CI when it’s not visible.
How PowerToys’ module could differ from existing apps​
  • Integration and centralization: PowerToys centralizes settings under the same umbrella as FancyZones, Light Switch, and other utilities, offering a single place for power‑user features. That could simplify workflows and make the control flyout more discoverable for mainstream users.
  • Consistent UX and updates: A PowerToys control would follow Microsoft’s visual language and update cadence (Store, winget, GitHub), potentially reducing compatibility nightmares caused by unmaintained vendor apps.
  • Enterprise readiness: As noted, a Microsoft‑maintained module is easier for IT to package and manage than a third‑party utility with unpredictable update cycles.
  • Potential policy & automation hooks: Being first‑party, Microsoft could integrate the module with Windows accessibility or automation features down the line (for example, linking brightness profiles to Focus Assist or scheduled work hours as PowerToys has done with Light Switch).
Risks, shortcomings and realistic expectations​
  • It’s not a hardware fix. PowerToys can’t add DDC/CI to a monitor that lacks it, nor can it coax DDC across hardware that blocks the channel (some docks, adapters and DisplayLink devices).
  • Variability across devices persists. Expect the usual “works on X monitor but not on Y” for certain models and specific VCP features.
  • Potential for regressions. System updates and graphics driver patches sometimes break DDC behavior; while a Microsoft module reduces fragmentation, it can’t eliminate driver‑level breakage.
  • Enterprise endpoints may still standardize on vendor solutions for advanced features. If your organization uses vendor management suites (for display firmware, service and warranty), those tools may remain necessary for deeper features like factory presets and firmware updates.
Be especially cautious with color‑critical workflows: adjusting brightness and color temperature via software can invalidate precise color profiles, so always test and, for professional work, re‑calibrate using instrumentation after any major change.
Practical steps for readers who want to be ready​
  • Check whether your monitor supports DDC/CI: open the OSD and look for a DDC/Ci or “Enable external control” option. If present, enable it.
  • Prefer direct connections: connect displays via DisplayPort or HDMI directly to the GPU rather than through low‑end hubs. If you use a dock, verify whether it forwards DDC/CI.
  • Try Twinkle Tray or Monitorian now to confirm your monitor’s VCP support; these are the same mechanisms PowerToys will likely use, so they’re a good compatibility test.
  • If you manage devices in an organization, plan how you’ll vet the PowerToys module: test on representative hardware, confirm Group Policy controls, and document fallback procedures for devices that don’t expose DDC/CI.
  • If you need cross‑platform features or smart‑monitor networking, evaluate DisplayBuddy’s trial to see whether its extra features justify the cost in your environment; expect the price and store availability to vary.
Verification and the current status of the feature​
At the time of writing, the monitor utility had been reported publicly through a screenshot and a proposed GitHub change request, but Microsoft has not shipped the module to the stable channel or documented a ship date. The proposal — referred to by some community threads as “Power Monitor” — shows UI mockups and early diffs indicating support for brightness, contrast, volume and color temperature controls, but the repository discussion and any pull request should be considered the authoritative source for implementation details and availability. Independent reporting also shows Microsoft iterating PowerToys with utilities such as Light Switch and experimental webcam/lighting overlays, which reinforces the idea that PowerToys is being used to trial hardware-adjacent features before broader OS integration. A note on specifics and unverifiable claims: exact labels, keyboard shortcuts, supported VCP codes, and the final name of the module (Power Monitor versus another label) remain subject to change until a stable release is published. Some community stories reference a particular developer’s social post showing the screenshot; however, if you need to rely on the details for deployment planning, verify against the live PowerToys GitHub repository and the official PowerToys release notes when the module appears. If the GitHub pull request is still in draft or discussion form, expect additional changes before merge and release.
Final analysis: why this is good — and where to be careful​
A PowerToys monitor utility is a sensible, low‑risk evolution for Microsoft’s power‑user toolkit. It addresses a longstanding UX gap: Windows lacks a simple, first‑party multi‑monitor control surface that covers brightness, contrast and basic VCP features. Putting monitor sliders inside PowerToys would:
  • Reduce friction for everyday users who adjust brightness frequently.
  • Standardize an experience across disparate hardware.
  • Give IT teams a manageable, first‑party deployment path.
However, expectations should be tempered. The underlying hardware and cabling limitations that plague third‑party tools will remain. The module will likely offer great convenience for many setups, but it is not a silver bullet for all multi‑monitor pain points.
For now, users who need these capabilities should test with Twinkle Tray or Monitorian to confirm their monitors respond to VCP commands, keep firmware and graphics drivers updated, and watch the PowerToys GitHub releases and release notes for the first public preview of the module. If you manage many different monitor vendors centrally, pilot testing on representative hardware will remain essential before broad rollout.
PowerToys’ monitor control plan is an overdue convenience feature that fits the project’s history of practical, no‑nonsense tools. When Microsoft releases an official module, it will likely simplify life for many Windows users — but whether it becomes a universal solution depends entirely on the messy reality of DDC/CI, vendor implementations and the variety of docking hardware that enterprises and pros use every day. Until then, Twinkle Tray, Monitorian and DisplayBuddy remain viable stopgaps while PowerToys’ module matures and ships.
  1. PowerToys is getting a new monitor utility for Windows 11 and 10 Neowin
