What the chip actually is
The 495, codenamed Gorgon Halo, is a refresh of Strix Halo, not a new architecture. AMD's top SKU has 16 Zen 5 cores, 32 threads, 80MB of cache and 40 RDNA 3.5 compute units. VideoCardz reported earlier that the Radeon 8065S update applies only to the Max+ PRO 495, not to the other PRO 400 parts.
The changes are modest:
- GPU clock: The iGPU gets a 100 MHz higher clock, making it the first Halo part at 3.0 GHz. That fits VideoCardz's 3.0 GHz versus 2.9 GHz comparison with the 8060S. One caveat: one third-party spec roundup lists the older GPU's frequency differently, so treat the exact clock delta as approximate.
- CPU boost: up to 5.2 GHz.
- Memory: Memory moves from LPDDR5X-8000 to LPDDR5X-8533, while the GPU keeps 40 compute units. AMD's Halo developer platform page lists 192GB of LPDDR5x at 8533MT/s with 273GB/s of bandwidth.
- Power range: third-party spec summaries list a 45W to 120W configurable power range. Real systems sit at different points in that range, and the FEVM reportedly runs above it for short periods (see below).
The 160GB "VRAM" figure
The headline number is up to 160GB allocated to the GPU. That is shared system memory, not a dedicated pool like on a discrete card. Vendor listings such as ACEMAGIC's F9A describe UMA graphics with up to 160GB of shared memory. It matters for large local AI models. It does nothing for frame rates in games, and no tested game came close to needing it.
FEVM FAEX2 results (1080p)
VideoCardz says the Chinese reviewer's FEVM FAEX2 is a 1-liter mini PC that can hold 160W for up to 18 minutes. Reported averages:
| Game (1080p) | Radeon 8065S | Radeon 8060S | RTX 5060 system |
| Forza Horizon 5, Ultra, no FSR | 133 FPS | 125 FPS | 142 FPS |
| Cyberpunk 2077, High | 104 FPS | 90 FPS | 109 FPS |
| Shadow of the Tomb Raider | 151 FPS | 107 FPS | not reported |
| Black Myth: Wukong, highest preset | 79 FPS | 72 FPS | not reported |
The gains range from about 6% in Forza Horizon 5 to about 41% in Shadow of the Tomb Raider. The spread is far wider than a 100 MHz clock bump could explain, which points to other factors at work.
The RTX 5060 comparison is interesting but should not be over-read. In two games the integrated GPU lands within a few frames of a discrete card. That is a single-reviewer sample at a power budget most laptops will never see.
GMKtec EVO-X5 Pro results (1440p)
ETA PRIME used a sustained 120W limit. Reported results:
- Cyberpunk 2077, 1440p Ultra, FSR 4.1 upscaling: about 69 FPS.
- Red Dead Redemption 2, a mix of Ultra and High, no FSR: about 87 FPS.
- Forza Horizon 6 at 1440p Ultra without upscaling was demonstrated, but VideoCardz gives no frame rate.
- Crimson Desert reached mid-90s FPS at 1440p Ultra only with FSR Multi Frame Generation. That is a generated-frame figure, not native rendering.
Synthetic benchmarks
- FEVM FAEX2: 12,139 in 3DMark Time Spy, about 3.4% ahead of the older FAEX1 with the Ryzen AI Max+ 395.
- GMKtec EVO-X5 Pro vs EVO-X2 at a matched 120W: 11,743 vs 10,499 in Time Spy, up 11.8%. The graphics score rose 11.3%.
- Geekbench 7 CPU on the same pair: up 9.3% single-core and 12.1% multi-core.
The 3.4% and 11.8% figures are the most useful pair. Both come from the same vendor's old and new machines, but they differ by a factor of three. That again suggests chassis, cooling and tuning matter as much as the silicon.
How much to trust the numbers
VideoCardz itself cautions that the gains could come from better cooling, faster memory or newer drivers. It also notes that reviewers often don't retest older hardware on current drivers. There is a further problem: the CPU also improved by 9–12% in the matched-power test, so some of the graphics gain could be a platform-wide effect, not a GPU-only one.
My read, based on general industry experience rather than any new testing:
- Expect a single-digit to low-double-digit percentage uplift at equal power and cooling. The 3.4% and 11.8% Time Spy results bracket that.
- Treat the 41% Tomb Raider figure as an outlier until it is reproduced.
- Take the FEVM's 160W figure with care. A burst of up to 18 minutes is not the same as sustained output.
- Native-resolution results and upscaled or frame-generated results should never be mixed in one comparison.
Price and who it's for
VideoCardz asks whether the platform is worth $7,000 for gaming. The evidence I have does not establish a current price for the tested FAEX2 or EVO-X5 Pro configurations, so I won't repeat that figure as fact. The framing is still fair. Most of what the 192GB configurations cost pays for memory capacity that matters for local AI work. Framework, for example, pitches its 192GB Desktop on running much larger models locally. Gamers looking at Halo-class mini PCs should check whether a lower-memory configuration is available.
Also note that the "PRO" in the name matters to IT buyers. Notebookcheck says as a PRO CPU, the 495 offers support for management and additional security features. That is useful in managed Windows fleets, whatever the frame rates are.
Bottom line
The Radeon 8065S appears to be a real but modest step over the 8060S, with large variation between systems. Wait for more reviews with matched power limits, matched drivers and native-resolution testing before treating any single percentage as the 8065S's true uplift.
- First AMD Ryzen AI Max+ PRO 495 gaming reviews show Radeon 8065S gains over 8060S - VideoCardz.com VideoCardz.com · 2026-10-10T17:57:37+00:00
- AMD Ryzen AI MAX PRO 400 launches in third quarter, only MAX+ 495 gets updated Radeon 8065S graphics - VideoCardz.com videocardz.com
- ACEMAGIC F9A AMD Ryzen AI MAX+ PRO 495 acemagic.com
