What Razer Launched
Razer announced licensed headsets with Charizard, Lucario and Sylveon designs, developed with The Pokémon Company International. The lineup is the BlackShark V3 X HyperSpeed in Charizard and Lucario editions, plus a Kraken V4 X Sylveon Edition. Razer's newsroom post is dated October 13, 2026. It ties the launch to Pokémon's 30th anniversary.
The Charizard model pairs Razer TriForce 50 mm Gen-2 drivers with HyperSpeed Wireless. Razer says HyperSpeed is a low-latency 2.4 GHz connection. The headset also supports Bluetooth and a wired USB-C connection.
Price: The $20 "Charizard Tax"
Razer's U.S. product page listed the Charizard Edition at US$119.99. The standard BlackShark V3 X HyperSpeed page listed US$99.99. That matches the review's description of a $20 premium. The Outer Haven's review also reports that Target's website priced the Pokémon editions higher, at $139.99. Prices and retailer availability change, so check before buying.
The review stresses that the themed edition is cosmetic and uses the same hardware as the standard model. Whether $20 is worth it comes down to how much you like Charizard.
What the Reviewer Found
These are the reviewer's observations. They are not lab measurements.
- Connectivity: The reviewer tried a Windows 10 gaming PC, two Macs, a PS5 and a Nintendo Switch 2. The headset connected on all of them, and the 2.4 GHz adapter was the easiest route.
- Audio: Sound was good for the category with no configuration. Passive noise isolation from the memory-foam cups was decent but not close to premium noise-cancelling headphones.
- Microphone: The mic was clear but a little flat. It handled an hour-long Discord call from a PS5, though loud background noise can still get through. A sidetone dial lets you hear yourself, which the reviewer did not like.
- Comfort: The reviewer found it more comfortable than a five-year-old Logitech Pro X for hours of calls. Razer lists the weight as 270 g, which supports the "light" impression.
- Dual connection: The reviewer connected a phone over Bluetooth and a computer through the adapter at the same time. That allowed phone-call alerts while game audio played. This is one user's result, not a promise for every setup.
Battery Life
Razer rates the battery at up to 70 hours over 2.4 GHz wireless. The reviewer says their experience bore that out and that they recharged the unit only once. That is not a standardized endurance test. The comparison with the Logitech Pro X's 20-hour rating is a rated-versus-rated comparison. It is not a head-to-head test.
Vice's separate review also says battery life was no issue for how they used it. Two reviewers reporting the same thing makes the battery claim more credible, though still not lab-verified.
The Software Catches
Synapse and 7.1 surround on Windows
Basic use needs no software. The Windows version of Razer Synapse gave the reviewer custom adjustments and presets. However, the advertised 7.1 surround sound, which requires registering the device with a Razer account, never worked for them. Razer's product page says 7.1 is only available on Windows 10 64-bit or higher, which is worth checking if you rely on that feature. The reviewer's PC met that OS requirement, so the cause is unknown. The reviewer also noted that Synapse is a heavy application that takes time to set up.
Practical tips for Windows users:
- Confirm you are on 64-bit Windows 10 or newer.
- Register the headset to your Razer account in Synapse.
- Treat 7.1 as optional. The reviewer found the base Synapse features sufficient for most games.
Macs and mobile
The reviewer says Synapse does not support this headset on Macs, even though Mac support is advertised for Synapse in general. The headset still worked natively there. The Razer Audio mobile app did not support this edition during the review, but the reviewer says it has since been updated. Bluetooth worked as a fallback.
Xbox
Vice reports it could not get the headset to connect to an Xbox, even with the provided dongle, and says Xbox is not on Razer's compatibility list. Razer's store page does sell Xbox-and-PC and PlayStation-and-PC platform options for an extra $20. If you are buying for Xbox, confirm the exact platform variant before you order.
Durability and Omissions
The reviewer is wary of the sliding plastic-and-metal cup adjustment. A single braided cable also runs between each cup and the band. Nothing failed during testing, so this is a concern, not a demonstrated defect. No carrying case is included, which the reviewer calls a noticeable omission for a premium-priced headset that is marketed for mobile use.
Verdict
The reviewer's conclusion is that the headset is worth the splurge for Pokémon fans. That is an opinion, not a finding that it beats every competitor at this price. The Outer Haven calls it a good headset first and a Pokémon collectible second.
- Good fit: You want long battery life, light weight and decent calls on a Windows PC or console, and you like the design.
- Think twice: You need Synapse features on a Mac, you want to use it on Xbox, or you only want the standard headset and would rather save $20.
- Razer’s BlackShark V3 X HyperSpeed Charizard Edition Wireless Headset Is Actually Fire - But Why Tho? But Why Tho? · 2026-11-11T03:12:06+00:00
- Buy Razer BlackShark V3 X HyperSpeed - Charizard Edition razer.com
- Razer BlackShark V3 X HyperSpeed Charizard Edition Review (2026) vice.com
