A black gaming controller with green accents is shown with a USB dongle, gaming setup, and close-up stick details.
Razer's Wolverine V4 Pro is a $199.99 wireless controller for Xbox and PC. It is built around one idea: PC players get the full benefit, and Xbox players get a very good pad with a capped feature. Windows Central's Daniel Rubino calls it an excellent all-rounder, and his main complaints are the missing charging dock and the missing Bluetooth. Razer's own documentation corrects one detail in the review, which is what the sticks are made of.
A black gaming controller with green accents is shown with a USB dongle, gaming setup, and close-up stick details. What Windows Central found​
Rubino has used the V3 Pro as his main PC controller for some time. He says he now prefers it to his Xbox Elite Series 2, which developed stick drift. He describes the V4 Pro as a refinement of the V3 rather than a reinvention. Here are his main points:
  • Ergonomics and controls: He rates the ergonomics highly. The controller has four removable back buttons and two claw-grip bumpers, which makes six extra inputs. The back buttons can now be removed individually, so you can run two instead of four.
  • Buttons: The face buttons and D-pad keep their "clicky" feel. He likes it, but he notes it divides opinion.
  • Triggers: Trigger locks switch between a short, fast pull for shooters and full-range travel for racing games.
  • Wireless reliability: He says the V4 fixes the signal-interference problems he saw on the V3. He reports no disconnects or degradation in his radio-heavy office. That is one reviewer's experience, not a lab result.
  • Software: He calls Razer's PC software among the best for third-party accessories. He warns that macros can trigger automation detection and get you banned in some competitive shooters.
  • Battery: Razer claims up to 27 hours. Rubino estimates about 20 to 24 hours in his Xbox use. That is an informal estimate, not a standardized test.
The sticks are capacitive, not TMR​
The review repeatedly calls the thumbsticks TMR. Razer's launch announcement says otherwise. It describes new high-resolution capacitive sensors, which it calls the next step in contactless design after TMR and Hall Effect. Razer describes them as the next step beyond TMR (tunnelling magnetoresistance) and Hall Effect designs. Coverage of the launch also says the V4 replaces the V3 generation's TMR thumbsticks with new capacitive sensors.
Razer says the sensors are paired with a 16-bit ADC and register about 3,000 steps of movement. It says they resist magnetic interference better than TMR or Hall Effect designs. Razer measured the 3,000-step figure at 8,000 Hz on PC using the HyperSpeed Wireless dongle. Treat "drift-free" as marketing language. The real test is how the sticks hold up over months of use.
Razer's support FAQ adds a practical warning. The controller supports a true 0% dead zone, with no filtering at all. In the Synapse testing tool, tiny movements or micro-tremors can show up at that setting. Razer says this reflects the sensor's sensitivity and is not stick drift. If you see jitter, raise the dead zone, which adjusts from 0% to 15%, before you decide the controller is faulty.
8,000 Hz on PC, 250 Hz on Xbox​
The polling split is the most important spec to understand.
  • PC: Razer says polling reaches up to 8,000 Hz, wired or wireless. The company claims this is up to 32 times more frequent positional reporting than standard controllers.
  • Xbox Series X|S: Polling tops out at up to 250 Hz.
  • Setting the rate on PC: An Amazon listing says that on a compatible Windows 11 PC with the HyperSpeed dongle, you use Razer Synapse 4 to change the polling rate from 250 Hz, 1000 Hz, 2000 Hz, 4000 Hz or 8000 Hz.
Rubino attributes the Xbox ceiling to Microsoft's Xbox Wireless signal. Razer confirms the two rates but does not give that reason in its announcement. Also, 8,000 Hz is a maximum. Whether you can feel it depends on the game, your hardware and your own sensitivity. Rubino himself says he would swap the 8K polling for something else on a typical consumer controller.
Customization at a glance​
FeatureRazer's listed spec
Extra inputs4 magnetic back buttons plus 2 claw-grip bumpers
TriggersPro HyperTriggers, actuation from 1.3 mm to 8.2 mm via Synapse
Profiles4 onboard
Dead zone0% to 15%
Stick caps6 total: short concave, short convex, tall concave
FaceplateRemovable magnetic
ChargingUSB-C, about 3 hours for a full charge
WarrantyUp to 1 year
Razer says buying directly from RazerStore comes with 14-day risk-free returns. Terms may vary by region.
The trade-offs​
Rubino's complaints are about convenience:
  • No charging dock. Similarly priced rivals offer one, and he says he did not want to hunt for a cable mid-match.
  • No Bluetooth. The pad works with Xbox and Windows PCs only, so it is not a mobile-friendly second controller.
  • Dongle swapping. Moving between platforms means physically moving the dongle. The review notes that the SteelSeries Aeon Pro switches between two platforms at once.
  • Smaller gripes. The USB-C port on top juts out, and he found the sound-based haptics inconsistent. He also hasn't found third-party faceplates yet, but that is only a snapshot of review time.
How it compares​
Rubino's comparisons come from his review, and I haven't verified the current prices. He says the 8BitDo Ultimate 3E costs $70 less and includes a dock, Bluetooth and TMR sticks. It also polls at up to 1,000 Hz on PC. He puts the SteelSeries Aeon Pro $50 above the Razer, with a dock and dual-platform switching. He still advises most people to avoid the Elite Series 2 because of stick and build-quality degradation, though he praises its dock.
He also mentions a rumored Xbox Elite Series 3. That is speculation in the review. There is no confirmed release, so it shouldn't drive a purchase decision on its own.
Who should buy it​
Good fit:
  • Competitive PC players who want the highest polling ceiling available.
  • Anyone who wants lots of mappable inputs, adjustable triggers and contactless sticks in a wireless pad.
  • Players who are fine with a dongle and a charging cable.
Look elsewhere if:
  • You want Bluetooth, a dock, or easy switching between devices.
  • You mainly play on Xbox, where the 250 Hz cap removes the headline advantage.
  • Value matters more than competitive extras.
Bottom line​
Rubino's verdict is that the V4 Pro does the fundamentals better than most rivals, though most buyers would want more convenience features at this price. Razer's documentation adds two points to that: the sticks are capacitive rather than TMR, and the 8,000 Hz headline applies only on PC. If you play competitively on a Windows machine, it is a strong choice. If you want a dock, Bluetooth or a lower price, consider the alternatives above.
Update: Additional details (November 9, 2026)​
Basic Tutorials lists the Wolverine V4 Pro’s weight as 305 grams and its dimensions as 156.7 × 105.7 × 65 mm. The review also lists Xbox One compatibility and says the package includes magnetic blank covers for unused rear-paddle slots, but no hard case.
According to the review, Razer Synapse includes an SOCD setting for choosing how the controller handles simultaneous opposite-direction inputs.
  1. Razer Wolverine V4 Pro controller review (Xbox, PC): Powerful, versatile, comfortable. It's an all-round standard-bearer. - Windows Central Windows Central 2026-10-27T11:00:00+00:00
  2. Razer Wolverine V4 Pro Review: The New Benchmark for Pro Controllers? - Basic Tutorials Basic Tutorials 2026-11-09T09:00:13+00:00
  3. Razer Wolverine V4 Pro Wireless Xbox Series X|S & PC Controller amazon.com
