The test rig and method
Gizbot tested the game on an RTX 5070 at 4K, using the Ultra and Medium presets with DLSS and Frame Generation. The machine is a high-end Windows 11 desktop:
- Intel Core Ultra 9 285K
- GeForce RTX 5070
- MSI Z890 motherboard
- 48GB of DDR5-6000
- WD Black SN850X 2TB SSD
- Acer Nitro XV275K P5 monitor
DLSS was on for all four runs. The reviewer recorded average FPS, 1% lows, GPU and CPU utilization, and temperatures.
The review leaves out several details:
- the DLSS quality mode
- the game and driver versions
- the test scene and its length
- how the FPS figures were captured
That makes it one person's result on one PC, not a reproducible benchmark.
The numbers
| Preset | DLSS | Frame Generation | Avg FPS | 1% low |
| Ultra | On | Off | 93 | 78 |
| Ultra | On | 2x (auto) | 138 | 79 |
| Medium | On | Off | 104 | 79 |
| Medium | On | 3x (auto) | 153 | 79 |
Other readings from the review:
- Ultra, no Frame Generation: GPU utilization was 99% at 80°C. The CPU sat at 11% and 53°C.
- Ultra with 2x: GPU use was 96% and the temperature stayed at 80°C. The CPU readings were unchanged.
- Medium, no Frame Generation: GPU use was 99% at 82°C. The CPU rose to 14% and 54°C.
- Medium with 3x: GPU use was 83% at 75°C. The CPU was at 9% and 54°C.
What stands out
Presets barely matter here. Without Frame Generation, the difference between the presets was only 11 FPS. That is roughly 12%. The GPU stayed pinned at 99% on both presets, which suggests the heavy workload isn't tied to what the Medium preset turns down. The reviewer therefore recommends staying on Ultra. That advice applies to this card, this resolution and this DLSS setup, and shouldn't be assumed for other hardware.
The 1% lows are flat. All four runs landed between 78 and 79 FPS, even though averages ran from 93 to 153. Frame Generation lifted the displayed average but not the worst-case frames, at least by this measurement.
The Frame Generation comparison isn't like-for-like. The game picked 2x for Ultra and 3x for Medium, so the 15 FPS gap between those two runs mixes the preset change with a different multiplier.
Generated frames aren't responsiveness. The reviewer notes they don't improve input feel the way a higher rendered frame rate does. The review reports no latency measurements, so it can't say how the game feels.
The Frame Generation menu
The reviewer reports the menu offers only "Multi Frames" and "Dynamic." The multiplier appeared to be chosen automatically, and there was no 6x option. Other sources paint a mixed picture:
- ComputerBase tested the review build and says the game supports Multi Frame Generation up to 6x. It found the automatic mode poor on frame pacing and latency, and said the Dynamic option appeared to do nothing. That differs from Gizbot's 2x/3x observations. Neither source explains the discrepancy, and build, settings or test method could all play a part.
- Players on the Steam forums have complained about having no manual multiplier. One reply suggested using the NVIDIA app to set a fixed multiplier. Another user described the steps in the NVIDIA app's profile settings: set the DLSS-FG forced mode to Fixed, set the fixed count to 2x, then apply. That is a community workaround, not official documentation, and I haven't verified it. If you try it, treat it as experimental.
- One commenter recommended turning off in-game frame generation and using "Smooth Motion" in NVIDIA's settings instead, because of artifacts with V-Sync on. That is also one user's report.
Independent testing for context
ComputerBase's results aren't directly comparable. It used a Ryzen 7 9800X3D, a defined 20-second test scene, and DLSS 4 Quality at a 67% render resolution. It reported an RTX 5070 averaging 58.2 FPS at 3840×2160, with a 51.5 FPS 1% low. Gizbot's 93 FPS average with a 78 FPS 1% low is considerably higher, but the DLSS mode, scene and game build differ, so the numbers don't contradict each other. Both show how much a single run depends on scene and settings.
ComputerBase also made several points that matter for Frame Generation:
- It says a rendered frame rate of roughly 50 to 60 FPS is needed for a good feel with Frame Generation.
- It found CPU limits in some areas with many NPCs.
- It reported occasional short traversal hitches during level streaming.
- It found the game's VRAM needs modest, with 8GB recommended for maximum detail.
DSOGaming used a different area and a different rig (a Ryzen 9 7950X3D with Radeon and RTX cards, on Windows 10). It found the game ran well on a wide range of GPUs, even at native 4K. Its verdict was that the game runs extremely well on a wide range of GPUs. It reported no major stuttering, which contrasts with ComputerBase's streaming hitches.
Settings and usability
Gizbot's review says the graphics menu offers Ultra, High, Medium and Low presets. It also exposes draw distance, shadow maps, physics, NPC and enemy refresh rates, and chromatic aberration. Two annoyances stood out for the reviewer:
- There's no in-game VRAM indicator.
- Changing the preset requires restarting the game.
ComputerBase's menu breakdown also lists no VRAM readout, FPS counter or built-in benchmark. If you want to compare your own system, you'll need an external monitoring tool and a repeatable route.
Practical takeaways
- Don't expect much from preset drops. If you're GPU-bound at 4K, individual settings or the upscaler mode are more likely to help than moving from Ultra to Medium. That is an inference from this test, not a proven result.
- Check your base frame rate before enabling Frame Generation. Gizbot's 93 FPS Ultra baseline is comfortable. A weaker card won't get the same benefit.
- Watch the multiplier. If the game is choosing 3x or higher and the feel is off, a fixed multiplier through the NVIDIA app is worth testing. RTX 40-series cards are limited to 2x.
- Judge by 1% lows, not just averages. The flat lows in this review show why.
The bottom line
On a high-end Windows 11 PC, the RTX 5070 handles Resonance at 4K with DLSS comfortably. The less obvious finding is how little the preset matters and how opaque the Frame Generation behavior is. One reviewer's four runs can't settle either question. ComputerBase's results, and the discrepancies over multiplier behavior, suggest your own results will depend heavily on scene, build and settings.
- Resonance: A Plague Tale Legacy PC Performance Review - Gizbot Gizbot · 2026-10-31T08:42:23+00:00
- Resonance: A Plague Tale Legacy im Benchmark-Test: Benchmarks (WQHD, UWQHD & UHD), Frametimes und VRAM - ComputerBase computerbase.de
- Resonance: A Plague Tale Legacy im Benchmark-Test - ComputerBase computerbase.de
