What the author actually did
Singh's central claim is modest. Software gates can sometimes be bypassed on older hardware. That doesn't turn an RTX 4070 Ti into a Blackwell card. He says so himself: the card still has 12 GB of VRAM, the same CUDA and Tensor cores, and the same architecture it shipped with.
The numbers below are his, from a single system. The reporting gives no test methodology, repeated runs, base frame rates or frame-time data. Treat them as anecdotes, not expectations.
Multi Frame Generation on an RTX 40 card
Officially, Nvidia's lineup is staggered. Per Nvidia's DLSS 4.5 announcement, DLSS Frame Generation introduced a 2X multiplier, and DLSS 4 Multi Frame Generation raised the maximum to 4X on GeForce RTX 50 Series GPUs. The 6X mode then arrived for RTX 50 cards. Nvidia describes 6X as generating five additional frames for every natively rendered frame.
Singh says OptiScaler, plus the appropriate DLSS DLLs, got MFG running on his card.
- Game and settings: The Blood of Dawnwalker at 4K High.
- Reported result: 96 fps with 2x Frame Generation, and 160 fps with 4x.
- Image quality: he calls it clear and crisp, though he offers no side-by-side comparison.
- Limit: he couldn't test 5x or 6x because the 12 GB card ran out of VRAM.
- Preferred setting: 3x, which he calls the sweet spot.
A public OptiScaler fork documents a similar RTX 40 unlock. Its author reports a test on an RTX 4070 Ti in Crimson Desert, with about 240 fps from roughly 60 rendered frames at 6x. That is a self-reported result from the tool's developer, not independent validation.
The fork's setup is specific to that project, so don't assume it applies to every OptiScaler build. Its documentation describes these steps:
- Install OptiScaler.
- Keep the game's
nvngx_dlssg.dll(version 310.x) next to the executable. - Set
[MfgUnlock] Enabled=trueinOptiScaler.ini. - Enable the game's own DLSS Frame Generation and restart.
- Pick a multiplier in-game, or set
ForceMultiplier. - Leave OptiScaler's separate
[FrameGen]feature off, because the game's DLSS-G is doing the work.
The same documentation warns that the unlock modifies Nvidia code inside the game process. It says not to use it in multiplayer titles, which is sensible given anti-cheat. It also warns that higher multipliers can raise latency and cause artifacts.
That last point matters. Output fps is not the same as render fps. A 6x display rate built on a 60 fps base still carries the input feel of 60 fps.
DLSS 5 on a 4070 Ti
Nvidia unveiled DLSS 5 in March 2026 as a real-time neural rendering model. Nvidia's research page says it runs locally as a rendering stage on GeForce RTX 50 Series GPUs. It is fed the rendered frame, motion vectors, temporal state and artistic-direction values.
Singh says OptiScaler, ReShade and neural-rendering components injected it into games that don't officially support it. He also mentions one-click tools such as DLSS 5 Swapper and DLSS 5 Manager. He used it with the PCSX2 and RPCS3 emulators too.
His performance claims are modest but unverified. The cost is steep even on flagship hardware. He says the RTX 5090 loses roughly half its frame rate with DLSS 5 on, and his 4070 Ti took a bigger hit. He got playable results by combining Smooth Motion with a changed position for the neural renderer in the pipeline. No game-by-game data is provided.
Nvidia's own position has shifted. Spokesperson Rajal Maharaj told The Verge that RTX 40 support is coming. The current focus is RTX 50 optimization, with model updates expected this fall. No exact date is confirmed for RTX 40 support. Outlets also report that DLSS 5 launched with a single title. That title is NBA 2K27, alongside Game Ready Driver 616.64 WHQL.
One reported detail suggests the gate isn't purely hardware. One outlet says the DLSS 5 model runs on FP8, which RTX 40 and RTX 50 both have. I'd treat that as secondhand. It fits the pattern, though. It also doesn't settle whether Ada can match Blackwell's performance.
Gameluster is blunt about the unofficial route: modded RTX 40 and 30-series DLSS 5 efforts remain experimental and don't reflect Nvidia's eventual support, safety or performance. That seems fair. Injecting a generative renderer into an emulator is a hobbyist experiment. It is not a supported configuration.
Reflex 2 and Frame Warp
Reflex 2 works differently from frame generation. Frame Warp takes an already rendered frame and shifts it using the latest input data. It doesn't create a new frame. Nvidia tied it to RTX 50 at announcement and said other GeForce RTX GPUs would follow. As of Singh's October 2026 writing, RTX 40 support is still pending.
Singh says modders have run parts of it on older RTX GPUs. He acknowledges this isn't identical to native support. I found no implementation documentation or reproducible test, so this is the weakest of the three claims. Don't confuse it with standard Reflex Low Latency, which synchronizes CPU and GPU work. Frame Warp is a separate technique.
What this means for GPU buyers
Hardware sets the ceiling, and software sets which parts of it Nvidia lets you reach. Three layers decide feature availability:
- Hardware capability: what the silicon can physically do.
- Official driver and game support: what Nvidia enables and validates.
- Community software: what modders can route around a gate.
The caveats are real:
- VRAM: Singh found his 12 GB card was the limit for higher multipliers.
- Latency: generated frames don't make a game respond like native frames.
- Stability and safety: unofficial injection can break games, and the MFG fork warns against multiplayer use.
- Nvidia's own tuning: Nvidia says DLSS 5 performance still needs work on RTX 50, so unofficial results on older cards are early.
There's also a fair counterargument for Nvidia. Gating a feature can mean the vendor hasn't validated the experience yet. It doesn't always mean the hardware can't do it. Frame-generation quality, pacing and latency are hard to get right.
Singh says he deleted an RTX 5070 Ti from his shopping cart after getting MFG working. That's his call. A tweaked 4070 Ti with a modest 3x multiplier is not a 5070 Ti, and nothing here shows equivalent latency or image quality. If you're considering this route, expect hobbyist-grade setup and no official support. Keep it to single-player games, and watch for Nvidia's official RTX 40 DLSS 5 rollout.
- I unlocked RTX 50-series features on my RTX 4070 Ti, and Nvidia's GPU generations don't make sense anymore XDA · 2026-10-02T11:00:17+00:00
- NVIDIA Home nvidia.com
- DLSS 5 Support for RTX 40 GPUs: What We Know gameluster.com
