A laptop displays battery performance and health statistics while plugged in on a desk.
A laptop that feels slow isn't necessarily failing. How-To Geek's Monica J. White argues that the cause is often power policy, a charger problem or, less often, the battery itself. The Microsoft and Dell documentation backs up much of that advice, with some model-specific caveats. Here is a diagnostic order that changes one variable at a time, so a settings problem doesn't get mistaken for a hardware fault.
A laptop displays battery performance and health statistics while plugged in on a desk. Step 1: Compare plugged in and on battery​
Start by running the same task in both states. Many laptops deliberately lower CPU and GPU power limits on battery. That can mean lower clock speeds and slower performance, and it is usually normal. Gaming laptops are the extreme case, because they typically expect to stay plugged in.
Treat the result as a clue:
  • Fast on AC, slow on battery: this is probably the normal power trade-off or an adjustable setting.
  • Slow in both states: look elsewhere, such as the power mode, the charger, thermals, background load, or the battery on models that depend on it.
Step 2: Check the Windows power mode​
Microsoft documents the power-mode setting for Windows 11 and Windows 10. In Windows 11, open Settings › System › Power & battery. Under Power mode, Microsoft's support page lists three options: Best power efficiency saves battery life, Balanced balances performance and battery use, and Best performance maximizes performance.
On many systems, there are two dropdowns, one for when the PC is plugged in and one for when it is on battery. That makes it easy to run the same workload under different modes.
Some points worth knowing:
  • Microsoft says Best power efficiency can reduce background activity both on battery and plugged in. A laptop on AC can therefore still be held back if that mode is selected for the plugged-in state.
  • If you can't change the mode, Microsoft says a custom power plan may be selected. Its suggested fix is to open Control Panel > System and Security > Power Options and select Balanced.
  • On Windows 10, the feature isn't available on every PC. It depends on the hardware and the manufacturer, and it requires version 1703 or later. Microsoft's page also notes that Windows 10 support ended on October 14, 2025.
  • Best performance isn't free. One guide notes it comes at the cost of heat, fan noise and battery life. Treat it as a test, or as a plugged-in setting for demanding work. It isn't a universal fix.
  • Pick settings by workload. One guide suggests switching to Best performance while plugged in, running a repeatable test, and deciding whether the measurable gain is worth the extra power and heat.
Energy saver is a separate feature. Microsoft says it activates when the battery is low, dims the screen and limits background processes. If a laptop gets sluggish only when its charge is low, Energy saver is a prime suspect. Some manufacturers also ship their own performance-profile utilities, and those can restrict hardware independently of Windows.
Step 3: Check the charger and connection​
A "plugged in" icon doesn't prove the laptop is getting enough power. The How-To Geek piece names three possible culprits: an underpowered USB-C charger, a third-party adapter, and a cheap docking station.
A practical check:
  1. Find the wattage your laptop's manufacturer specifies for its adapter.
  2. Compare it with the rating printed on your charger.
  3. Inspect the adapter and cables for damage.
  4. If you're using an aftermarket adapter, try the original or manufacturer-recommended one.
Not every third-party or USB-C charger is inadequate. The point is to verify against your model's requirements instead of assuming. A charger swap is usually cheaper than a battery replacement.
Step 4: Check whether your model uses its battery to boost performance​
Some laptops draw on the battery to supplement the charger under heavy load. Dell's Hybrid Power is the example How-To Geek cites. Dell's documentation for the Alienware m15 R2 says the feature coordinates power from the adapter and battery during heavy loads. These include graphics- and processor-intensive applications and gaming.
  • Battery draw: the m15 R2 manual says the battery can supply power at up to five percent per hour while the adapter is connected.
  • Low-charge cutoff: the feature is disabled below 20 percent charge. Below that level, the computer may throttle and show performance problems under heavy load.
  • Charging behavior: at 100 percent charge with the adapter connected, the battery stops charging. Under heavy load it is allowed to discharge to maintain performance, and it resumes charging when the load eases.
This behavior is model-specific. Another Dell guide, for the G7 15, reportedly uses a different threshold (10 percent). I couldn't verify that document myself, so treat the exact figure with caution. Don't read 10 or 20 percent as a general rule.
This feature explains why a low or degraded battery can matter even on AC for some gaming laptops. It does not show that a worn battery slows laptops in general. As the original article concedes, not every laptop uses this kind of system, and an aging battery doesn't automatically mean worse performance. Check your model's manual or the manufacturer's support page.
Step 5: Generate a Windows battery report​
Windows has a built-in tool. Microsoft's powercfg documentation says powercfg /batteryreport generates a report of battery usage characteristics over the lifetime of the system. It writes an HTML file to the current path.
To use it:
  1. Open Command Prompt or Windows Terminal.
  2. Run powercfg /batteryreport.
  3. Open the HTML file it creates in a browser.
  4. Compare Design Capacity with Full Charge Capacity.
You can also choose where the file goes with powercfg /batteryreport /output "batteryreport.html". The command also takes a /duration argument that sets how many days the report covers.
The report has limits:
  • A large gap between design capacity and full-charge capacity means the battery holds less than it once did. That is useful for judging runtime and replacement.
  • It doesn't measure CPU or GPU performance, and it can't prove the battery is why your laptop is slow.
  • No threshold in the sources I reviewed says when a battery must be replaced, so I won't invent one.
Microsoft's Windows 11 power documentation also notes that lithium-ion batteries age with charge cycles. That reduces how long a charge lasts. It doesn't, by itself, say anything about speed.
Step 6: Escalate to the manufacturer​
If the slowdown persists after you've checked the power mode, Energy saver, the charger and the battery report, contact the manufacturer. That applies especially if the laptop is still under warranty. Vendor support can check firmware, BIOS settings, thermal behavior and any battery-assisted power design that Windows settings can't reveal.
Bottom line​
The useful lesson isn't "your battery is probably dying." It's that laptop performance depends on the power state, and several fixes are free:
  • A slowdown on battery is often by design.
  • A restrictive power mode or Energy saver can hold performance back.
  • An inadequate charger can quietly limit what the laptop receives.
  • Battery-assisted designs like Dell's Hybrid Power are real but model-specific.
  • The battery report shows how worn the battery is, not why the machine is slow.
Run through the checks in order before you write the laptop off or order a replacement battery.
  1. Your slow laptop might just have a battery problem How-To Geek 2026-11-12T16:30:15+00:00
  2. Alienware m15 R2 Setup and Specifications | Dell US dell.com
  3. Power settings in Windows 11 | Microsoft Support support.microsoft.com
