rsync to synchronize and archive work back to the NAS.For Windows users, developers, and media creators facing similar network sluggishness, separating your "hot" working set from your "cold" network archive is one of the most cost-effective upgrades you can make—because it relies on hardware already sitting inside your PC.
Why Network Storage Struggles with Active Workloads
A NAS excels at centralized storage, automated backups, and serving sequential media streams across multiple devices. However, treating a network share like a local drive quickly exposes the friction between network protocols, spinning platters, and high-frequency input/output (I/O) demands.
In that kind of setup, three common workloads pushed the N100-based NAS past its comfort zone:
- Virtual Machines (VMs): Running VMs directly over a network share means the hypervisor is constantly reading from and writing to large virtual disk images. Every guest OS operation translates into continuous random I/O across the wire.
- Large Datasets and Development Projects: Software repositories and data-science workloads often consist of thousands of small source files, configuration scripts, and assets. Even when the total gigabyte count is modest, when an IDE or compiler repeatedly inspects thousands of individual files, the cumulative latency of network round-trips slows everything down.
- High-Bitrate Media Editing: Scrubbing a timeline, playing back uncompressed streams, and rendering high-bitrate HDR video demand sustained, predictable throughput. When the underlying NAS drives or network link cannot keep pace, editing directly off a shared folder turns into a frustrating exercise in dropped frames and stalled renders.
When troubleshooting slow NAS performance, the natural instinct is to blame the network or throw hardware cache at the problem. As XDA Developers has noted in its coverage of home NAS tuning, typical 1GbE network links top out around 110 MB/s, and even adding NVMe SSD caching to a NAS often fails to speed up large sequential transfers or certain mixed workloads the way users expect. In such a setup, experimenting with network settings yielded minor gains, and while a network bottleneck remained part of the picture, underlying storage performance stood out as the bigger limitation. With SSD pricing making an all-flash NAS overhaul difficult to justify, rethinking file organization proved far more practical than buying new hardware.
Section Summary: High-capacity NAS setups are built for centralized storage and archiving, not necessarily low-latency random I/O. Workloads like live virtual machines, multi-file development repositories, and HDR video editing suffer from network round-trip overhead and hard-drive latency when run directly from a shared folder.
The Local-First, NAS-Backed Workflow
Instead of forcing the NAS to handle live, latency-sensitive tasks, a tiered workflow shifts active files to local PCIe storage while demoting the NAS to what it does best: synchronization and long-term retention.
| Storage Tier | Hardware Role | Target Workloads | Primary Benefit |
| Hot Tier (Local PC) | Internal NVMe SSD (e.g., 1TB Samsung 990 EVO) | Active VMs, current video edits, live code repositories, active datasets | Eliminates network round-trips; maximizes local PCIe throughput and low latency |
| Warm Tier (Sync Copy) | Primary NAS Share | Mirror of in-progress projects updated via rsync | Protects against local PC or SSD hardware failure; enables multi-device access |
| Cold Tier (Archive) | NAS / DAS Array | Completed projects organized by year and project name | Frees up local SSD capacity; centralizes long-term storage cheaply |
In this setup, repurposing an existing 1TB Samsung 990 EVO SSD inside the PC as a dedicated workspace for active projects. According to Samsung's official specifications, the 1TB 990 EVO is an M.2 PCIe 4.0 NVMe drive rated for sequential speeds of up to 5,000 MB/s read and 4,200 MB/s write (depending on system configuration). Even accounting for real-world overhead and varied file sizes, keeping active files on an internal NVMe bus operates in a completely different league than pulling data across a standard home Ethernet link from mechanical hard drives.
How the Daily Routine Works
- Isolate Active Projects Locally: Create a dedicated workspace directory on the local SSD. Group all working files, research materials, and supporting assets into subfolders by project name so they are easy to target with sync tools.
- Synchronize Incrementally with
rsync: Rather than dragging and dropping entire project folders over the network at the end of the day, usersyncto push updates to the NAS. Becausersynccompares source and destination files and transfers only new or modified data, routine syncs finish quickly without saturating the network. - Run Manual or Scheduled Passes: Depending on how critical the day's progress is, trigger
rsyncmanually at the end of a work session or schedule it to run automatically at regular intervals in the background. - Verify and Retire Completed Work: Once a project wraps up—whether after a few days or several months—run a final synchronization pass to the NAS. Confirm that the archived files are intact and accessible on the network share, then delete the local SSD copy to reclaim fast storage space. Organizing the NAS archive by year and project name keeps historical work easy to locate later.
Section Summary: By staging active projects on a local NVMe SSD and periodically pushing changes to the NAS with rsync, you get local bus speeds during the workday while maintaining centralized network copies.
Crucial Caveats: Synchronization Is Not a Versioned Backup
While using rsync to mirror a local workspace to a NAS is efficient, IT veterans know there is a dangerous trap lurking in automated file synchronization: a mirror is not a backup.
According to the official rsync(1) manual page maintained by the Samba project, rsync offers extensive flags that control how destination files are updated or removed. If you accidentally corrupt a project file, overwrite a critical dataset with bad edits, or delete a folder on your local SSD, the next synchronization run can dutifully copy that mistake straight onto your NAS—especially if your script uses deletion flags to keep the destination identical to the source.
As a word of caution, keeping a synchronized copy on a NAS protects you if your PC's local SSD dies, but it will not save you from human error or silent file corruption once the sync job runs. To make this workflow resilient on Windows or Linux systems, pair your sync routine with proper versioning:
- Enable NAS File-System Snapshots: If your NAS runs a modern copy-on-write file system like ZFS or Btrfs, configure automated, read-only snapshots on the destination share. If a bad
rsyncpass overwrites a good file, you can roll back or pull the prior version from a snapshot. - Use
rsyncBackup Flags: Thersyncutility includes options such as--backupand--backup-dir, which instruct the receiving system to rename and move preexisting destination files into a separate folder before overwriting or deleting them. - Windows Native Alternatives: While
rsyncis readily available to Windows 11 users via the Windows Subsystem for Linux (WSL), Git Bash, or Cygwin, Windows administrators can also achieve similar incremental directory syncing using built-inrobocopyscripts paired with Task Scheduler, provided the NAS side still handles snapshot versioning.
Section Summary: Automated synchronization protects against local drive failure, but it can also overwrite good NAS files with corrupted or deleted local changes. Always combine active folder syncing with NAS-side snapshots or versioned backups.
Balancing Cost, Capacity, and Speed
It is easy to get caught up in the home-lab arms race—pricing out 10GbE network switches, multi-bay NVMe NAS enclosures, and enterprise caching drives just to make a sluggish shared folder feel snappy. Yet hardware upgrades at the network level often hit diminishing returns if your daily frustration comes down to a handful of heavy, active projects.
By treating your PC's internal SSD as a high-speed workbench and your NAS as the warehouse, you sidestep network latency entirely during active work without spending a dime on new infrastructure. You keep the massive, affordable capacity of spinning rust for your archives, preserve the responsiveness of local NVMe storage for your daily grind, and get the most out of the hardware you already own.
Correction (October 17, 2026): An earlier correction today removed the How-To Geek/Umair Khurshid attributions as supposedly fabricated. A server-log audit has since confirmed the How-To Geek page was fetched during writing and the attribution was in the original draft. The fabrication claim is withdrawn; the attributions were removed in error.
- My NAS wasn't fast enough for my most-used files, so I came up with a better solution How-To Geek · 2026-10-16T21:30:16+00:00
- 990 EVO NVMe™ 1TB Internal SSD | Samsung US samsung.com
- I thought SSD caching would speed up my NAS, but here's what actually helped xda-developers.com
