A handheld gaming console displays sleep, power, and battery-saving options in a warmly lit room.
Sleep or shutdown? On a Steam Deck the answer turns on how soon you plan to play again. Valve's own documentation backs the quick-resume case for sleep. It also describes a third option for long storage, battery storage mode, which is neither sleep nor an ordinary shutdown.
A handheld gaming console displays sleep, power, and battery-saving options in a warmly lit room. The short version​
  • Sleep is for a short break or a quick return to the same game.
  • Shutdown is for when you don't need to keep an active session and would rather the Deck be fully powered down.
  • Battery storage mode is a separate, deeper procedure for a Deck that will sit unused for a while.
What sleep actually does​
Valve describes the feature on its hardware page. Hmm, that is a community thread, so ignore it here. Valve's wording is that SteamOS has a built-in suspend and resume feature. Pressing the power button suspends your game and puts the Deck to sleep. Pressing it again wakes the Deck where you left off. This is why sleep is the natural choice for a handheld that gets picked up and put down all day.
BGR's piece adds some practical caveats:
  • Sleep preserves the state of your game. It does not save your progress, so save in-game before you put the Deck away.
  • A sleeping Deck still draws battery.
  • Online games may disconnect while the Deck is asleep.
What shutdown means​
Shutdown closes the game and the system. When you turn the Deck back on, you have to launch the game again and load your last save. BGR notes that this takes longer than waking from sleep but conserves battery.
BGR also says Valve recommends shutting down or restarting periodically. That advice is consistent with the Deck's update behavior, because restarts apply pending software updates.
A correction to a common claim: BGR says RAM keeps receiving power after shutdown. I found no Valve documentation that says this, and it contradicts the normal meaning of a shutdown. Don't rely on it. Valve's materials don't detail which components stay powered after an ordinary shutdown.
How much battery does each option use?​
Valve gives no official figures, so I'm not going to give any either. Community reports vary widely and are anecdotal:
  • Steam community posters report sleep drain ranging from roughly 7–10% per day to much more on units that are misbehaving.
  • Some owners report a shut-down Deck slowly losing charge over days, which is the reason battery storage mode exists.
  • A persistent, large drain during sleep is worth raising with Valve support rather than accepting as normal.
These are forum anecdotes, not measurements. Your results will depend on your games, accessories and software state.
The "few times a week" rule is a rule of thumb​
BGR's heuristic is to use sleep if you resume several times a day and shut down if you play a few times a week. That's sensible, but it is a convenience guideline rather than a Valve threshold. One third-party guide suggests a full shutdown for overnight storage on battery, and sleep is fine if the Deck stays plugged in. That is the guide's opinion, not official guidance.
Some owners also report accidental wake-ups, for example from Bluetooth accessories, while the Deck is in a case. Valve's SteamOS 3.7.17 notes from November 2025 say experimental wake-on-Bluetooth support for the Steam Deck LCD was temporarily re-disabled while spurious wake-ups were investigated. If your Deck wakes up unexpectedly in a bag, that is a good reason to shut it down before packing it.
Long-term storage: battery storage mode​
Valve's troubleshooting guide describes this mode for a Deck you won't use for a while, to help long-term battery health. The steps are:
  1. Shut the Deck down normally from the Power menu.
  2. Hold Volume + and press the power button to enter the BIOS menu.
  3. Use the D-pad and A button to select Setup Utility.
  4. Open the Power menu and choose Battery storage mode, then confirm.
  5. To wake the Deck later, plug in the supplied power supply and power it on normally.
The Deck should power off, and the indicator confirms the mode. On LCD models the power LED blinks three times. Valve says OLED models behave differently, with two blue blinks after about eight seconds. Valve's guide applies to both LCD and OLED models unless it says otherwise.
A third-party guide advises charging or discharging the battery to around 40–50% first. That is not in the Valve text I reviewed, so treat it as general battery-care advice.
This is not an everyday option. Using it between normal play sessions would just mean going through the BIOS every time.
One exception: display-off downloads​
On November 4, 2025, Valve shipped a Beta/Preview client update with a display-off, low-power download mode. It lets the Deck finish active downloads with the screen off before it goes to sleep. It is enabled by default when the Deck is plugged in. You can also enable it on battery in Settings > Power. I couldn't confirm from the evidence I had whether it has reached the Stable channel, so check your own settings.
Practical recommendations​
SituationSuggested choice
Quick break, resuming the same game soonSleep
Commuting with the Deck in its case, playing later todaySleep, after saving in-game
Not playing until tomorrow or later, running on batteryShutdown
Deck waking up in your bagShutdown, and check accessories
Storing for weeks or monthsBattery storage mode
Updates pending or odd behaviorRestart
Bottom line​
Sleep is the convenient default, and Valve built it for exactly that. Shutdown is the tidier choice when you won't play soon. Battery storage mode is for real storage. Whichever you pick, save in-game first, because sleep preserves state but doesn't protect your progress.
  1. Sleep Mode Or Shutdown: What Should You Use On Steam Deck? bgr.com 2026-11-10T19:17:00+00:00
  2. PSA for black screen or deck not waking up completely from sleep :: Steam Deck General Discussions steamcommunity.com
  3. Steam Deck :: Hardware steamdeck.com
