What launched, and when
TechRadar's verdict is that the Rival Pro Mini offers flagship performance in a compact form, but at a high price. SteelSeries announced the Sensei Pro and Rival Pro series on September 29, 2026. Pre-orders opened that day, and retail availability was set for October 13. The series has four mice:
- Rival Pro (ergonomic, right-handed, full size)
- Rival Pro Mini (ergonomic, right-handed, compact)
- Sensei Pro (symmetrical, full size)
- Sensei Pro Mini (symmetrical, compact)
Each comes in black or white. SteelSeries lists every one at US$179.99, €199.99 or £169.99. TechRadar notes this means the Mini costs the same as the full-size Rival Pro. A Best Buy listing showed an October 11 release date for the Mini. Treat October 13 as SteelSeries' announced retail date, since that listing shows only that one retailer displayed an earlier date.
The headline specs
Most of these figures come from SteelSeries or from the review's spec table. They are not independent lab measurements.
| Spec | Rival Pro Mini |
| Wireless | Ultra-Wideband (UWB), via a base station |
| Polling | 8,000 Hz, with 9,000 Hz over-polling |
| Sensor | TrueMove 42K, up to 42,000 DPI |
| Switches | Optical; SteelSeries rates them at 100 million clicks and claims 0.35 ms click latency |
| Buttons | 6 programmable |
| Weight | 49 g (1.7 oz) |
| Size | 120.7 × 65.4 × 40.5 mm |
| Battery (per battery) | Up to 60 hours at 1 kHz, up to 16 hours at 8 kHz |
Root Nation's review says the sensor is a customized version of PixArt's PAW3955.
UWB: what SteelSeries claims
Almost every wireless mouse uses the crowded 2.4 GHz band. SteelSeries argues that this congestion stops gamers from getting consistent 8K polling. Its answer is UWB.
SteelSeries says UWB runs across the 6.4 to 9.056 GHz range and has roughly 20 times the bandwidth. It says this makes the link less prone to interference from headsets, keyboards, phones and other 2.4 GHz devices. These are company claims. The reviews I could see did not independently measure the interference resistance.
The mouse also has no USB port, so it cannot be used wired. The base station connects to the PC by cable. Shacknews reported that the full-size models work best within about one to two feet of the base station. It said SteelSeries staff recommended a three-foot limit, and that this matched its own testing. The Mini will presumably behave similarly, but that is an inference and not a tested result.
The "infinite power" system
SteelSeries calls the battery arrangement the Infinite Power System. One battery sits in the mouse while a second charges in the base station. When the first runs low, you swap them. TechRadar called this a "truly brilliant feature" in its review.
"Infinite" is shorthand for the swap routine. The batteries still run down and still need charging. Uninterrupted play depends on the spare being charged and you remembering to swap.
The battery numbers are easy to misread:
- Per battery: up to 60 hours at 1 kHz, or up to 16 hours at 8 kHz.
- Two batteries in rotation: SteelSeries says up to 120 hours at 1 kHz, or 32 hours at 8 kHz.
TechRadar's "60 hours or 16 hours" figures are the per-battery numbers. At 8K polling, 16 hours is about two long gaming days. Shacknews, testing the full-size models, said the battery lasts a good business day at middle settings and can drain faster with more demanding settings.
SuperSync and 9K over-polling
SuperSync lets you set the tracking report rate separately from the click polling rate. SteelSeries' product page says tracking can run at 1K, 2K or 4K while clicks stay at 8K. The idea is that you can trade some tracking rate for battery life without giving up click responsiveness.
Over-polling at 9K adds an extra packet for every eight, to help hold a steady 8K signal. These are vendor descriptions of configuration options. They do not prove that every player will notice a difference.
TechRadar's reviewer said button mapping, sensitivity, polling rate and power management can all be changed in the SteelSeries GG app or its web platform. The reviewer found both easy to navigate. SteelSeries lists Windows 10 and later, PlayStation and Xbox Series S|X as compatible. It warns that not all features may work on consoles, and the evidence doesn't say which ones are affected.
How it felt in testing
The reviewer tested over a few days, mainly with the PC version of Cyberpunk 2077 on an LG UltraGear 25G590B 1000 Hz monitor. They also used it for general productivity. Their impressions, which are one person's subjective opinions, were:
- Aim felt stable and accurate, and camera movement was smooth and responsive.
- The optical switches felt good. They are not the quietest, but the reviewer didn't find them distracting.
- The mechanical scroll wheel was controlled and tactile.
- The lightweight molded body was comfortable for hours without cramping.
- The matte finish looks premium but picks up fingerprints. The reviewer expects the white version to hide them better than the black model they tested.
Fit and grip
The Mini is the smaller of the two ergonomic Rival models, and it is made for right-handers. TechRadar suggests larger-handed players step up to the full-size Rival Pro and left-handers look at the symmetrical Sensei Pro Mini.
SteelSeries' own fit guidance is looser than a hard rule:
- The Rival Pro is designed for palm and relaxed-claw grips.
- The Sensei Pro is designed for aggressive claw or fingertip grips.
- Mini sizes and symmetrical shapes are often preferred for fingertip and aggressive-claw grips.
- Any of the four can be used with palm, claw or fingertip grips.
Root Nation's summary of the lineup is similar: palm users should get the Rival Pro, claw or fingertip users the Sensei Pro, and people with small hands either Mini.
Corroboration, and one caveat
Shacknews reviewed the full-size Rival Pro and Sensei Pro, not the Mini. It found them comfortable and light. It praised the UWB connection and the quick battery swaps. SteelSeries provided its review samples.
It also reported one problem. After long use, scrolling became slower and less responsive. The problem went away when it swapped in a fresh battery. That is a single observation on a related model. Nothing in the evidence shows the Mini has the same issue, so it is a point to watch in other reviews.
Value: who should buy it
The case for the Mini is simple. It has the same features as the full-size Rival Pro in a slightly smaller, lighter body. The case against is that it costs the same as the larger mouse. TechRadar acknowledges the price is steep and says it would have been nice for the Mini to cost a little less.
TechRadar says plenty of good mice cost under $100 or £100, and that the Mini may be overkill if you don't need top-end precision. Its alternatives are the Logitech G Pro X2 Superstrike and the Razer DeathAdder V4 Pro, which it says is sometimes discounted.
Here is who the Rival Pro Mini suits:
- A good fit: competitive FPS players with small or medium hands and a fingertip or claw grip, who want 8K polling and don't want to plug in a charging cable.
- Look elsewhere: people with large hands, left-handers who want an ergonomic shape, anyone who wants a wired fallback, and buyers who don't need 8K polling.
Be skeptical of marketing language such as "true 8K" and "8K all day." Treat them as SteelSeries' pitch, not as results anyone has measured independently. The hands-on reports are positive, but they are early and mostly cover the full-size models. They also cover only the first weeks of ownership.
- SteelSeries Rival Pro Mini review: S-tier performance in a compact package TechRadar · 2026-11-04T23:00:00+00:00
- SteelSeries Rival Pro & Sensei Pro Gaming Mouse review: Always locked in | Shacknews shacknews.com
- How do I decide which size or shape for the Rival Pro is best for me? – Support support.steelseries.com
