A hand gestures toward one laptop as two computers display wireless connection graphics on a home office desk.
Notebookcheck says the new Surface Laptop 13 is the closest thing Windows has to a MacBook Air. It also admits the laptop isn't fanless, and that's the first thing to understand about this verdict.
A hand gestures toward one laptop as two computers display wireless connection graphics on a home office desk. What Notebookcheck is claiming​
Notebookcheck says the Snapdragon X2 Plus processor makes the Surface Laptop 13 virtually always silent in everyday use. That, it argues, makes it the best Windows alternative to the passively cooled MacBook Air. The headline says "best", but the body is more careful. It says there is still no true Windows alternative, and that the Surface comes very close to a passively cooled device.
The test unit uses the six-core X2P-42-100. Notebookcheck's spec table lists 16 GB of memory and a 1920 x 1280 IPS touchscreen at 60 Hz. The review's published date of October 28 and the Microsoft announcement of September 23 put this squarely in the current product cycle. Don't confuse this model with the 13.8-inch Surface Laptop 8, which Notebookcheck reviewed separately with a different X2 Plus chip.
Quiet, but not fanless​
The fan is still there. Notebookcheck's reviewer says you must load the chip for several minutes before even faint fan noise appears. Its review reports maximum noise of 29 dB(A) in the stress test and 27 dB(A) while gaming. These are one reviewer's measurements on one unit, not a guarantee for every workload or room.
Other outlets describe the cooling differently, so check before buying. Tom's Guide's hands-on says both the new Surface Pro and Surface Laptop lack active cooling fans. Microsoft's own announcement, though, calls only the Surface Pro 12-inch fanless. For the Laptop it mentions "quiet thermals" in general terms. Notebookcheck's lab review, which found a fan that rarely spins up, is the more detailed account, and it is the one this article relies on.
Performance: adequate, not M5-class​
Notebookcheck is blunt here. The X2P-42-100 handles everyday work but cannot match Apple's M5.
  • CPU rating: Notebookcheck's native-performance rating gives the Surface 70.9 points against 100 for the 10-core M5.
  • Geekbench 6.7 multi-core: the Surface scores 12,070 and the MacBook Air M5 scores 17,072.
  • Geekbench 6.7 single-core: the M5 scores 4,185 against 3,269 for the Surface.
  • Cinebench 2024 single-core: the M5 scores 200 against 130.
Notebookcheck says the chip stays at around 22 W under sustained load and doesn't lose performance on battery. That's useful for office work, browsing and video calls. It is less useful for sustained creative work or heavy compiling.
Battery life​
Notebookcheck's Wi-Fi web test gives the Surface about 18 hours 50 minutes at 150 nits. The MacBook Air runs out of steam nearly three hours earlier in that test. At maximum brightness, Notebookcheck lists 10 hours 41 minutes for the Surface, and says the MacBook Air doesn't reach seven hours.
Keep these figures separate from Microsoft's claim. Microsoft cites 22.5 hours of battery life, measured for local video playback. The two numbers come from different tests and aren't comparable.
How the two laptops compare​
Notebookcheck gives these as its own judgments:
AreaSurface Laptop 13MacBook Air M5
TouchscreenYesNo
USB-A portYesNo
KeyboardSlightly better (reviewer's view)Slightly behind
DisplayMore reflective, about 70% P3 coverageLess reflective, wider P3 gamut
StorageReplaceable SSDNot mentioned
ChassisSlightly thickerSlightly slimmer
Refresh rate60 Hz60 Hz
The review also lists drawbacks: soldered RAM and tricky access to the internals. Removing the M.2-2242 SSD means taking off the top of the base unit and some cables. There's no USB4. The webcam lacks Windows Hello face login, though a fingerprint reader is built into the power button. TechRadar's first look at the new models also questioned the screen, saying the 1920 x 1280 panel won't compare to the MacBook Air's sharper 2560 x 1664 display.
The price claim needs a caveat​
The news item says the prices are almost identical. The details are less tidy. Microsoft's U.S. starting price for the 13-inch Surface Laptop is $1,199. Notebookcheck lists the tested configuration at 1,439 euros. Its comparison table lists a 16 GB / 512 GB MacBook Air M5 at 1,199 euros. On that basis the Surface is about 240 euros more in Europe. Compare the same market and configuration before you buy.
Who should consider it​
The evidence supports a narrower conclusion than "best". The Surface Laptop 13 makes sense for Windows users who:
  • want a laptop that rarely makes noise;
  • need a touchscreen or a USB-A port;
  • value battery life over peak speed;
  • want an SSD they can replace.
The MacBook Air M5 still wins on raw CPU speed and has the less reflective, wider-gamut screen. Check any Windows-on-Arm software your workflow depends on. It's also worth testing the fan behavior in a shop or during the return period.
Microsoft says the Surface Laptop 13-inch starts at $1,199 and ships from October 13 in select markets. Surface for Business customers get it from the same date.
  1. The new Surface Laptop 13 is the best Windows alternative to the fanless Apple MacBook Air - Notebookcheck Notebookcheck 2026-10-31T12:48:00+00:00
  2. Microsoft announces new Surface Pro and Surface Laptop devices powered by Qualcomm’s Snapdragon X2 Plus chip — and this could be its best shot at taking on Apple’s MacBook Air techradar.com
  3. Microsoft Surface Laptop 13 2026 Review - Almost silent with Snapdragon X2 Plus - Notebookcheck Review notebookcheck.net
