What TechPowerUp measured
TechPowerUp reports these whole-laptop readings:
| Test | Best Performance | Balanced | Best Power Efficiency |
| Idle | 12.8 W | not reported | 8.6 W |
| 3D rendering (full CPU load) | 116 W | 98 W | 64 W |
| Cyberpunk 2077, Ultra details | 121 W | 105 W | 95 W |
- Ray tracing: With ray tracing on in Cyberpunk, the laptop drew 113 W. The excerpt doesn't say which power mode that figure came from, so I've kept it out of the table.
- The Intel comparison: TechPowerUp says efficient Intel ultrabooks can idle as low as 2–4 W. It says this partly explains why the Surface's battery life isn't longer. The excerpt doesn't name the comparison laptops or the measurement conditions, so treat this as the reviewer's framing, not a controlled test.
- The RTX laptop comparison: TechPowerUp says most RTX gaming laptops on its charts need well over 200 W for the same gaming job. It acknowledges they are faster. The excerpt doesn't name those systems or match their settings, so it doesn't prove the Surface is more efficient per frame.
What the power modes do
The gap between modes is the most useful finding. These percentages come from simple arithmetic on TechPowerUp's numbers.
- Idle: Best Power Efficiency draws about a third less than Best Performance (8.6 W against 12.8 W).
- CPU rendering: The drop is about 45%, from 116 W to 64 W.
- Gaming: Best Power Efficiency draws roughly 21% less, from 121 W to 95 W.
TechPowerUp's excerpt doesn't report performance in each mode. So these figures show how much power you save, not how much speed you give up. Other reviewers did measure the speed cost. CNET found up to about a 40% CPU-performance difference between power settings on its unit, whose Balanced profile defaulted to Best Power Efficiency even while plugged in. Windows Central also noted that the laptop ships with the "Best Power Efficiency" profile set by default. Microsoft says it does this to maximize battery life, but that costs performance.
Practical takeaway: if you bought this machine for rendering or gaming, check the Windows power mode setting. Don't assume plugging in switches you to full speed.
How the numbers fit the hardware
Microsoft's announcement describes a design built around NVIDIA RTX Spark. It pairs a Blackwell GPU with up to 6,144 cores, a Grace CPU with up to 20 cores, and up to 128 GB of unified memory shared between CPU and GPU. Microsoft also claims a new thermal design with up to 2.5 times the thermal power capacity of its current Surface Laptops. Those are manufacturer claims, not independent findings.
The review's 116–121 W peak readings sit below the 140 W USB-C adapter that the product page lists. That doesn't prove how much headroom the system has, or how it behaves when charging. Notebookcheck measured a harsher load. Its maximum was 145 W during the stress test, settling around 130 W, and it concluded the 140 W adapter is sufficient. That fits TechPowerUp's lower, workload-specific readings. A full CPU and GPU stress test will always draw more than a rendering run or a game.
Other reviewers' gaming and idle figures
Other outlets found similar numbers:
- Notebookcheck logged an idle average of 22.7 W (6.7 W minimum, 24 W maximum) and a Cyberpunk 2077 average of 115.4 W at FHD Ultra without FSR. Its gaming figure is close to TechPowerUp's, but its idle draw is well above TechPowerUp's two idle figures.
- PCWorld caught the laptop pulling about 130 watts while gaming.
The test settings differ, so the numbers don't line up exactly. On gaming they agree: about 115–130 W. On idle they don't: TechPowerUp's figures sit at 8.6–12.8 W, while Notebookcheck's idle average is 22.7 W, which Notebookcheck attributes to the bright Mini-LED panel.
What it means for battery life
Idle draw is only one input to battery life. Reviewers got quite different runtimes from their own tests:
- Engadget measured 13 hours 25 minutes in the PCMark 10 battery benchmark.
- Windows Central's Procyon test lasted around 14 hours, and real-world use got close to 10.
- PCWorld recorded 7 hours 57 minutes streaming 4K video and 10 hours 3 minutes in a simulated office workload.
- Gizmodo said the laptop lasts between two and three hours when gaming or running GPU-heavy tasks like AI.
Gizmodo's two-to-three-hour figure is consistent with TechPowerUp's 95–121 W gaming draw. A battery of roughly 90 Wh drained at about 100 W lasts around an hour, before accounting for the fact that it also has to carry the system's other demands. That is my back-of-envelope arithmetic, not a measured result. Tom's Hardware, meanwhile, reported 10 hours 43 minutes in its own battery test on a 92 Wh unit.
Reviewers also disagree on capacity: PCWorld lists 89Wh (95Wh as tested), while Tom's Hardware lists 92 Wh. Check the figure on the exact configuration you buy.
Limits of this data
- TechPowerUp's excerpt doesn't say whether the laptop was on AC power or charging, how long each reading ran, or what Cyberpunk resolution was used.
- The excerpt doesn't say what brightness the display was set to for the idle reading.
- Power draw alone says nothing about frame rates or render times. Efficiency claims need matched performance numbers.
Bottom line
TechPowerUp's data suggests the Surface Laptop Ultra is efficient for an RTX-class laptop but not a low-power ultrabook at idle. Best Power Efficiency mode cuts system draw by about a third to nearly half across the three tests TechPowerUp reported. Other reviewers found it also costs speed. For creators, gamers, and local-AI users, the practical advice is to set the power mode on purpose and not rely on the default.
Correction (November 20, 2026): Notebookcheck's idle average is 22.7 W, not 10.3 W — the 10.3 W figure was wrong, and Notebookcheck's idle draw does not sit between TechPowerUp's 8.6 W and 12.8 W figures. The summary range for idle draw has been corrected accordingly; the Cyberpunk 2077 figure of 115.4 W was correct.
- Microsoft Surface Laptop Ultra Review - The Next-gen Arm Laptop - Power Consumption - TechPowerUp TechPowerUp · 2026-11-20T15:59:22+00:00
- Microsoft Surface Laptop Ultra review: Incredible RTX Spark AI power, painful price pcworld.com
- Microsoft Surface Laptop Ultra RTX Spark Review - The 2000-nits Mini-LED panel is a problem - Notebookcheck Review notebookcheck.net
