A sleek laptop sits on a desk beside a digital price display, glowing processor model, stylus, and potted plant.
Microsoft appears to be preparing a Snapdragon X2 version of its smaller Surface Pro 12-inch. WinFuture's Roland Quandt reported on September 23, 2026 that European retailers have listed the device under the codename "Cabo," with French prices starting at €1,259. Microsoft has not confirmed it. The model on sale today still uses first-generation Snapdragon X Plus silicon and a 90 Hz LCD. If the listings are right, this is a chip refresh for a design that is only a year old, and the entry price for a compact Surface would rise sharply. For buyers, the practical question is whether to wait. Unless the discounted current model fits your needs now, waiting a few weeks for confirmation is the sensible choice.
WinFuture's Retailer Listings Put Snapdragon X2 Inside the 12-inch Surface Pro "Cabo"​
The claim comes from retailer data, not from Microsoft. WinFuture says listings at several European retailers include updates to two Qualcomm-based Surface models: the Surface Pro with a 12-inch display (codename "Cabo") and the 13-inch Surface Laptop (codename "Navarro"). Both currently ship only with first-generation Snapdragon X chips, and WinFuture expects both to move to the Snapdragon X2 series. Notebookcheck picked up the report the same day and summarized it this way: "A new leak suggests a new 12-inch Surface Pro is coming."
According to WinFuture, the listings show a 16 GB RAM / 256 GB storage configuration at €1,259 and a 16 GB / 512 GB configuration at €1,379. The listed colors are black, platinum and violet, the same three the current 12-inch model offers. WinFuture also warns that codenames like "Cabo" are not necessarily Microsoft's regular internal names, because the company often uses several internal names for the same device during a launch.
Only WinFuture's retailer data supports the Snapdragon X2 claim. Notebookcheck's story passes the leak along without adding independent sourcing. Treat the specs, prices and colors as leaked listing data until Microsoft publishes a spec sheet.
The same WinFuture report covers other listings. One is a 12-inch Surface device codenamed "Minos" or "Project BP," which reportedly uses Nvidia's RTX Spark chip with 24, 32 or 48 GB of RAM. The other is a Bluetooth mouse codenamed "Coolidge," listed at about €90. WinFuture itself says the 12-inch detail for Minos could simply be a listing error, and that the entry might really be the 15-inch Surface Laptop Ultra. That makes Minos a far weaker rumor than the Snapdragon X2 refresh of the existing 12-inch Pro.
The Current Surface Pro 12-inch Sets the Baseline: Snapdragon X Plus, 90 Hz LCD​
Microsoft's own pages describe what a refresh would replace. The consumer Surface Pro page lists the 12-inch model with an 8-core Snapdragon X Plus processor, up to 16 hours of local video playback, a 2,196 × 1,464 PixelSense LCD touchscreen at 90 Hz, two USB-C / USB 3.2 ports and a weight of 1.5 lbs without keyboard. The business listing likewise describes the 12-inch device as "powered with the Snapdragon® X Plus processor," and notes it is "Built with Windows 11 Pro."
Microsoft's product page contradicts itself on one display spec. The 12-inch highlight panel shows "2880 x 1920, 90Hz 220 PPI," but the page's side-by-side comparison table lists 2,196 × 1,464 for the 12-inch model. 2,880 × 1,920 is the resolution the same table gives for the 13-inch model. The comparison table is more consistent with the rest of Microsoft's material, so this article uses 2,196 × 1,464.
The "90 Hz display" in Notebookcheck's headline refers to this existing panel. Nothing new has been reported about the screen. Notebookcheck says it suspects Microsoft "will return to the 38 Wh battery and 90 Hz display used in the original Surface Pro 12-inch, based on past performance." The outlet also guesses Microsoft "will opt for the Snapdragon X2 Plus X2P-42-100, currently the weakest chipset in Qualcomm's Snapdragon X2 lineup." Both are Notebookcheck's own guesses based on past Surface releases. Neither appears in the retailer data.
The smaller model differs from the 13-inch Pro in more than the chip. Microsoft's support documentation for the "Surface Pro 12in 1st Edition with Snapdragon" gives these details:
  • The device charges from either USB-C port with a USB Type-C PD charger. Microsoft recommends at least 27W, and warns that a lower-wattage charger may charge the device slowly or not at all.
  • Fast charging needs at least 45W and can take the battery to 80% in about an hour.
  • The Slim Pen stores and charges magnetically on the back of the tablet, not on the keyboard.
  • Only the Surface Pro 12-inch Keyboard is compatible. The Surface Pro 13-inch Keyboard and the Pro 13-inch Flex Keyboard do not fit.
If "Cabo" keeps the current chassis, which a processor-only refresh would suggest, existing 12-inch keyboards should carry over. That is an inference. Neither the listings nor Microsoft has said anything about accessory compatibility.
The Surface Pro Naming Mess, and Why 13-inch Snapdragon X2 Numbers Don't Transfer​
Surface naming is confusing right now, and the confusion runs through the coverage. Microsoft calls the smaller tablet "Surface Pro, 12-inch (1st Edition)." The larger model it launched in June is "Surface Pro, 13-inch (12th Edition)." Some outlets call that 13-inch model the "Surface Pro 12"; Windows Central's launch headline did. So Notebookcheck's line that the new model "will remain smaller than the Surface Pro 12 and its 13-inch display" is accurate, but it reads like a contradiction. PhoneArena summed up the confusion by noting that last year's 12-inch Surface Pro was "confusingly not named the Surface Pro 12 or Surface Pro (12th Gen)".
Snapdragon X2 is already on sale in the 13-inch model. Microsoft announced that Surface Pro on June 16, 2026 at $1,499 MSRP, with a 10-core Snapdragon X2 Plus or 12-core Snapdragon X2 Elite, a 120 Hz OLED or LCD panel, and USB4 plus Surface Connect. Microsoft claims up to 53% faster graphics than the previous generation. Neowin reported that the new chip's NPU "can run at up to 80 TOPS for on-device AI processing." For comparison, the current 12-inch model's Store listing cites a Hexagon NPU "with 45 TOPS."
Don't read those figures as a preview of the smaller Pro. Microsoft's footnote says the 53% graphics claim came from a 3DMark Steel Nomad comparison between a 13-inch Snapdragon X2 Elite unit and the previous 13-inch Snapdragon X Elite model. The 12-inch Pro has never used an Elite-class chip. If Notebookcheck's guess about the entry-level X2 Plus is right, the gain over the current 8-core X Plus could be very different. The battery claims come from 13-inch preproduction units as well. No performance, NPU or battery figures exist for "Cabo."
Euro Listings Point to Another Surface Price Increase​
Pricing is the most concrete part of the leak. WinFuture describes the new models as raising prices, and its French listings put the 12-inch Snapdragon X2 Pro at €1,259 for 16 GB / 256 GB. WinFuture expects German prices to be €10–20 lower than French ones. That is the outlet's estimate, not a listed figure. The 13-inch "Navarro" Surface Laptop is listed at €1,319 and €1,439 for the same memory and storage tiers.
There is no US price in the leak, so a US figure would be a guess. The current 12-inch model's US price has already moved around. Microsoft's Surface Pro page lists it at $849.99 today, while PhoneArena reported in June that the 12-inch Surface Pro "is still around at a starting price of $1,049.99." Neowin reported that the 13-inch model's base price rose from $999 for the previous generation to "an eye-watering $1,499" with Snapdragon X2.
If the smaller Pro follows the same pattern, the budget Surface Pro gets noticeably less budget. At €1,259 it would sit close to 13-inch Snapdragon X2 pricing while keeping a slower 90 Hz LCD, USB 3.2 instead of USB4, and no Surface Connect port. That is an inference from the leaked euro figures, and final regional pricing could change it.
The October 7 Surface Event Is the Obvious Venue, Not a Confirmed One​
Microsoft holds a Surface event in San Francisco on October 7. Notebookcheck says the company is expected mainly to share more about the Surface Laptop Ultra and the Surface RTX Spark Dev Box. Microsoft's June announcement said it would ship the Surface Laptop Ultra, "our most powerful Surface Laptop ever," later this year. It described the RTX Spark Dev Box as an entirely new category of Surface hardware for AI developers who need sustained local compute. WinFuture reports that the Laptop Ultra will be Microsoft's first PC on the Nvidia and MediaTek Arm platform with a Blackwell GPU.
Retail listings often appear shortly before a launch, so the timing points to October 7. But nothing in the reporting says Microsoft will show the Snapdragon X2 12-inch Pro on stage. It could appear at the event, arrive later through a quiet listing, or launch only in some markets first. The June Snapdragon X2 launch shows how Microsoft sometimes staggers availability: consumer models shipped June 16, and Surface for Business followed on July 14.
What this means for you​
If you want a compact Surface Pro, decide whether a discounted Snapdragon X Plus model at today's price beats a likely pricier Snapdragon X2 model with unknown gains. Everything about "Cabo" comes from retailer data, so plan around what Microsoft sells today and treat the leak as a reason to hold off briefly, not as a spec sheet.
  • If you need a 12-inch Surface now and the $849.99 US price fits your budget, the current model is a known quantity: Snapdragon X Plus, 90 Hz 2,196 × 1,464 LCD, up to 16 hours of video playback, and Copilot+ PC features on configurations with 16 GB or more of RAM.
  • If newer silicon or a longer support window matters to you, wait at least until after Microsoft's October 7 event. The listings suggest a refresh is close, and an announcement would give you real specs and prices.
  • Don't apply the 13-inch model's 53% graphics claim or 15.5-hour battery figure to the smaller Pro. Microsoft measured those on 13-inch units, including the X2 Elite, which has never been offered in the 12-inch chassis.
  • IT buyers standardizing on the 12-inch Surface Pro for Business should check whether a successor affects procurement timing and keyboard stock. The current device works only with the Surface Pro 12-inch Keyboard and needs a USB-C PD charger of at least 27W, or 45W for fast charging.
  • Treat the €1,259 and €1,379 figures as French retailer listings, not European MSRPs. There is no US price for the Snapdragon X2 12-inch model yet.
A Snapdragon X2 12-inch Surface Pro would complete Microsoft's move of its Arm lineup to Qualcomm's second-generation chips. It would also leave the smaller tablet as a more expensive product than it was at launch. If the French listings hold, the entry price for the smallest Surface Pro will be well above what the current model sells for today. Microsoft can confirm or correct the specs and pricing on October 7, or in a quieter listing soon after.
