A futuristic Guangzhou OLED factory produces vivid widescreen and ultrawide monitors, with a roadmap highlighting expansion through 2028.
For years, competitive PC gamers have faced an annoying compromise at their desks: if you wanted absurdly high refresh rates, you were usually staring at a compact 24-inch or 27-inch screen, while spacious 32-inch 4K slabs and 34-inch ultrawides were reserved for slower cinematic immersion. That boundary could start blurring over the next couple of years. According to research published by market analytics firm Omdia on October 8, 2026, TCL’s display manufacturing division—TCL China Star Optoelectronics Technology (TCL CSOT)—is planning to produce 32-inch and 34-inch OLED monitor panels with refresh rate offerings reaching up to 700Hz.
Before you start clearing space on your desk or checking your graphics card's DisplayPort bandwidth, there is a major caveat: this is a long-range factory roadmap, not a retail monitor launch. Omdia reports that TCL CSOT plans to manufacture these panels at an upcoming Generation 8.6 inkjet-printed OLED (IJP OLED) facility in Guangzhou, China, where mass production is scheduled to begin in 2028. Still, the move signals a major shift in who builds the screens powering high-end Windows gaming rigs—and how much we might eventually pay for them.
A futuristic Guangzhou OLED factory produces vivid widescreen and ultrawide monitors, with a roadmap highlighting expansion through 2028. The 2028 Guangzhou Roadmap: What Is Actually Confirmed?​
When display roadmap numbers leak into the hardware press, "up to 700Hz" easily gets telephoned into "every 32-inch monitor will run 4K at 700Hz." Looking closely at Omdia’s findings and subsequent hardware reporting from outlets like TechPowerUp, VideoCardz, and Club386, it is important to separate confirmed factory plans from unannounced product specs.
Here is what Omdia’s research actually establishes about TCL CSOT’s display pipeline:
  • The Target Sizes and Speeds: TCL CSOT’s Gen 8.6 line is planned to produce larger monitor panels—specifically including 32-inch and 34-inch form factors—with refresh rate offerings reaching a ceiling of up to 700Hz.
  • The Production Timeline: The Guangzhou Gen 8.6 factory is scheduled to start production in 2028. Because panel fabrication precedes OEM monitor integration, firmware tuning, and retail distribution, actual monitors using these panels will depend on when partner brands bring finished displays to market.
  • First-of-Its-Kind Manufacturing Scale: Omdia projects that this facility will make TCL China Star the first display maker to mass-produce inkjet-printed OLED monitor panels on a Gen 8.6 production line.
  • The Near-Term Stepping Stone: TCL is not waiting until 2028 to enter the desktop OLED space. According to Omdia, TCL CSOT’s existing Gen 5.5 facility was scheduled to begin shipping 27-inch UHD (4K) 120Hz inkjet-printed OLED panels in the third quarter of 2026 for a commercial-grade creator monitor from MSI. Reporting from Club386 identifies that display as the MSI PRO MAX OLED 271UPJW12, noting that it uses a standard RGB stripe subpixel layout designed to eliminate the color fringing around text that plagued early OLED desktop monitors.
What remains completely unknown? Neither TCL nor Omdia has disclosed the native resolutions for the planned 32-inch and 34-inch gaming panels, whether the 700Hz ceiling applies to both sizes, or whether hitting 700Hz will require a dual-mode resolution drop.
Summary: Roadmap Reality Check​
TCL CSOT is building the factory capacity to make 32-inch and 34-inch IJP OLED panels with refresh offerings up to 700Hz starting in 2028, following a 2026 rollout of 27-inch 4K 120Hz panels for MSI. Final resolutions, retail brands, and pricing for the 700Hz lineup remain unannounced.
The 1.43-Millisecond Question: What Does 700Hz Mean for PC Gamers?​
Let’s do a quick bit of back-of-the-napkin display math. A standard 60Hz office monitor refreshes its image once every 16.67 milliseconds. Step up to a comfortable 120Hz display, and a new frame arrives roughly every 8.33 milliseconds. Even today's brisk 240Hz OLED monitors refresh every 4.17 milliseconds.
At 700Hz, the display updates its refresh cycle approximately once every 1.43 milliseconds. Combined with OLED's near-instantaneous pixel response times—which Club386 notes sit around 0.03ms—sample-and-hold motion blur practically evaporates. If you are tracking a fast-moving target in Counter-Strike 2, Valorant, or Overwatch 2, the visual clarity during rapid mouse flicks on a 700Hz OLED panel would come remarkably close to the legendary motion clarity of old-school CRT monitors, without having to lug an 80-pound beige cube onto your desk.
However, a 1.43ms refresh interval is not a magic wand for total system latency, and it comes with two massive technical hurdles on a Windows PC:
  1. The Resolution and Bandwidth Catch: Pushing 700 frames per second across a 4K (3840×2160) or ultrawide 1440p (3440×1440) pixel grid requires astronomical video bandwidth. In the current market, ultra-high refresh rates often rely on dual-mode scaling. As Club386 points out, AOC’s AGON PRO AGP277QKDC can reach an even slightly higher 720Hz refresh rate, but only when switched into a reduced 1280×720 resolution mode. Similarly, TechPowerUp notes that existing 720Hz OLED panels from LG Display are built at a compact 24.5-inch size and 1080p resolution. Whether TCL’s 2028 panels will achieve 700Hz at native resolution or rely on a lower-resolution esports mode is not yet specified.
  2. The CPU and GPU Bottleneck: Even if a monitor refreshes every 1.43ms, your PC actually has to render frames that fast for you to see the full benefit. Outside of lightweight competitive shooters running on top-tier processors at low settings, very few games on Windows 11 can sustain 700 frames per second without hitting a severe CPU scheduling or game-engine wall.
Summary: Performance Implications​
A 700Hz refresh rate cuts the interval between screen updates to 1.43ms, pairing with OLED's rapid pixel response to dramatically reduce motion blur. However, real-world usability will depend on whether TCL achieves 700Hz at native resolution or via a lower-resolution dual mode, as well as whether PC hardware can actually push 700fps.
Inkjet-Printed OLED vs. The Samsung and LG Duopoly​
Perhaps the most consequential part of Omdia’s report has nothing to do with reaching 700Hz—it is how TCL CSOT plans to build these panels.
Up to now, the desktop OLED monitor market has been dominated by two panel suppliers: Samsung Display (with QD-OLED) and LG Display (with WOLED). According to Club386, both South Korean giants rely primarily on Vacuum Thermal Evaporation (VTE), a manufacturing technique that deposits organic light-emitting materials through fine metal masks (FMM) inside vacuum chambers. While effective, VTE is material-intensive and expensive to scale.
TCL CSOT is betting heavily on Inkjet-Printed OLED (IJP OLED). Much like a high-precision industrial inkjet printer, the process sprays organic electroluminescent materials directly onto the substrate only where they are needed. According to figures reported by Club386:
  • TCL claims its inkjet printing process achieves a material utilization rate above 90%, substantially cutting down on wasted organic compounds.
  • Omdia data cited by Club386 estimates that inkjet printing can deliver 30% to 35% in manufacturing cost savings compared to conventional fine-metal-mask OLED production.
  • As observed on the upcoming 27-inch MSI creator panel, TCL’s inkjet method also facilitates a clean RGB stripe subpixel arrangement, which plays much nicer with Windows ClearType text rendering than unconventional triangular or RWBG subpixel layouts.
Does a 30% to 35% manufacturing cost reduction guarantee that future TCL-powered monitors will be 35% cheaper at retail? Not automatically—OEM margins, scalers, cooling solutions, and tariffs all play a role. Still, introducing a third major panel supplier with a structurally cheaper production method at Gen 8.6 scale is bound to put downward pressure on panel pricing across the industry.
The Bigger Picture: OLED Monitors Are Going Mainstream​
TCL’s expansion arrives in the middle of an explosive growth phase for desktop OLED displays. According to Omdia’s October 2026 market forecast, global OLED monitor panel shipments are projected to surge 79% year-over-year in 2026 to reach 6.1 million units, with shipments forecast to climb further to 7.5 million units in 2027 as new factory capacity comes online.
Omdia’s data reveals just how rapidly the supply chain and street prices are shifting:
Market Metric (Omdia Forecast / Data)2026–2027 Projection & Details
2026 Global OLED Panel Shipments6.1 million units (up 79% from 2025)
2027 Global OLED Panel ShipmentsForecast to reach 7.5 million units
Top Panel Purchasers (2026 Share)ASUS leads at 23%, followed by MSI (14%) and TPV (12%)
Other Major BuyersSamsung, LG Electronics, Dell, Acer, Lenovo, plus expanding lines from Gigabyte, HKC, and KTC
27-inch 240Hz OLED Price DropPrices fell by more than 40% in 2026
Entry/Mainstream OLED Price FloorReached the $350 range in 1H 2026; forecast to approach $300 by 2027
"Expanding capacity, falling prices and broader adoption of brands & OEMs are helping OLED monitors reach a wider market," said Nick Jiang, Principal Analyst for Display and OEM Research at Omdia, in the firm's release. Jiang added that TCL China Star's Gen 8.6 IJP OLED capacity is projected to reshape supply chain dynamics and the broader competitive landscape.
Summary: Market Impact​
With global OLED monitor panel shipments forecast to hit 6.1 million units in 2026 and mainstream 27-inch 240Hz OLED prices already dropping into the $350 range, OLED is rapidly moving out of the luxury niche. TCL CSOT’s entry with inkjet-printed panels adds a third major supplier to challenge Samsung Display and LG Display.
Should You Wait for 2028 or Buy an OLED Monitor Now?​
If you are building or upgrading a Windows gaming PC right now, waiting until 2028 (or likely late 2028 to 2029 for retail availability) just to chase a 700Hz sticker on a 32-inch box makes very little practical sense.
With mainstream 27-inch 240Hz OLED monitors already seeing price cuts of more than 40% in 2026—dipping into the $350 territory and projected by Omdia to approach $300 in 2027—today's OLED market offers tremendous value. For the vast majority of PC gamers, a 240Hz or 360Hz OLED display already delivers transformative contrast, true HDR blacks, and razor-sharp motion clarity that most graphics cards can actually saturate.
Where TCL CSOT’s roadmap does matter today is what it signals for the future of PC hardware. First, look out for those initial 27-inch 4K 120Hz inkjet-printed panels arriving in monitors like MSI's creator lineup; they will serve as our first real-world proving ground for TCL's RGB-stripe inkjet durability, brightness, and text clarity on Windows desktops. Second, if TCL’s Gen 8.6 Guangzhou factory hits its 2028 stride as projected, the days of choosing between a large-format display and esports-grade refresh rates may finally be numbered.
  1. TCL Is Bringing 700Hz OLED Gaming to 32-Inch and 34-Inch Monitors Windows Report 2026-10-15T06:45:54+00:00
  2. TCL is prepping 700Hz OLED gaming monitor panels for 2028, says research firm | Club386 club386.com
  3. TCL is preparing 700Hz OLED gaming monitor panels - VideoCardz.com videocardz.com
