Two rechargeable batteries sit beside a USB-C charging cable, mouse, and illuminated keyboard on a wooden desk.
USB-C charging can make an older wireless mouse and keyboard easier to live with—without replacing either device or reaching for a soldering iron. The trick is putting the charging port on the removable AA batteries, not the peripherals themselves. Verbatim, for example, sells AA lithium-ion cells with built-in USB-C charging and no separate charging cradle.
That distinction is central to MakeUseOf writer Pankil Shah’s account of refreshing his desktop accessories. He replaced disposable AAs in an HP wireless mouse and a mechanical keyboard with USB-C-rechargeable cells, then kept charged replacements ready. It is a battery-management upgrade, rather than a hardware conversion—and arguably more useful for being so uncomplicated.
Two rechargeable batteries sit beside a USB-C charging cable, mouse, and illuminated keyboard on a wooden desk. What changed at the desk​
Shah reports that his mouse struggled to reach four weeks between battery changes, sometimes developing lag and disconnects before he realized its battery needed replacing. His keyboard lasted several months, with shorter intervals when its RGB lighting was enabled.
Those are observations about his equipment, not benchmarks for wireless peripherals generally. The account does not identify the exact mouse, keyboard or rechargeable battery model, so it cannot establish what another owner should expect.
His solution was to buy four rechargeable AA cells and rotate them between charging and use. The practical improvement was having replacements on hand rather than discovering that the drawer of disposable batteries was empty.
There is an important boundary here: this does not turn an AA-powered mouse into a wired USB mouse, or add charging circuitry to a keyboard. The charging connection belongs to the batteries, which are removed and recharged separately. Verbatim’s product documentation describes that self-contained arrangement, including a cable for charging four cells.
The specifications deserve a closer look​
Shah describes approximately one-hour charging, but that should not become a buying expectation. Verbatim specifies up to three hours for its Charge ’n’ Go AA batteries; XTAR advertises 3.9 hours for its AA LR 3000mAh USB-C model. Neither specification supports a blanket promise of a one-hour refill.
Battery-warning behavior also deserves attention. Verbatim describes regulated 1.5V output, whereas XTAR says its LR 3000mAh model uses a gently declining voltage profile intended to resemble alkaline batteries. Consequently, “USB-C AA” does not describe one universal discharge characteristic.
The practical takeaway is to observe how your particular mouse or keyboard behaves after switching, rather than assuming its existing battery warning will give the same notice. Keep a charged replacement available during those first discharge cycles.
A sensible checklist before switching​
For readers considering the same approach, the useful questions are less glamorous than the connector—and more important:
  • Check the peripheral’s battery requirements. Confirm the required cell size, voltage and any restrictions in its documentation.
  • Check the exact rechargeable model. Read its dimensions, charging instructions and supported cable arrangements rather than relying on the broad “USB-C AA” label.
  • Allow enough charging time. Plan around the manufacturer’s specification, not another owner’s experience with unidentified cells.
  • Size the spare set to your equipment. Count the cells needed by both peripherals before deciding whether four batteries provide a complete replacement set.
  • Test before traveling. Establish that the cells fit, the peripherals operate normally and the charging setup works before depending on them away from home.
Charging instructions are particularly worth reading. XTAR specifies a 5V adapter for its LR 3000mAh cells and warns against charging a battery and phone simultaneously through certain multi-device cables, because the phone’s fast-charging negotiation could expose the battery to excessive voltage. That is a model-specific caution, not a reason to condemn all multi-output charging cables.
Convenience is the strongest argument​
Shah’s experience makes a credible case for reducing the nuisance of battery replacement. It does not establish universal runtime improvements, a guaranteed financial break-even point or a quantified environmental benefit: the account lacks an identified battery model and comparative testing.
The strongest conclusion is narrower and more useful. If your mouse and keyboard already suit you, rechargeable AA cells with their own USB-C ports offer another way to maintain them. You still have a charging routine—but it may be preferable to a recurring scavenger hunt through the battery drawer.
  1. I gave my battery-powered mouse and keyboard a USB-C port they never had MakeUseOf 2026-11-15T13:00:16+00:00
  2. Charge 'N' Go USB-C Rechargeable Batteries, 4pk - AA verbatim.com
  3. XTAR AA 1.5V LR 3000mAh USB-C Rechargeable Battery xtar.cc
