A neon-lit gaming setup displays a cyberpunk city scene alongside performance stats on an ultrawide monitor.
There is a specific kind of quiet heartbreak every PC gamer knows well. You ride into a packed city hub, watch your frame rate stumble, dive into the graphics menu, and start dragging your upscaling slider down the ladder—from Quality to Balanced, Performance, and finally Ultra Performance. You brace yourself for a softer, fuzzier image in exchange for silky-smooth frames. Only this time, the game looks like someone smeared petroleum jelly across your monitor, and the FPS counter refuses to budge.
It feels like a broken promise, mostly because modern graphics marketing has trained Windows gamers to treat Nvidia DLSS and AMD FSR as magic "free FPS" buttons. They aren't. Image reconstruction only speeds up your game when your graphics card is the component gasping for air. The instant your processor falls behind on preparing game logic and draw calls, rendering at a tinier internal resolution just lets your GPU finish its homework early and sit around twiddling its silicon thumbs.
A neon-lit gaming setup displays a cyberpunk city scene alongside performance stats on an ultrawide monitor. The Resolution Illusion: What Upscalers Actually Fix​
To see why aggressive upscaling hits a brick wall, it helps to separate what your GPU and CPU actually do on every single frame. Your processor runs the world simulation—AI routines, physics, crowd behavior, animation states, and instructing the graphics driver on what needs to be drawn. Your graphics card then takes that blueprint and paints the actual pixels, shadows, reflections, and post-processing effects onto your screen.
Upscaling technologies like Nvidia DLSS Super Resolution and AMD FidelityFX Super Resolution (FSR) only lighten the GPU's half of that workload. Rather than shading millions of native pixels, the game renders internally at a fraction of your monitor's resolution and relies on temporal data or machine-learning models to reconstruct a sharp output image.
Official developer tables from AMD's GPUOpen documentation illustrate just how aggressively these presets slash pixel counts:
Upscaling TierPer-Dimension ScaleArea Scale (Pixel Count)Internal Res at 1080pInternal Res at 1440pInternal Res at 4K
Native AA / DLAA1.0x (100%)1.0x1920 × 10802560 × 14403840 × 2160
Quality~1.5x (66.7%–67%)2.25x1280 × 7201706 × 9602560 × 1440
Balanced~1.7x (58%–59%)2.89x1129 × 6351506 × 847~2227–2259 × 1253–1270
Performance2.0x (50%)4.0x960 × 5401280 × 7201920 × 1080
Ultra Performance3.0x (33%–33.3%)9.0x640 × 360854 × 4801280 × 720
Note: Ratios reflect AMD FSR Upscaling's documented presets alongside Nvidia DLSS's matching 66.7%, 58%, 50%, and 33.3% scaling steps.
Even as both camps have pushed neural rendering dramatically forward—Nvidia rolling out its Transformer-based DLSS 4 and 4.5 models for cleaner edges and better temporal stability, and AMD expanding machine-learning FSR Upscaling 4.1 across Radeon RX 6000, 7000, and 9000 GPUs as well as Ryzen handhelds—neither neural network can rewrite the laws of pipeline math. Shrinking a 1440p render target down to 854 × 480 cuts pixel-shading work by nearly ninefold, yet the CPU still has to calculate every pedestrian, draw call, and physics tick just as fast as before.
Inside the 1440p Wall: Cyberpunk 2077 and The Witcher 3​
To catch that exact handover point in action, Mainak Kumar Dey at XDA Developers tested every DLSS tier at 1440p (with Frame Generation disabled so generated frames wouldn't mask raw engine throughput) on a rig pairing an Intel Core i5-13600K and 32GB of RAM with an undervolted GeForce RTX 4090. The results draw a remarkably clear line between GPU relief and CPU exhaustion.
Night City's Hard Ceiling​
In Cyberpunk 2077—run on the Ultra preset with ray tracing switched off so the RTX 4090 wouldn't obscure processor limits—DLAA using Nvidia's DLSS 4.0 Transformer model pushed the graphics card flat out. The RTX 4090 sat at 97% to 98% utilization, pulling close to 300W to average roughly 78 to 91 FPS while the Core i5-13600K sipped around 65W.
Enabling DLSS Quality immediately uncorked the GPU, catapulting live frame rates to roughly 143–146 FPS and forcing CPU power draw up to 94W to feed the faster pipeline. Dropping to DLSS Balanced delivered the final worthwhile bump, landing in the 166–181 FPS range.
Beyond Balanced, the gains evaporated:
  • DLSS Performance hovered in the exact same 166–181 FPS band while CPU power topped out just past 101W.
  • DLSS Ultra Performance added zero extra frames, yet RTX 4090 utilization plunged to 68% and board power dropped to around 185W.
Why didn't Task Manager scream "100% CPU usage" when that ceiling hit? Because games rarely distribute work evenly across every core on modern hybrid processors. Instead, a handful of critical main threads max out while background cores idle, leaving overall CPU utilization deceptively low even as the frame rate hits a brick wall.
Novigrad Docks and the Ray-Tracing Shift​
The Witcher 3: Next-Gen provided an even sharper demonstration at the bustling Novigrad docks (with HairWorks disabled), where dense NPC crowds tax the CPU far harder than the quiet countryside.
Game & Scene (1440p, FG Off)Upscaling PresetReported FPS (1% Lows)GPU Load & PowerCPU Power
Cyberpunk 2077 (Ultra, RT Off)DLAA (DLSS 4.0)78–91 FPS97%–98% / ~300W~65W
Cyberpunk 2077 (Ultra, RT Off)DLSS Quality143–146 FPS—94W
Cyberpunk 2077 (Ultra, RT Off)DLSS Balanced166–181 FPS——
Cyberpunk 2077 (Ultra, RT Off)DLSS Performance166–181 FPS—>101W
Cyberpunk 2077 (Ultra, RT Off)DLSS Ultra Perf.~166–181 FPS (no gain)68% / ~185W—
Witcher 3 (Novigrad, Ultra, RT Off)DLAA119 FPS95% / 292W—
Witcher 3 (Novigrad, Ultra, RT Off)DLSS Quality165 FPS88% / 241W79W–84W
Witcher 3 (Novigrad, Ultra, RT Off)DLSS Balanced / Perf. / Ultra160 / 155 / 161 FPSDown to 65% / 147W79W–84W
Witcher 3 (Novigrad, Ultra, RT Off)FSR Ultra Perf.168 FPS (86 1% low)61% / 144W~80W
Witcher 3 (Novigrad, RT Ultra + RR)DLAA~53 FPS98% / ~311W—
Witcher 3 (Novigrad, RT Ultra + RR)DLSS Quality / Balanced79–87 FPS~91%—
Witcher 3 (Novigrad, RT Ultra + RR)DLSS Perf. / Ultra Perf.~87 FPS (60–61 1% low)82% down to <76%—
With ray tracing off, DLSS Quality already pushed the Core i5-13600K straight into its ceiling at 165 FPS. Dropping to Balanced, Performance, or Ultra Performance actually drifted between 155 and 161 FPS while GPU draw fell all the way from 292W down to 147W. Switching to AMD FSR Ultra Performance in the identical dockside scene produced 168 FPS (with 86 FPS 1% lows) and dragged the RTX 4090 down to 61% load at 144W—proving that changing upscaling vendors does nothing to cure a processor bottleneck.
Flipping on RT Ultra with Ray Reconstruction flipped the script, at least initially. Heavy ray-traced lighting loaded the RTX 4090 back up, dropping native DLAA to ~53 FPS at 98% GPU load (~311W). Because the GPU was genuinely slammed again, DLSS Quality and Balanced delivered a massive leap to 79–87 FPS. Only after Performance and Ultra Performance drove GPU load down from 91% to below 76% did the frame rate flatten out around 87 FPS.
One important caveat: these figures come from XDA Developers' hands-on test bench at 1440p without controlled multi-run averages, driver version logs, or specific patch notes—so treat the exact FPS numbers as illustrative of one specific hardware pairing rather than universal law. Still, the pattern itself mirrors basic graphics-pipeline mechanics.
The 4K and Mid-Range Myth: Shifting the Ceiling Doesn't Break It​
It is tempting to brush these numbers off as a "flagship GPU at 1440p" problem. After all, most Windows gamers aren't pairing an RTX 4090 with a 1440p monitor. What happens on a 4K screen, or on a more modest mid-range desktop or laptop?
  • At 4K resolution, your graphics card renders more than twice as many pixels per frame as 1440p. Because GPU demand stays near 99% much longer, presets like Balanced and Performance keep adding real frames further down the menu before the CPU ever becomes the limiting factor.
  • On a mid-range GPU, lower raw shading horsepower keeps the GPU busy longer too—unless it is paired with an older or entry-level CPU at 1080p. At 1080p, pixel counts are light enough that a modern budget card can easily outrun an aging six-core processor in busy cities or ray-traced scenes (ray tracing itself adds CPU overhead when building and updating bounding-volume hierarchies for scene geometry).
  • And beware the resolution floor: Cranking Ultra Performance drops internal rendering to 720p at 4K, 480p at 1440p, and a painful 360p at 1080p. You end up sacrificing fine textures, foliage, and thin UI edges for zero measurable speed.
How to Diagnose a CPU Bottleneck on Windows 11​
Before you blame your processor or settle for blurry pixels, verify what is actually holding your rig back in a repeatable, busy game scene (such as a crowded town square rather than a quiet indoor hallway).
Step 1: Turn On a Live Windows Telemetry Overlay​
You don't need complicated benchmarking suites to spot a CPU ceiling. Windows 11 includes built-in monitoring, and both GPU vendors offer clean overlays:
  • Xbox Game Bar (Any GPU): Press Win + G while in-game, open the Widget menu, select Performance, and click the Pin icon so it stays visible during play. Click the FPS tab (and grant access if prompted, which may require a quick restart and Game Bar version 3.34.11002.0 or newer) to track FPS alongside GPU and CPU percentages.
  • Nvidia App: Press Alt + R to toggle the real-time statistics overlay, or Alt + Z to customize metrics—newer versions even let you display 1% low FPS alongside GPU utilization.
  • AMD Software: Adrenalin Edition: Open Adrenalin, search for Metrics, open the Overlay tab, and enable Show Metrics Overlay to watch FPS and GPU load live.
Step 2: Rule Out "Fake" Bottlenecks First​
Low GPU usage does not automatically prove your processor is too slow. Before drawing conclusions, double-check that you aren't hitting an artificial wall:
  1. Frame-rate caps and V-Sync: If V-Sync, Nvidia Max Frame Rate, Radeon Chill, or an in-game limiter is capping your output at 60, 120, or 144 FPS, your GPU will naturally throttle down once it hits that target. Turn caps off briefly while testing.
  2. Background Windows hogs: Check Task Manager (Ctrl + Shift + Esc) for browser tabs, game launchers downloading updates, or RGB/telemetry bloatware stealing main-thread cycles.
  3. Thermal or power throttling: Verify GPU clock speeds and Windows power modes; unusually low GPU clocks and board wattage alongside low utilization can point to overheating or a laptop power-saving profile rather than a CPU limit.
Step 3: Apply the Utilization Rule of Thumb—and Reclaim Your Sharpness​
With frame caps off, step down one upscaling preset at a time in the same scene and watch two numbers: FPS and GPU load. XDA Developers offers a handy heuristic—once GPU utilization dips below roughly 90% and your frame rate stops climbing between presets, dropping any lower won't buy you meaningful speed. Keep in mind that 90% isn't a hard scientific cutoff; engine quirks, memory bandwidth, or driver overhead can also depress GPU usage. The real smoking gun is flat FPS paired with falling GPU utilization and wattage.
When you hit that plateau, you actually have a golden opportunity to make your game look better for free:
  • Step back up the upscaling ladder: Move from Performance or Balanced back up to Quality—or even native DLAA / FSR Native AA—until GPU load climbs back toward 95%–99%. You get crisper visuals at the exact same frame rate.
  • Dial back CPU-heavy settings: Lowering crowd density, draw distance, physics simulation, or heavy ray-tracing geometry settings directly relieves main-thread pressure, unlike resolution scaling.
  • Turn up GPU-only eye candy: Higher texture filtering, volumetric fog, or ambient occlusion can often be bumped up into that unused GPU headroom without costing a single frame.
  • Weigh Frame Generation carefully: Unlike super-resolution upscaling, DLSS Frame Generation and FSR Frame Generation synthesize intermediate frames on the GPU, which can smooth visual motion even when the CPU is tapped out. Just remember the trade-off: generated frames add slight input latency and can feel uneven if your underlying native frame rate is already choppy.
Next time a sprawling PC port stutters in a crowded city, don't blindly mash the Performance preset until everything turns to mush. Pull up your overlay, check whether your GPU is actually working hard, and save your sharpness when the processor is the one calling the shots.
  1. Why cranking up DLSS or FSR stops giving you free FPS the moment your CPU falls behind XDA 2026-11-24T12:00:22+00:00
  2. nvidia.com nvidia.com
  3. gpuopen.com gpuopen.com
