A home entertainment setup shows a Wi-Fi router streaming 4K mountain scenery with signal and bandwidth graphics.
XDA Developers' Jasmine Mannan reports that one 5GHz channel-width change on her Wi-Fi 6 router ended the micro-stutter she saw while streaming high-bitrate video locally. This is a single first-person account. It doesn't name the router, the client, the channel or any before-and-after measurements. Treat it as a hypothesis worth testing, not a guaranteed fix. The same setting can also make things worse, as the evidence below shows.
A home entertainment setup shows a Wi-Fi router streaming 4K mountain scenery with signal and bandwidth graphics. What the author reported​
Mannan describes 4K Blu-ray remuxes and game or PC VR streams from a local server such as Plex. They stuttered, dropped frames and drifted out of audio sync despite a modern Wi-Fi 6 router. Her suggested fix is to open the router's 5GHz radio settings and change the channel width. Her options are 160MHz where hardware and surroundings allow it, or a clean, non-overlapping 80MHz block on a clear channel.
She also says remuxes can spike past 80 to 100+ Mbps in intense scenes. She says retransmissions after packet loss cause the buffering. She gives no measurements, packet captures or file details for either claim. The source also says routers ship with conservative defaults that leave "half" the performance unused. That is a broad claim and nothing in the evidence backs it.
What channel width does​
Channel width sets how much spectrum a connection occupies, which sets its peak physical-layer rate. Intel's Wi-Fi 6 rate table lists the theoretical maximum for a 2x2 link at about 1.2 Gbps at 80MHz and 2.4 Gbps at 160MHz. I'm taking those figures from Intel's published table, which the fetched Intel document shows for 2x2 80MHz and 160MHz modes. That is a doubling of the ceiling under ideal conditions. It is not a doubling of the speed you'll see in an app.
The figures also assume both ends cooperate. Intel's disclaimer says gigabit Wi-Fi speeds require optional 160MHz support and a similarly capable router and device. In practice, setting the router to 160MHz does nothing for a streaming box, headset or laptop that can't use it.
A fast link rate also isn't a stable one. For a video stream, what matters is whether the device sustains enough throughput for the stream's peaks. The headline link speed doesn't tell you that.
Why wider can backfire: DFS and interference​
The strongest counterweight to the "wider is better" framing is the interference trade-off. Intel's Wi-Fi troubleshooting guide tells readers who have reliability problems to try 40MHz on 5GHz. It warns that 80MHz and 160MHz channels will interfere with, and receive interference from, many more sources than 40MHz.
The second catch is radar-sharing channels. In the US, XDA's own recent piece on turning 160MHz off says a 160MHz channel on 5GHz almost always reaches into DFS channels. That article says a router that thinks it hears radar must leave within 10 seconds and stay away for 30 minutes. That author blamed repeated channel hops on 160MHz and reported steadier Wi-Fi after turning it off. A reader comment on that piece disputes the diagnosis and argues that DFS, not 160MHz itself, was the problem. So there is a real disagreement about cause, but the practical lesson is the same.
Dong Knows' Wi-Fi 6 explainer says there are only two 160MHz channels on the 5GHz band, and both need DFS. It also says using DFS can cause occasional brief disconnections.
Vendor behavior varies too. D-Link's support page for one Wi-Fi 6 router says it doesn't switch to DFS channels by default, so you must enable DFS to get 160MHz. It adds that a network using 160MHz that hits a DFS event drops to 80MHz until DFS is available again. That is one vendor and one model line, so check your own router's documentation.
If you stream locally, a radar-triggered channel change could look much like the stutter you're trying to fix.
Local streaming has other suspects​
Wi-Fi isn't the only cause of stutter. Plex's support documentation separates local from remote streaming quality. It notes that on a wired connection you can usually pick the highest quality. On Wi-Fi you may need a lower setting, depending on how fast or strong your signal is. Plex also says lower quality settings raise the chance the server must transcode, so the server needs enough CPU. Stutter can therefore come from the server, the client or the wireless path. Mannan doesn't say she ruled the other two out.
A cautious way to test it​
Router menus differ a lot, so I'm not giving click-by-click steps. Here is a general procedure:
  1. Record a baseline. Note the router's current 5GHz width and channel. If the client shows a negotiated link rate, note that too. Reproduce the stutter with the same file in the same room.
  2. Check both ends. Confirm that the router and the playback device each support the width you want.
  3. Survey the air. Use a phone Wi-Fi analyzer, as the author suggests, and take readings where you actually watch. Intel's guide says a free analyzer can show which channels are least used. If you can't find an empty one, it advises picking the channel with the weakest neighboring signal.
  4. Change one thing at a time. Try a clear 80MHz channel, or 160MHz if your hardware and local spectrum suit it. Intel's guide suggests non-DFS channels if you see drops or the network disappears. In the US it lists those as outside channels 50-144.
  5. Repeat the same playback. Watch the toughest scenes and compare stutter. If the new setting is worse, revert and try a narrower width or another channel. A single smooth movie isn't proof of a fix, because neighbors' Wi-Fi use changes through the day.
  6. Keep extenders and mesh nodes on different channels from the main router. Intel's guide warns that radios set to the same channel can conflict with each other.
If you can, skip the argument​
Intel's 5GHz/6GHz explainer notes that 5GHz offers only a few 80MHz channels, and some may be restricted at times because of radar. It says 6GHz offers up to seven 160MHz channels, but only to Wi-Fi 6E devices. The gap is large enough that a Wi-Fi 6E or Wi-Fi 7 router and client, or simply Ethernet for a fixed media box, may beat any 5GHz tweak.
Bottom line​
  • Channel width is a legitimate thing to check when local streams stutter. A change worked for one XDA writer.
  • Wider means a higher peak rate but more exposure to interference and, in the US, often DFS channels.
  • Check client support, and test one change at a time against the same content.
  • Treat the "completely stops stutter" result as one reader's outcome, not a rule.
  1. I changed one channel width setting on my Wi-Fi 6 router, and local streaming stutter completely stopped XDA 2026-10-23T18:31:22+00:00
  2. Guide to Configure Wi-Fi Channels and Channel Widths to Improve... intel.com
  3. How do I choose the right Streaming Quality in an app? | Plex Support support.plex.tv
