This applies to any PC, Windows or otherwise. Nothing here is specific to a Windows version.
Why a USB hub can upset a wireless mouse
USB 3.0 and its faster successors run at high data rates and spread a lot of noise across the radio spectrum. A technical white paper hosted by the USB Implementers Forum (USB-IF), dated April 2012, set out the problem. The noise from USB 3.0 data signaling can affect radio receivers whose antennas sit close to a USB 3.0 device or connector. The paper's stated purpose is to raise awareness of radio interference to 2.4 GHz wireless devices caused by certain USB 3.0 devices and cables.
The paper's own measurements, as summarized in the evidence brief for this story, show how this plays out:
- Noise floor: With an external USB 3.0 hard drive attached to a notebook, the noise floor in the 2.4 GHz band rose by nearly 20 dB.
- Mouse behavior: The mouse worked normally at two feet from the notebook. It lagged at three and five feet while the drive was connected.
- Activity doesn't matter: The impact was the same whether data was being written or the connection was simply established.
- Other devices: A USB 3.0 flash drive had a similar effect.
- Placement: Moving the dongle to the opposite side of the notebook on a USB 2.0 extension cable restored normal mouse response at all tested distances. With the dongle stacked directly above the USB 3.0 port, the mouse didn't respond at all.
The authors conclude that moving the receiver farther from USB 3.0 ports and devices can reduce the noise's impact, but not necessarily eliminate it.
These are results from one test setup. They don't prove that every USB 3.x hub will disrupt every mouse.
What manufacturers say
Several vendors document the same issue.
- Logitech: Its support page says a 2.4 GHz wireless mouse, keyboard or headset may behave erratically when a USB 3.0 peripheral is plugged into the same PC, especially a remote hard drive or flash drive. It lists these symptoms:
- Delayed response to mouse or keyboard input.
- Missing keystrokes or mouse commands.
- Shorter operating distance between the device and its receiver.
- Anker: Its mouse-lag guide says USB 3.0 ports can interfere with 2.4GHz wireless devices and calls it a known issue. It suggests plugging the receiver directly into the computer instead of a USB 3.0 hub, or using a USB 2.0 extension cable.
- ASUS: Its support FAQ says placing the wireless dongle away from the USB 3.0 ports can reduce the impact, though it doesn't eliminate it completely.
- MSI: Its guidance, updated August 10, 2026, makes the same recommendations. It also cautions that not all USB 3.x devices cause interference, because shielding, cable design, location and distance all matter. I couldn't retrieve that page directly, so this comes from the research notes rather than my own reading of it.
How to test before you buy anything
Interference is only one possible cause of a laggy mouse. Work through these steps in order.
- Check how the receiver is connected. Note whether it's in a hub, a dock, or a port on the PC itself. Anker lists this as its first step.
- Unplug everything else from the hub. Test the mouse again. If it improves, the hub or one of the other devices on it is the likely cause. This doesn't tell you which one.
- Move the receiver to a port on the PC. On a desktop, a front-panel port is a sensible choice. This is the How-To Geek author's advice, and the reasoning is that a whole case between mouse and receiver doesn't help.
- Try a port on the opposite side of a laptop. Logitech recommends putting the receiver as far from the USB 3.0 connector as possible. It also advises using the USB 2.0 port nearest the mouse.
- Rule out the mouse itself. Anker suggests fresh batteries and trying the mouse on another computer.
- Look beyond USB if the problem persists with no hub. The How-To Geek author points to a nearby router or mesh node as another possible source of interference.
The cheap fix: a USB extension cable
A plain USB 2.0 extension cable lets you put the receiver in a better spot, away from the PC and its USB 3.x ports and cables. It can also bring the receiver close to the mouse, which Logitech recommends.
- Length: The author notes that USB 2.0 cables can run up to 16.4 feet. The sources don't give a required length. You don't need the maximum. Getting the receiver a foot or two from the mouse and keyboard, ideally with a clear line of sight, is the idea.
- Several receivers: The author uses an extension cable with a small USB splitter on the end. That holds a Logitech receiver and a Bluetooth dongle together on the desk. It's his own setup, not a vendor recommendation.
- Keep expectations realistic: ASUS says moving the dongle reduces the effect but doesn't eliminate it.
Bluetooth isn't a guaranteed escape
It's tempting to assume that switching to Bluetooth avoids the problem. It doesn't, because Bluetooth sits in the same 2.4 GHz band.
- Bluetooth dongles: A dongle plugged into a USB 3.0 hub can run into the same trouble. The same extension-cable approach applies.
- Built-in Bluetooth: The author suggests moving the hub farther from the computer, or using a longer hub cable, to cut stutters caused by nearby flash drives or hard drives.
- What the research says: The USB-IF paper reports a similar impact on Bluetooth performance. It says the Bluetooth test results weren't shown. So treat this as a possibility, not a certainty.
The author also says proprietary dongles like Logi Bolt or Unifying work better than Bluetooth in his experience. That's his opinion, not something the manufacturer documents establish. Both kinds of radio sit in the same vulnerable band.
What this does and doesn't prove
- Not every hub is a problem. If your mouse works well, nothing needs changing. MSI says as much.
- The hub isn't always the culprit. A fast external drive or a poorly shielded cable can be the noise source.
- The 2012 paper is old, but the guidance is current. Logitech, Anker and ASUS still publish it, and MSI updated its own guidance in 2026.
- Don't spend money on a diagnosis you haven't tested. Unplugging the other devices and moving the receiver costs nothing and takes a couple of minutes.
If the lag remains after all of this, you're probably dealing with something else, such as a dying battery, a bad sensor surface, or a failing mouse.
- Your USB hub can sabotage your wireless mouse: here’s the cheap fix How-To Geek · 2026-10-24T21:30:17+00:00
- (NUC) Wireless Keyboard or Mouse Has a Short Connection Range | Official Support | ASUS USA asus.com
- Wireless product not working properly when also using a USB 3.0 device – Logitech Support + Download support.logi.com
