Notice what isn’t in that list of headlines: a discrete GeForce RTX GPU, preinstalled memory, an included SSD, or a Windows license. As barebone systems, the MI658 and MI678 leave RAM, storage, and operating system choices to the buyer or IT integrator. And while ZOTAC’s initial specifications have surfaced, neither pricing, regional availability, nor an exact shipping schedule has been disclosed yet.
Still, for Windows system builders, digital signage integrators, and IT administrators eyeing ultra-slim endpoints, the hardware recipe inside this 149.5 × 149.5 × 28.5 mm enclosure marks a notable shift in ZOTAC’s ZBOX edge lineup.
Inside the Silicon: Core Ultra 5 335 vs. Core Ultra 7 365
According to LinuxGizmos, the MI658 and MI678 share virtually identical hardware apart from their processors: the MI658 steps out with an Intel Core Ultra 5 335, while the MI678 moves up to an Intel Core Ultra 7 365. Both chips belong to Intel’s Core Ultra Series 3 ("Panther Lake") family fabricated on Intel’s 18A process, pairing four Cougar Cove Performance cores with four Darkmont Low-Power Efficient cores for an 8-core, 8-thread layout.
On paper, the separation between the two models comes down to clock speed and a slight bump in NPU throughput:
- ZBOX edge MI658 (Intel Core Ultra 5 335): 8 cores / 8 threads (4P + 4 LP-E), 2.2 GHz P-core base clock and up to 4.6 GHz turbo, 12 MB Intel Smart Cache, 25W base / 55W maximum turbo power, Intel Graphics (4 Xe cores, up to 40 TOPS), and an Intel AI Boost NPU rated up to 47 TOPS (INT8).
- ZBOX edge MI678 (Intel Core Ultra 7 365): 8 cores / 8 threads (4P + 4 LP-E), 2.4 GHz P-core base clock and up to 4.8 GHz turbo, 12 MB Intel Smart Cache, 25W base / 55W maximum turbo power, Intel Graphics (4 Xe cores, up to 40 TOPS), and an Intel AI Boost NPU rated up to 49 TOPS (INT8).
Because both chips carry the exact same 8-core topology, 12 MB cache, and 25W-to-55W power envelope, the real-world gap between the MI658 and MI678 in everyday Microsoft 365, browser, and single-threaded office tasks is likely to be modest. Unless an organization specifically needs that extra 200 MHz peak clock ceiling on the Core Ultra 7 365—or requires the higher-tier SKU for standardized fleet procurement—the Core Ultra 5 335 in the MI658 looks like the value play for general-purpose Windows 11 desktops.
Generational Shift: Comparing the MI658/MI678 Against the ZBOX edge MI656/MI676
To appreciate what ZOTAC changed here, it helps to compare these newcomers against ZOTAC’s own official specifications for the previous-generation ZBOX edge MI656 and MI676, which used Intel Core Ultra Series 2 H-series silicon (Core Ultra 5 225H and Core Ultra 7 255H).
| Feature | ZBOX edge MI656 / MI676 (Prior Gen) | ZBOX edge MI658 / MI678 (New) |
| Processors | Core Ultra 5 225H (14C) / Core Ultra 7 255H (16C) | Core Ultra 5 335 (8C) / Core Ultra 7 365 (8C) |
| Memory Support | 2× DDR5-5600/5200 SO-DIMM, up to 64 GB | 2× DDR5-6400/5600 SO-DIMM, up to 96 GB |
| Primary Storage | 1× M.2 NVMe PCIe 4.0 x4 | 1× M.2 2280 PCIe 5.0 x4 NVMe |
| Secondary Storage | 1× M.2 NVMe PCIe 4.0 x4 / SATA | 1× M.2 2240 PCIe 4.0 x4 NVMe |
| Wired Networking | 1× Gigabit Ethernet | 1× 2.5GbE (IEEE 1588 PTP) + 1× Gigabit Ethernet |
| Wireless | Wi-Fi 7, Bluetooth 5.4 | Wi-Fi 7 (802.11be), Bluetooth 5.4 |
| USB-C / Thunderbolt | 1× USB 3.2 Gen 2 Type-C | 2× Thunderbolt 4 (USB-C) |
| Display Ceiling (HDMI) | HDMI 2.1 up to 4096 × 2160 @ 60Hz | HDMI 2.1 up to 8K @ 60Hz |
Notice the trade-off hiding in that table. In connectivity, memory bandwidth, storage speed, and I/O density, the MI658 and MI678 run circles around the MI656 and MI676: you move from 64 GB to 96 GB of faster DDR5-6400 RAM, pick up PCIe 5.0 SSD support, gain dual Ethernet (with 2.5GbE leading), and jump from a single 10Gbps USB-C port to dual Thunderbolt 4.
Yet in raw CPU core count, the H-series chips inside the older MI656 (14 cores) and MI676 (16 cores) actually had more cores than the 8-core Series 3 processors in the MI658 and MI678. Why the switch? Because the Core Ultra 5 335 and Core Ultra 7 365 are vPro-capable efficiency-oriented parts built around much stronger dedicated NPUs (47–49 TOPS) and lower base/turbo power envelopes. ZOTAC is clearly steering this sub-liter "edge" tier toward managed enterprise endpoints, edge inference, and multi-screen signage rather than brute-force multi-core workstation rendering. Buyers needing discrete GPU horsepower or higher core-count muscle have ZOTAC’s larger MAGNUS systems to look at instead.
Expansion, Displays, and the M.2 2240 Catch
In a 28.5 mm chassis, expansion always involves compromises, so barebone buyers should read the fine print before ordering parts:
- Memory Flexibility: Two standard SO-DIMM slots support up to 96 GB of DDR5-6400 or DDR5-5600 memory. That gives home-labbers and developers serious breathing room for local VMs or containerized workloads—assuming dual-channel modules are installed to keep integrated graphics bandwidth healthy.
- Mixed M.2 Lengths: The primary M.2 2280 slot runs at PCIe 5.0 x4, while the secondary slot is an M.2 2240 PCIe 4.0 x4 bay. If you have a stack of spare 2280 SSDs sitting in a desk drawer, only one will fit. M.2 2240 drives are shorter and far less common at retail than 2280 or 2230 drives, so verify drive length before adding a second SSD. Also keep in mind that PCIe 5.0 x4 defines the slot’s interface specification; actual sustained speeds in a 0.64-liter enclosure will depend on the SSD controller and chassis thermals.
- Quad-Display Output: Around the chassis, ZOTAC fits one HDMI 2.1 port rated up to 8K at 60Hz, one DisplayPort 1.4 port rated up to 4096 × 2160 at 60Hz, and two front-facing Thunderbolt 4 ports with DisplayPort tunneling, supporting up to four independent monitors. As with any multi-display Intel Graphics setup, simultaneous resolution and refresh-rate ceilings across all four screens will depend on monitor capabilities and cabling, so digital-signage planners should validate exact 4K/60Hz or 8K topologies once ZOTAC publishes full user manuals.
- Wired and Wireless I/O: Alongside Wi-Fi 7 and Bluetooth 5.4, ZOTAC splits wired networking across a 2.5GbE port with IEEE 1588 Precision Time Protocol (PTP) support and a secondary Gigabit Ethernet jack. IEEE 1588 PTP matters most in industrial automation, synchronized AV/signage, and deterministic edge networking, while dual NICs remain a perennial favorite for segmented corporate/OT networks or homelab routing. Rounding out the front and rear panels are three 10Gbps USB 3.2 Gen 2 Type-A ports (one front, two rear) and a front 3.5mm audio combo jack.
- Power Considerations: ZOTAC bundles a 90W external power brick, a Wi-Fi antenna, VESA mounting hardware, and a driver USB flash drive in the box. LinuxGizmos also notes USB-C Power Delivery input support among the platform capabilities, though the reported specs do not confirm what minimum USB-C PD wattage is required to run the system without throttling under a 55W turbo load.
Windows 11, Intel vPro Enterprise, and the Copilot+ PC Reality Check
For WindowsForum readers, the two biggest questions around these barebone boxes are enterprise manageability and Windows AI readiness.
On the IT administration side, Intel vPro Enterprise support is a major differentiator. Intel’s official product specifications for both the Core Ultra 5 335 and Core Ultra 7 365 confirm support for Intel Active Management Technology (AMT), Intel Threat Detection Technology (TDT), Intel Standard Manageability (ISM), Intel Remote Platform Erase (RPE), and Intel One-Click Recovery. In plain English, that means out-of-band remote management—power cycling, BIOS-level troubleshooting, and remote wiping—even when a behind-the-monitor kiosk or branch-office desktop refuses to boot into Windows. Intel’s driver downloads for these Series 3 chips already list NPU packages covering Windows 11 versions 23H2 through 26H1, alongside Arc/Intel Graphics drivers for Windows 11 and Windows 10 (22H2).
Now for the Copilot+ PC caveat. Microsoft’s official hardware guidelines require a 40+ TOPS NPU, at least 16 GB of RAM, 256 GB of storage, and Windows 11 version 24H2 or newer to unlock Copilot+ PC experiences such as Recall, Click to Do, Cocreator, and enhanced Live Captions. Features like Recall further stipulate Secured-core PC compliance.
On silicon alone, both ZOTAC models clear the NPU hurdle comfortably—47 TOPS on the MI658 and 49 TOPS on the MI678, with official support for WindowsML, ONNX Runtime, OpenVINO, WebNN, and Windows Studio Effects. However, because the MI658 and MI678 are barebone kits shipped without RAM, storage, or Windows preinstalled, they are not turnkey Copilot+ PCs out of the box. Anyone purchasing them specifically for Microsoft’s gated Copilot+ PC features will need to supply at least 16 GB of DDR5 and a 256 GB+ NVMe SSD, install a current Windows 11 build, and verify whether ZOTAC’s production BIOS and firmware meet Microsoft’s Secured-core requirements.
Bottom Line for Builders and IT Buyers
Without pricing or thermal/acoustic benchmarks in hand yet, it is too early to crown the ZBOX edge MI658 and MI678 as the value kings of the 2026 mini PC market. Even so, ZOTAC’s spec sheet hits an unusually practical sweet spot for Windows power users and commercial IT teams: up to 96 GB of DDR5-6400 memory, a PCIe 5.0 x4 SSD lane, dual Thunderbolt 4, quad-display support, 2.5GbE with PTP plus 1GbE, and full Intel vPro Enterprise manageability in a VESA-mountable 28.5 mm slab.
If your workload demands sustained heavy multi-core rendering or discrete GPU acceleration, look elsewhere. But if you want an ultra-thin, remotely manageable Windows 11 endpoint—or a quiet, high-bandwidth barebone node that disappears behind a monitor—the MI658 and MI678 are two models worth watching once ZOTAC reveals retail availability and street pricing.
- ZOTAC Unveils ZBOX edge MI658 and MI678 Mini PCs - Wisevoter Wisevoter · 2026-11-26T20:30:41+00:00
- ZOTAC fits Core Ultra Series 3 processors into 0.64-liter mini PCs linuxgizmos.com
- zotac.com zotac.com
