Hi!
I've searched help with my problems, but didn't seem to find anything helpful. So here they are:
1. Sometimes, when I click the minimize / close button on a window, they both start flickering, and don't respond. The issue is solved by minimizing / closing the window from the taskbar. Has anyone encountered this, and is there a permanent fix? It's annoying to go all the way down for working with the window.
2. Also, I often focus on a window by clicking the title bar. However, as I use mostly maximized windows, Aero Snap un-maximizes the window. I've found how to disable it entirely, but I wonder, is there a way to only disable one component of it? (the others are very helpful).
Note that I use Windows 7 Professional x64.
Thank you, and I apologise if it has been covered before.
Regards,
Viorel
Regards,
Viorel
