7100 64 Bit not using all 4GB of memory
Discussion in 'Windows 7 Hardware' started by Dark Light, Aug 13, 2009.
  1. Dark Light
    Dark Light New Member
    Jan 11, 2009
    56
    0
    I have Windows 7 build 7100 64 Bit, I have 4GB of memory. I have disabled virtual memory, when my memory usage reaches 2.66 GB a message comes up saying I should close a app. I have been playing Crysis and when my total system usage reaches 3GB Crysis crashes, it like Windows 7 is not using the last 1GB of memory.
  2. textureDnB
    textureDnB New Member
    Jun 29, 2009
    652
    6
    I would re instate pagefile bud. That was inadviseable in XP but sometimes would help. Windows seven keeps way too much stuff in memory for easy access and will not put you in an out of memory situation it will crash apps if it needs to recover memory. I am currently using 2.5 GB of total memory (pagefile + RAM) evenly split I am running into no pagefile access slowdown even under MUCH high memory usage. If i were to disable paging i would immediately be out of RAM in my current situation. If your really worried about hitting your pagefile too hard you could limit it's size to (for windows seven) an insanely small 750 MB this would give you a little cushion for windows to work with but i still believe that you will be better off with a larger even system managed pagefile.
    Finally if you INSIST your better off without a pagefile you may want to disable Superfetch which will prevent Windows from filling RAM unnecessarily.
  3. Dark Light
    Jan 11, 2009
    56
    0
    Thanks, but that still doesn't explain why Windows 7 isn't using all the memory available.
  4. textureDnB
    Jun 29, 2009
    652
    6
    It will do this before you use up a specified percentage of your memory i am not aware of the percentage nor if it this behavior is changeable just that it exists. In windows opinion (i think i agree) it's better to crash 1 app a little early than it is to crash the whole OS a little later. Hope this helps a bit.
    #4 textureDnB, Aug 13, 2009
  5. BishopLord
    BishopLord New Member
    Aug 9, 2009
    110
    2
    Someone correct me if I'm wrong, but isn't the last GB of memory reserved for the video memory? (even if the card has it's own memory)
    I just did a quick Google search and this sort of backs up what I'm saying: Windows 7 x64 memory specifics?
  6. Radenight
    Radenight New Member
    Nov 16, 2008
    4,525
    108
    Does Windows 7 report that you actually have 4GB's installed? If so, then it's not that Win 7 isn't using the whole 4GB's, it's just distributing it as Windows sees fit.. ;) If it doesn't say you have a total of 4GB's installed then perhaps you have a bad stick of ram.. ;)
  7. Dark Light
    Jan 11, 2009
    56
    0
    It does say that there is 4GB installed.
  8. kemical
    kemical Windows Forum Admin
    Staff Member Premium Supporter Microsoft MVP
    Aug 28, 2007
    32,093
    1,598
    As Radenight says you may have a bad stick...(even though the 4GB is showing). You can test your memory using this utility: Memtest86+ - Advanced Memory Diagnostic Tool
    Remember to test one stick at a time...If you test them all together a bad stick may be missed.
Share This Page
Loading...
