Windows 7 7260 Is Out
See next post.....
davehc
Microsoft MVP
Please read the forum rules. No links to leaks please.
X86 7260 Out in VHD and ISO Flavors
My bad...... (on previous post)
No links just letting you know....... Maybe X64 is forthcoming. Haven't seen it yet.:razz:
So far the leaked 7260 is only "officially" a 32-bit VHD and a modified ISO (of that VHD) by SoLoR just like he did for 7232. I'm hearing that soon (tomorrow? day after?) 7261 will be leaked (64-bit). It doesn't really matter if it's also a VHD since SoLoR will have an ISO up in a few hours after leaking anyway. :)
How is there 7261 if 7260 is the RTM? Also won't rtm require new keys are its not rc branch no more. Cause i hope the rc keys did work since i could use them on it. Since i plan on getting the last build before final rtm which is free and works with rc codes then ill stick with it until it expires
Also most things i have seen are fake 7260.
gws
Here is the info for 7261
6.1.7261.0.win7_rtm.090615-1900 Compiled of the 15th
RTM win7_rtm branch :
6.1.7260.0.win7_rtm.090612-2110
(June 15-19 to continue to assemble. That's the first candidate for the final assembly of Windows 7)
Final RTM Re-build 7300 (Expected)
gws
whoosh
Cooler King
#7
Thanks GWS very nicely done info :D
gws
#8
All I need now is the RTM 7300 :D
gws
whoosh
Cooler King
#9
Yes I would be happy with that one to :D
gws
#10
I will be watching for everyone here and help with what I can :razz:
These next few days will be real exciting
gws
whoosh
Cooler King
#11
Yes nearly there after so many builds . Seems like a short time though because of the constant movment between builds .
Now At the escrow stage :D
#12
7260 X86 Quirk
Seems that 7260 X86 thinks that it is older than 7201 X86 and one can't update. You can do a clean install tho. In times past, you could hack the cversion.ini file to avoid this but M$ has found another way to keep one from upgrading. Now, if only 7261 wouldn't cause the same problem.:mad:
gws
#13
Busydog
Check your PM
gws :)
#14
Again, clean install wins. I keep all my files on my external HDD so all I have to go through after a clean install (which happens at least once a week now...) is reinstalling my programs. 7300 is the build that I'm actually going to "permanently" install.
