Windows 7 a BSOD after 10 min long shutdown
smutten
so yesterday i got a BSOD, i shut of my computer the normal way but it stood there for 10 to 20 minnutes before finaly giving me a BSOD, i couldnt get to read what it said but i do have the things it told me on startup today, so infodump:
exact specs of all my hardware (nothing changed):
HP pavilion slimline s5130sc
dump files and info on bootup:
Thanks for all of you awesome people helping out because you can :)
  • BSOD info.zip
BugCheck A, {8, 2, 0, fffff8000301c33e}
Unable to load image \SystemRoot\system32\DRIVERS\Rt64win7.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Rt64win7.sys
*** ERROR: Module load completed but symbols could not be loaded for Rt64win7.sys
Probably caused by : Rt64win7.sys ( Rt64win7+10bb8 )
Followup: MachineOwner
1: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000008, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff8000301c33e, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff8000330b0e0
 0000000000000008
CURRENT_IRQL:  2
FAULTING_IP:
hal!HalpDmaFreeMapRegisters+1a
fffff800`0301c33e 488b5a08        mov     rbx,qword ptr [rdx+8]
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  System
TRAP_FRAME:  fffff88002faf800 -- (.trap 0xfffff88002faf800)
rax=fffff88002faf930 rbx=0000000000000000 rcx=fffffa8004dad318
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8000301c33e rsp=fffff88002faf990 rbp=0000000000000b00
 r8=fffff88002faf930  r9=fffff80003045c60 r10=ffffffffffffffe8
r11=0000000000000002 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz ac po nc
hal!HalpDmaFreeMapRegisters+0x1a:
fffff800`0301c33e 488b5a08        mov     rbx,qword ptr [rdx+8] ds:00000000`00000008=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800030d2b69 to fffff800030d3600
STACK_TEXT:
fffff880`02faf6b8 fffff800`030d2b69 : 00000000`0000000a 00000000`00000008 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`02faf6c0 fffff800`030d17e0 : 00000000`00000030 00000000`00000000 00000000`00000000 fffffa80`049a0d00 : nt!KiBugCheckDispatch+0x69
fffff880`02faf800 fffff800`0301c33e : fffffa80`042edd50 fffffa80`042edd50 fffffa80`05b768d0 00000000`00000001 : nt!KiPageFault+0x260
fffff880`02faf990 fffff800`0301eb82 : fffffa80`04dad2a0 00000000`00000000 fffffa80`04dad2a0 00000000`0000060b : hal!HalpDmaFreeMapRegisters+0x1a
fffff880`02faf9c0 fffff800`0301e825 : fffffa80`05abe200 00000000`00000b60 00000000`00000000 fffffa80`068a1b20 : hal!IoFreeMapRegisters+0x62
fffff880`02fafa30 fffff880`016d98a1 : fffffa80`068a1a50 fffffa80`068a1920 fffffa80`05a10f80 fffffa80`042edd50 : hal!HalPutScatterGatherList+0xd5
fffff880`02fafa90 fffff880`03da6bb8 : fffff800`03278501 fffffa80`05a10f80 00000000`00000000 fffff800`03278501 : ndis!NdisMFreeNetBufferSGList+0x31
fffff880`02fafad0 fffff800`03278501 : fffffa80`05a10f80 00000000`00000000 fffff800`03278501 00000000`00000000 : Rt64win7+0x10bb8
fffff880`02fafad8 fffffa80`05a10f80 : 00000000`00000000 fffff800`03278501 00000000`00000000 00000000`00000000 : nt!ExpWorkerSwapinMutex+0x21
fffff880`02fafae0 00000000`00000000 : fffff800`03278501 00000000`00000000 00000000`00000000 00000000`00000001 : 0xfffffa80`05a10f80
STACK_COMMAND:  kb
FOLLOWUP_IP:
Rt64win7+10bb8
fffff880`03da6bb8 ??              ???
SYMBOL_STACK_INDEX:  7
SYMBOL_NAME:  Rt64win7+10bb8
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: Rt64win7
IMAGE_NAME:  Rt64win7.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  49a65b0d
FAILURE_BUCKET_ID:  X64_0xA_Rt64win7+10bb8
1: kd> !analyze -v
Arguments:
Arg4: fffff8000301f33e, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff8000330e0e0
0000000000000008
CURRENT_IRQL: 2
FAULTING_IP:
fffff800`0301f33e 488b5a08 mov rbx,qword ptr [rdx+8]
BUGCHECK_STR: 0xA
TRAP_FRAME: fffff88007279800 -- (.trap 0xfffff88007279800)
rax=fffff88007279930 rbx=0000000000000000 rcx=fffffa8004d84378
rip=fffff8000301f33e rsp=fffff88007279990 rbp=0000000000000e00
r8=fffff88007279930 r9=fffff80003048c60 r10=ffffffffffffffe0
fffff800`0301f33e 488b5a08 mov rbx,qword ptr [rdx+8] ds:00000000`00000008=????????????????
LAST_CONTROL_TRANSFER: from fffff800030d5b69 to fffff800030d6600
STACK_TEXT:
fffff880`072796b8 fffff800`030d5b69 : 00000000`0000000a 00000000`00000008 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`072796c0 fffff800`030d47e0 : 00000000`0000002e 00000000`00000000 fffff880`072799e0 fffffa80`04f6e470 : nt!KiBugCheckDispatch+0x69
fffff880`07279800 fffff800`0301f33e : fffffa80`05c3ed50 fffffa80`05c3ed50 fffffa80`05a518d0 00000000`00000001 : nt!KiPageFault+0x260
fffff880`07279990 fffff800`03021b82 : fffffa80`04d84300 00000000`00000000 fffffa80`04d84300 00000000`000005d3 : hal!HalpDmaFreeMapRegisters+0x1a
fffff880`072799c0 fffff800`03021825 : fffffa80`058dc780 00000000`00000e70 00000000`00000000 fffffa80`06bcfe30 : hal!IoFreeMapRegisters+0x62
fffff880`07279a30 fffff880`016ff8a1 : fffffa80`06bcfd60 fffffa80`06bcfc30 fffffa80`04dd3c20 fffffa80`05c3ed50 : hal!HalPutScatterGatherList+0xd5
fffff880`07279a90 fffff880`03c34bb8 : fffff800`0327b501 fffffa80`04dd3c20 00000000`00000000 fffff800`0327b501 : ndis!NdisMFreeNetBufferSGList+0x31
fffff880`07279ad0 fffff800`0327b501 : fffffa80`04dd3c20 00000000`00000000 fffff800`0327b501 00000000`00000000 : Rt64win7+0x10bb8
fffff880`07279ad8 fffffa80`04dd3c20 : 00000000`00000000 fffff800`0327b501 00000000`00000000 fffff880`07279c00 : nt!ExpWorkerSwapinMutex+0x21
fffff880`07279ae0 00000000`00000000 : fffff800`0327b501 00000000`00000000 fffff880`07279c00 00000000`00000001 : 0xfffffa80`04dd3c20
STACK_COMMAND: kb
FOLLOWUP_IP:
Rt64win7+10bb8
fffff880`03c34bb8 ?? ???
DRIVERS
fffff800`00ba9000 fffff800`00bb3000   kdcom    kdcom.dll    Tue Jul 14 02:31:07 2009 (4A5BDFDB)
fffff800`0301a000 fffff800`03063000   hal      hal.dll      Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff800`03063000 fffff800`0363f000   nt       ntkrnlmp.exe Sat Feb 27 07:55:23 2010 (4B88CFEB)
fffff880`00c00000 fffff880`00c2a000   cdrom    cdrom.sys    Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00c2a000 fffff880`00c3e380   pcouffin pcouffin.sys Tue Dec 05 14:39:30 2006 (457584A2)
fffff880`00c43000 fffff880`00c87000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`00c87000 fffff880`00c9b000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00c9b000 fffff880`00cf9000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00cf9000 fffff880`00db9000   CI       CI.dll       Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`00db9000 fffff880`00de8000   SCSIPORT SCSIPORT.SYS Tue Jul 14 01:01:04 2009 (4A5BCAC0)
fffff880`00de8000 fffff880`00e00000   BTHUSB   BTHUSB.sys   Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`00e00000 fffff880`00e0e000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`00e15000 fffff880`00eb9000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00eb9000 fffff880`00ec8000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00ec8000 fffff880`00fee000   sptd     sptd.sys     Sun Oct 11 21:55:14 2009 (4AD24632)
fffff880`00fee000 fffff880`00ff7000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`01000000 fffff880`0105c000   volmgrx  volmgrx.sys  Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`0105c000 fffff880`01064000   intelide intelide.sys Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01064000 fffff880`01074000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01074000 fffff880`0108e000   mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`0108e000 fffff880`01097000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01097000 fffff880`010c1000   ataport  ataport.SYS  Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff880`010c1000 fffff880`010cc000   amdxata  amdxata.sys  Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`010cc000 fffff880`010e7000   USBSTOR  USBSTOR.SYS  Tue Jul 14 01:06:34 2009 (4A5BCC0A)
fffff880`010e8000 fffff880`010f1000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`010f7000 fffff880`0114e000   ACPI     ACPI.sys     Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`0114e000 fffff880`0115b000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`0115b000 fffff880`0118e000   pci      pci.sys      Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`0118e000 fffff880`01198000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01198000 fffff880`011ad000   partmgr  partmgr.sys  Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`011ad000 fffff880`011c2000   volmgr   volmgr.sys   Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`011c2000 fffff880`011fc000   fvevol   fvevol.sys   Sat Sep 26 03:34:26 2009 (4ABD7DB2)
fffff880`01200000 fffff880`0124c000   volsnap  volsnap.sys  Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`0124c000 fffff880`0127c000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`0127c000 fffff880`01283000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`01283000 fffff880`012cf000   fltmgr   fltmgr.sys   Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`012cf000 fffff880`012e3000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`012e3000 fffff880`012ef040   PxHlpa64 PxHlpa64.sys Tue Oct 20 19:08:42 2009 (4ADDFCAA)
fffff880`012f0000 fffff880`0134e000   msrpc    msrpc.sys    Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`0134e000 fffff880`013c1000   cng      cng.sys      Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`013c1000 fffff880`013fb000   rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`01400000 fffff880`01416000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0141c000 fffff880`015bf000   Ntfs     Ntfs.sys     Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`015bf000 fffff880`015d9000   ksecdd   ksecdd.sys   Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`015d9000 fffff880`015ea000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`015ea000 fffff880`015f4000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01600000 fffff880`01660000   NETIO    NETIO.SYS    Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`01660000 fffff880`0168b000   ksecpkg  ksecpkg.sys  Fri Dec 11 06:03:32 2009 (4B21E0B4)
fffff880`0168b000 fffff880`016d5000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`016d7000 fffff880`017c9000   ndis     ndis.sys     Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`017c9000 fffff880`017d1000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`017d1000 fffff880`017e3000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`017e3000 fffff880`017ec000   hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`01801000 fffff880`019fe000   tcpip    tcpip.sys    Tue Jul 14 00:25:34 2009 (4A5BC26E)
fffff880`01e00000 fffff880`01e23000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`01e23000 fffff880`01e44000   WudfPf   WudfPf.sys   Tue Jul 14 01:05:37 2009 (4A5BCBD1)
fffff880`01e44000 fffff880`01e59000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`01e59000 fffff880`01eac000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`01eac000 fffff880`01ebf000   ndisuio  ndisuio.sys  Tue Jul 14 01:09:25 2009 (4A5BCCB5)
fffff880`01ebf000 fffff880`01ed7000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`01efc000 fffff880`01f88000   bthport  bthport.sys  Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`01f88000 fffff880`01fb4000   rfcomm   rfcomm.sys   Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`01fb4000 fffff880`01fc4000   BthEnum  BthEnum.sys  Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`01fc4000 fffff880`01fe4000   bthpan   bthpan.sys   Tue Jul 14 01:07:00 2009 (4A5BCC24)
fffff880`01fe4000 fffff880`01ff2000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`02c00000 fffff880`02c1b000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`02c1b000 fffff880`02c3c000   raspptp  raspptp.sys  Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`02c3c000 fffff880`02c56000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`02c5b000 fffff880`02c80000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`02c80000 fffff880`02c90000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`02c90000 fffff880`02c99000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`02c99000 fffff880`02ca2000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`02ca2000 fffff880`02cab000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`02cab000 fffff880`02cb6000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`02cb6000 fffff880`02cc7000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`02cc7000 fffff880`02ce5000   tdx      tdx.sys      Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`02ce5000 fffff880`02cf2000   TDI      TDI.SYS      Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`02cf2000 fffff880`02d43000   avgtdia  avgtdia.sys  Sun Apr 25 22:09:35 2010 (4BD4AF8F)
fffff880`02d43000 fffff880`02d88000   netbt    netbt.sys    Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`02d88000 fffff880`02dcf000   avgldx64 avgldx64.sys Thu Feb 11 03:52:31 2010 (4B737EFF)
fffff880`02dcf000 fffff880`02dfe000   ndiswan  ndiswan.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`03a03000 fffff880`03a8d000   afd      afd.sys      Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`03a8d000 fffff880`03a96000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03a96000 fffff880`03abc000   pacer    pacer.sys    Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`03abc000 fffff880`03ad2000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`03ad2000 fffff880`03ae1000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03ae1000 fffff880`03afc000   wanarp   wanarp.sys   Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`03afc000 fffff880`03b10000   termdd   termdd.sys   Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff880`03b10000 fffff880`03b61000   rdbss    rdbss.sys    Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`03b61000 fffff880`03b6d000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff880`03b6d000 fffff880`03b78000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`03b78000 fffff880`03b87000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`03b87000 fffff880`03ba5000   dfsc     dfsc.sys     Tue Jul 14 00:23:44 2009 (4A5BC200)
fffff880`03ba5000 fffff880`03bb6000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`03bb6000 fffff880`03bbd080   avgmfx64 avgmfx64.sys Sun Apr 25 22:06:15 2010 (4BD4AEC7)
fffff880`03bbe000 fffff880`03be4000   tunnel   tunnel.sys   Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`03be4000 fffff880`03bfa000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`03c00000 fffff880`03c1e000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`03c1e000 fffff880`03c27000   PS2      PS2.sys      Thu Sep 07 23:49:03 2006 (4500A1DF)
fffff880`03c27000 fffff880`03c36000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`03c36000 fffff880`03c37480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`03c38000 fffff880`03d2c000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 02:00:14 2009 (4AC5509E)
fffff880`03d2c000 fffff880`03d72000   dxgmms1  dxgmms1.sys  Tue Jul 14 00:38:32 2009 (4A5BC578)
fffff880`03d72000 fffff880`03d96000   HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`03d96000 fffff880`03dc8000   Rt64win7 Rt64win7.sys Thu Feb 26 09:04:13 2009 (49A65B0D)
fffff880`03dc8000 fffff880`03dd5000   usbuhci  usbuhci.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`03dd5000 fffff880`03de6000   usbehci  usbehci.sys  Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`03de6000 fffff880`03df3000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff880`03df3000 fffff880`03dff000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`03e00000 fffff880`03e1d000   usbccgp  usbccgp.sys  Tue Jul 14 01:06:45 2009 (4A5BCC15)
fffff880`03e1d000 fffff880`03e2b000   hidusb   hidusb.sys   Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`03e2b000 fffff880`03e44000   HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`03e44000 fffff880`03e4c080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`03e4d000 fffff880`03e60000   LHidFilt LHidFilt.Sys Wed Jun 17 17:49:39 2009 (4A391EA3)
fffff880`03e60000 fffff880`03e6d000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`03e6d000 fffff880`03e81000   LMouFilt LMouFilt.Sys Wed Jun 17 17:49:43 2009 (4A391EA7)
fffff880`03e85000 fffff880`03ec8000   ks       ks.sys       Tue Jul 14 01:00:31 2009 (4A5BCA9F)
fffff880`03ec8000 fffff880`03eda000   umbus    umbus.sys    Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`03eda000 fffff880`03f34000   usbhub   usbhub.sys   Tue Jul 14 01:07:09 2009 (4A5BCC2D)
fffff880`03f34000 fffff880`03f49000   NDProxy  NDProxy.SYS  Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`03f49000 fffff880`03f60000   nvhda64v nvhda64v.sys Mon May 11 19:49:08 2009 (4A087324)
fffff880`03f60000 fffff880`03f9d000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`03f9d000 fffff880`03fbf000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`03fbf000 fffff880`03fc4200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`03fc5000 fffff880`03fd1000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`03fd1000 fffff880`03fda000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`03fda000 fffff880`03fed000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`03fed000 fffff880`03ffb000   kbdhid   kbdhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`04800000 fffff880`04824000   rasl2tp  rasl2tp.sys  Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`04830000 fffff880`05329d80   nvlddmkm nvlddmkm.sys Fri Jun 26 23:15:53 2009 (4A454899)
fffff880`0532a000 fffff880`0532b180   nvBridge nvBridge.kmd Fri Jun 26 22:22:03 2009 (4A453BFB)
fffff880`0532c000 fffff880`05382000   USBPORT  USBPORT.SYS  Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`05382000 fffff880`053c7000   a8r002ew a8r002ew.SYS Tue Jul 14 22:12:55 2009 (4A5CF4D7)
fffff880`053c7000 fffff880`053d7000   CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`053d7000 fffff880`053ed000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`053ed000 fffff880`053fc000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05802000 fffff880`059e2400   RTKVHD64 RTKVHD64.sys Tue Aug 04 10:50:52 2009 (4A78047C)
fffff880`059e3000 fffff880`059ef000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`059ef000 fffff880`059fd000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`059fd000 fffff880`059fef00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`07200000 fffff880`0724e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 07:52:28 2010 (4B88CF3C)
fffff880`0724e000 fffff880`07271000   mrxsmb20 mrxsmb20.sys Sat Feb 27 07:52:26 2010 (4B88CF3A)
fffff880`07271000 fffff880`07289000   adfs     adfs.SYS     Thu Jun 26 21:52:37 2008 (48640195)
fffff880`07289000 fffff880`07292000   cpuz134_x64 cpuz134_x64.sys Fri Jul 09 12:16:58 2010 (4C37052A)
fffff880`0729b000 fffff880`07363000   HTTP     HTTP.sys     Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`07363000 fffff880`07381000   bowser   bowser.sys   Tue Jul 14 00:23:50 2009 (4A5BC206)
fffff880`07381000 fffff880`07399000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`07399000 fffff880`073c6000   mrxsmb   mrxsmb.sys   Sat Feb 27 07:52:19 2010 (4B88CF33)
fffff880`07a5c000 fffff880`07b02000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`07b02000 fffff880`07b0d000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`07b0d000 fffff880`07b3a000   srvnet   srvnet.sys   Tue Dec 08 08:32:26 2009 (4B1E0F1A)
fffff880`07b3a000 fffff880`07b4c000   tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`07b4c000 fffff880`07bb5000   srv2     srv2.sys     Tue Jul 14 00:25:02 2009 (4A5BC24E)
fffff880`07c97000 fffff880`07d2f000   srv      srv.sys      Tue Dec 08 08:32:55 2009 (4B1E0F37)
fffff880`07d2f000 fffff880`07d60000   WUDFRd   WUDFRd.sys   Tue Jul 14 01:06:06 2009 (4A5BCBEE)
fffff880`07d6b000 fffff880`07ddc000   spsys    spsys.sys    Mon May 11 18:20:58 2009 (4A085E7A)
fffff960`000f0000 fffff960`003ff000   win32k   win32k.sys   unavailable (00000000)
fffff960`004b0000 fffff960`004ba000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00750000 fffff960`007b1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff960`00830000 fffff960`00857000   cdd      cdd.dll      unavailable (00000000)
Unloaded modules:
fffff880`07d60000 fffff880`07d6b000   pcdsrvc_x64.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`017ec000 fffff880`017fa000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`015f4000 fffff880`01600000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`010cc000 fffff880`010d5000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`010d5000 fffff880`010e8000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
so first dump shows tht it was your realtek drivers that caused this,
realtek maybe your sound drivers , try updating these
also realtek maybe your wireless ,so update this along with the network card if poss
Top Bottom
