Windows 7 Problem Steps Recorder or PSR by Britec
YouTube - Windows 7 Problem Steps Recorder or PSR by Britec
How to use Problem Steps Recorder Tool in Windows 7
Problem Steps Recorder is a new miracle tool in Windows 7 for especially help desk or support engineers as well as software developers which will make it easier to receive a bug or problem ticket in much more detail. So developers will be enable to reproduce the steps that is causing an error with PSR Windows 7 recoring screen tool. Support engineers or help desk responsibles will be able to visualize and catch the problem among all other related issues to solve the situation.
So what is this miracle tool, Problem Steps Recorder (PSR) Windows 7 introduced with new version (since early beta versions) of Windows 7.
Problem Steps Recorder PSR Windows 7 can record what the user is doing on his/her computer. Problem Steps Recorder - PSR captures screen and can be assumed as a recording screen Windows7 tool. The user can enter comments on any screen capture to identify the situation with own words additional to what is seen on the screen capture.
If you have downloaded the public available beta realease or the Windows RC release of Windows Seven, and installed Windows 7 on a computer, go on and give a try simply by typing "psr" on the Windows 7 Start Menu.
psr.exe is the executable file of the Problems Steps Recorder. Problem Steps Recorder download is not a seperate download than Windows 7 installer.
