Windows 7 A little help unistalling please....
ultimatethombus
Hi All,
I installed windows 7 about a month ago and I'd like to revert back.
I was using Vista, and to install 7, I created a new partition and now have both; 7 on drive A and vista on drive C, as well as a recovery partition on D.
I'd like to merge A & C together, so I have my storage back, and remove 7 from A, keeping my existing Vista running once merged.
Is this possible?
Assuming Vista is the "system " partition ( check in Disk Management ) - it is straightforward.
Boot into Vista.
Open msconfig and under the Boot tab , set Vista entry as the Default and Delete 7 entry.
In vista Disk Management, delete the 7 partition - then rt click the Vista partiton and select Extend.
