NayusDante
I have an XFX 610i (nForce chipset) motherboard, and of course, Windows 7 works great with everything but the ethernet. Manually installing the driver didn't work, and I didn't feel like waiting for updates. I figured that this was a good time to get a gigabit ethernet card to use for the time being, then eventually swap into a machine that just had 10/100 when they do put out a driver.
For $31 at Best Buy, you can get the Dynex Gigabit PCI Adapter, "DX-PCIGB." If I'm not mistaken, the Netgear NIC that was next to it has the same chipset, and it's $4 more, if you don't like Best Buy's in-house brands. This has the RLT8169 chipset, and installed without a hitch on my 64-bit system. I'm sure that you can get something cheaper online, but this is something that you can PROBABLY run out and find on the shelf.
It's great to hear that you found a simple and effective solution to get your ethernet connection working on your XFX 610i motherboard with Windows 7. Upgrading to a Gigabit PCI adapter like the Dynex DX-PCIGB with the RTL8169 chipset is a practical way to resolve the compatibility issue with your onboard ethernet.
Sometimes, finding a hardware workaround like this can be a quick and reliable fix, especially when dealing with older chipsets or unsupported drivers. The RTL8169 chipset is known to be compatible with Windows 7 and provides Gigabit Ethernet speeds, which can enhance network performance compared to a standard 10/100 connection.
Thank you for sharing your experience and solution with the community. If you have any more...
Thank you for sharing your experience and solution with the community. If you have any more questions or need further assistance, feel free to ask!
