A year after - Problem returns.
Hi there everyone.
I'ts been over a year since I last wrote on this forum. Last time was because I had several bsod at the start of summer which ended up being fixed by cleaning the cooler. Well, here I am again, with the same problem, except that cleaning my computer didn't work this time.
It started with a single bsod in may, which I left alone since it never really returned. Now I had like 4 the last 2 days. Since it's nearly the exactly same time of the year and it's hot like hell outside, I've been thinking maybe it's the heat. I cleaned my computer (which was very dusty on the inside) but it didn't work out for long.
I did all the things mentioned in the "How to ask..." thread, but the website won't allow me to upload the .zip file at all. I also tried uploading individually, but only the picture (.png file) of the cpu-z info worked. Tried multiple times, but get an error nearly instantly after start
Hope you can help me out here :)
-Jens
Edit: I forgot to tell, that I'm having some issues with the website atm. Sometimes it only loads the background colors and such weird minor things.
Edit 2: Also forgot to tell that the 2 tabs in the cpu-z file had the exact same information, so I only print screened the first.
With laptops and especially if it's your only PC, then it's mandatory and essential to blow out the laptop on a regular basis, at least once a month. I do mine on a bi-weekly basis, that's every two weeks. That being said, I would also advise getting a laptop chill pad of some kind to help keep it cool.
As for the website; it's experiencing some technical difficulties at the moment, even I've experienced it some today.
usasma
Fantastic Member
Please provide this information so we can provide a complete analysis: http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html
If unable to upload here, try uploading to a free file-hosting service and post a link to it here.
Also, For starters:
At work we start all repairs with a set of diagnostics. Often they find problems that weren't even expected. It's a waste of time to try to fix software on a system that has hardware problems.
Please try these free diagnostics for starters: Initial Hardware Diagnostics
Also, please ensure that you have ALL available Windows Updates (it may take several trips to get them all).
After multiple attempts to enter the "go advance" part of replying, I gave up and just uploaded it to mediafire: Windows7Bsod.zip
Thanks for the quick replies :)
usasma
Fantastic Member
Sorry, but the reports aren't complete. Please run the data collection app again and let it run for at least 15 minutes (or until the app itself says it's done). Then zip it up and post it back again.
Sounds weird, but okay. I'll run the app again :) I think I might just have clicked the 'grab all' and when it said successful the first time I closed it down and zipped it. My bad >_<
W7F_23-06-2013.zip
Some extra information: I haven't had a bsod since the weather in Denmark cooled down a lot, which further increases my theory of overheating.
Thanks for taking your time :)
usasma
Fantastic Member
#7
Keep an eye on the temperatures with this free utility: HWiNFO, HWiNFO32 & HWiNFO64 - Hardware Information and Analysis Tools
No memory dumps in the uploaded files. This makes it more likely that there is a hardware problem (such as overheating).
You have a Realtek RTL8187B Wireless 802.11b/g 54Mbps USB 2.0 Network Adapter:
I do not recommend using wireless USB network devices. Especially in Win7/Win8 systems.
These wireless USB devices have many issues with Win7(and I suspect with Win8) - using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win7/Win8 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
There are several BSOD's listed in the WER section of MSINFO32. Nothing definitive tho', so it's still most likely hardware.
Just in case, please do this:
Upload Dump Files:
NOTE: If using a disk cleaning utility, please stop using it while we are troubleshooting your issues.
Please go to C:\Windows\Minidump and zip up the contents of the folder. Then upload/attach the .zip file with your next post.
Left click on the first minidump file.
Hold down the "Shift" key and left click on the last minidump file.
Right click on the blue highlighted area and select "Send to"
Select "Compressed (zipped) folder" and note where the folder is saved.
Upload that .zip file with your next post.
If you have issues with "Access Denied" errors, try copying the files to your desktop and zipping them up from there. If it still won't let you zip them up, post back for further advice.
If you don't have anything in that folder, please check in C:\Windows for a file named MEMORY.DMP. If you find it, zip it up and upload it to a free file hosting service. Then post the link to it in your topic so that we can download it.
Also, search your entire hard drive for files ending in .dmp, .mdmp, and .hdmp. Zip up any that you find and upload them with your next post.
Then, follow the directions here to set your system for Minidumps (much smaller than the MEMORY.DMP file): Set MiniDumpMore info on dump file options here: Overview of memory dump file options for Windows 2000, Windows XP, Windows Server 2003, Windows Vista, Windows Server 2008, Windows 7, and Windows Server 2008 R2
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Windows systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
#8
Sorry for the late reply. I've been out of town for some time now, but I'm back home. Got BSoD today too and it's quiet hot outside. I've added the previous minidump with todays too.
usasma
Fantastic Member
#9
Out of 6 memory dumps there were 5 different BSOD error codes. The differing error codes are usually symptomatic of a lower level problem within the system. They are usually caused by one of these things:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- BIOS issues (check for updates at the motherboard manufacturer's website)
- overclocking - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers)
- low-level driver problems
- or even malware (scanned for when we ask for hardware diagnostics from http://www.carrona.org/initdiag.html or http://www.carrona.org/hwdiag.html ).
You can get a head start on the hardware diagnostics if you'd like - they are located here: http://www.carrona.org/hwdiag.html
Please remove the LogMeIn/Remotely AnyWhere program from your system as it's very outdated (see the driver dates listed below). If needed it's easily reinstallable
lmimirr.sys Tue Apr 10 18:32:45 2007 (461C108D)
RemotelyAnywhere Mirror Miniport Driver or LogMeIn Mirror Miniport Driver
http://www.carrona.org/drivers/driver.php?id=lmimirr.sys
RaInfo.sys Fri Jan 4 13:57:14 2008 (477E818A)
LogMeIn/RemotelyAnywhere Kernel Information Provider
http://www.carrona.org/drivers/driver.php?id=RaInfo.sys
BisonC07.sys Tue Apr 29 06:47:06 2008 (4816FCAA)
BisonCam UVC, USB 2.0 Camera - Bison Electronics
http://www.carrona.org/drivers/driver.php?id=BisonC07.sys
LMIRfsDriver.sys Mon Jul 14 12:26:56 2008 (487B7E50)
http://www.carrona.org/drivers/driver.php?id=LMIRfsDriver.sys
SmSerl64.sys Fri Sep 26 04:45:56 2008 (48DCA144)
Dialup Modem driver
http://www.carrona.org/drivers/driver.php?id=SmSerl64.sys
jmcr.sys Mon Jul 20 07:39:02 2009 (4A645756)
JMicron JMB38X Memory Card Reader Driver
http://www.carrona.org/drivers/driver.php?id=jmcr.sys
If all of this doesn't stop the BSOD's, please run these free hardware diagnostics: http://www.carrona.org/hwdiag.html. Let us know the results and we can move on from there.
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Sun Jul  7 16:15:47.745 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070713-44553-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Built by: [B]7601[/B].18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime:[B]0 days 0:54:25.415[/B]
*** WARNING: Unable to verify timestamp for avgmfx64.sys
*** ERROR: Module load completed but symbols could not be loaded for avgmfx64.sys
*** WARNING: Unable to verify timestamp for MpFilter.sys
*** ERROR: Module load completed but symbols could not be loaded for MpFilter.sys
Probably caused by :[B]avgmfx64.sys ( avgmfx64+3e28 )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff800031cfbba, fffff880031ed7f8, fffff880031ed050}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/URL]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff800031cfbba, The address that the exception occurred at
Arg3: fffff880031ed7f8, Exception Record Address
Arg4: fffff880031ed050, Context Record Address
PROCESS_NAME:  System
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID: [B]X64_0x7E_avgmfx64+3e28[/B]
CPUID:        "Intel(R) Core(TM)2 Duo CPU     T6400  @ 2.00GHz"
MaxSpeed:     2000
CurrentSpeed: [B]1995[/B]
  BIOS Version                  1.02.15ZE
  BIOS Release Date             03/19/2009
  Manufacturer                  CLEVO CO.
  Product Name                  M860TU
**************************Sun Jul  7 15:20:00.189 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\070713-45817-01.dmp]
System Uptime:[B]0 days 3:11:59.098[/B]
Probably caused by :[B]win32k.sys ( win32k!BRUSHOBJ_hGetColorTransform+1d95 )[/B]
BugCheck [B]C4, {91, 0, fffffa80078aab50, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]DRIVER_VERIFIER_DETECTED_VIOLATION (c4)[/URL]
Arguments:
Arg1: 0000000000000091, A driver switched stacks using a method that is not supported by
    the operating system. The only supported way to extend a kernel
    mode stack is by using KeExpandKernelStackAndCallout.
Arg2: 0000000000000000
Arg3: fffffa80078aab50
Arg4: 0000000000000000
BUGCHECK_STR:  0xc4_91
PROCESS_NAME:  explorer.exe
FAILURE_BUCKET_ID: [B]X64_0xc4_91_win32k!BRUSHOBJ_hGetColorTransform+1d95[/B]
MaxSpeed:     2000
  Product Name                  M860TU
**************************Fri Jun 21 10:28:03.146 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\062113-43961-01.dmp]
System Uptime:[B]0 days 21:01:07.941[/B]
Probably caused by :[B]Wdf01000.sys ( Wdf01000!FxUsbPipeContinuousReader::FormatRepeater+b3 )[/B]
BugCheck [B]D1, {60, 2, 0, fffff88000f27f3f}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/URL]
Arguments:
Arg1: 0000000000000060, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88000f27f3f, address which referenced memory
BUGCHECK_STR:  0xD1
PROCESS_NAME:  League of Lege
FAILURE_BUCKET_ID: [B]X64_0xD1_Wdf01000!FxUsbPipeContinuousReader::FormatRepeater+b3[/B]
MaxSpeed:     2000
  Product Name                  M860TU
**************************Thu Jun 20 11:27:40.841 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\062013-45911-01.dmp]
System Uptime:[B]0 days 0:02:12.635[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+487ed )[/B]
BugCheck [B]1E, {ffffffffc0000005, fffffa8007a6d284, 1, ff00}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]KMODE_EXCEPTION_NOT_HANDLED (1e)[/URL]
Arguments:
Arg2: fffffa8007a6d284, The address that the exception occurred at
Arg3: 0000000000000001, Parameter 0 of the exception
Arg4: 000000000000ff00, Parameter 1 of the exception
BUGCHECK_STR:  0x1E_c0000005_R
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_nt!_??_::FNODOBFM::_string_+487ed[/B]
MaxSpeed:     2000
  Product Name                  M860TU
**************************Thu Jun 20 11:24:32.365 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\062013-54959-01.dmp]
System Uptime:[B]0 days 0:53:47.176[/B]
BugCheck [B]1E, {ffffffffc0000005, fffffa8006eee604, 1, ff00}[/B]
Arguments:
Arg2: fffffa8006eee604, The address that the exception occurred at
MaxSpeed:     2000
  Product Name                  M860TU
**************************Thu Jun 20 09:31:53.557 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\062013-49093-01.dmp]
System Uptime:[B]1 days 19:49:30.060[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!CmpKcbCacheLookup+1de )[/B]
BugCheck [B]50, {fffff8a004efca74, 0, fffff8000314df7e, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#Example"]PAGE_FAULT_IN_NONPAGED_AREA (50)[/URL]
Arguments:
Arg1: fffff8a004efca74, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff8000314df7e, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000000, (reserved)
BUGCHECK_STR:  0x50
FAILURE_BUCKET_ID: [B]X64_0x50_nt!CmpKcbCacheLookup+1de[/B]
MaxSpeed:     2000
  Product Name                  M860TU
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]lmimirr.sys                 Tue Apr 10 18:32:45 2007 (461C108D)[/B][/COLOR]
[COLOR=RED][B]RaInfo.sys                  Fri Jan  4 13:57:14 2008 (477E818A)[/B][/COLOR]
[COLOR=RED][B]BisonC07.sys                Tue Apr 29 06:47:06 2008 (4816FCAA)[/B][/COLOR]
[COLOR=RED][B]LMIRfsDriver.sys            Mon Jul 14 12:26:56 2008 (487B7E50)[/B][/COLOR]
[COLOR=RED][B]SmSerl64.sys                Fri Sep 26 04:45:56 2008 (48DCA144)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[COLOR=RED][B]jmcr.sys                    Mon Jul 20 07:39:02 2009 (4A645756)[/B][/COLOR]
nvBridge.kmd                Wed Aug 19 16:58:37 2009 (4A8C677D)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
RTL8187B.sys                Tue Mar 30 23:10:17 2010 (4BB2BD19)
tap0901.sys                 Thu Nov 24 13:50:27 2011 (4ECE91F3)
[COLOR=RED][B]dtsoftbus01.sys             Fri Jan 13 08:45:46 2012 (4F10358A)[/B][/COLOR]
cpuz135_x64.sys             Fri Mar  9 03:56:55 2012 (4F59C5D7)
Rt64win7.sys                Wed Apr 11 12:29:16 2012 (4F85B15C)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
MpFilter.sys                Wed Oct 31 18:43:06 2012 (5091A97A)
SteelBus64.sys              Sun Nov 11 18:40:39 2012 (50A03777)
nvhda64v.sys                Wed Dec 19 00:41:41 2012 (50D15395)
LHidFilt.Sys                Thu Jan  3 03:13:04 2013 (50E53D90)
LMouFilt.Sys                Thu Jan  3 03:13:07 2013 (50E53D93)
avgrkx64.sys                Thu Feb  7 22:14:05 2013 (51146D7D)
avgldx64.sys                Thu Feb  7 22:14:24 2013 (51146D90)
avgloga.sys                 Thu Feb  7 22:14:29 2013 (51146D95)
avgidsha.sys                Thu Feb  7 22:14:48 2013 (51146DA8)
avgmfx64.sys                Thu Feb  7 22:14:48 2013 (51146DA8)
nvlddmkm.sys                Thu Mar 14 21:37:00 2013 (51427B3C)
avgidsdrivera.sys           Thu Mar 28 21:40:56 2013 (5154F128)
LEqdUsb.Sys                 Thu Jan  3 03:12:57 2013 (50E53D89)
LHidEqd.Sys                 Thu Jan  3 03:12:59 2013 (50E53D8B)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=nvBridge.kmd
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=RTL8187B.sys
http://www.carrona.org/drivers/driver.php?id=tap0901.sys
http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sys
http://www.carrona.org/drivers/driver.php?id=cpuz135_x64.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
http://www.carrona.org/drivers/driver.php?id=SteelBus64.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=LHidFilt.Sys
http://www.carrona.org/drivers/driver.php?id=LMouFilt.Sys
http://www.carrona.org/drivers/driver.php?id=avgrkx64.sys
http://www.carrona.org/drivers/driver.php?id=avgldx64.sys
http://www.carrona.org/drivers/driver.php?id=avgloga.sys
http://www.carrona.org/drivers/driver.php?id=avgidsha.sys
http://www.carrona.org/drivers/driver.php?id=avgmfx64.sys
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
http://www.carrona.org/drivers/driver.php?id=avgidsdrivera.sys
http://www.carrona.org/drivers/driver.php?id=LEqdUsb.Sys
http://www.carrona.org/drivers/driver.php?id=LHidEqd.Sys
