Acer Aspire 5739G wireless problem
I have just bought a new computer Aspire 5739G.
Then i discovered that i could only connect to my wireless home network if i are 3 feets from the router.
the same happened when i was as my friend.
The wirered network is working fine...
if i go up to my room(2nd floor) it sais limited connection, but the signal sthrengt is high. if i am lucky i can get 1mbps and connection.
i can see many wireeless spots around the house.
all my other computers are working(xp,vista,leopard).
my router is named: SMC broadband network smcwbrt14t-G
i called acer support and they said that it might be my router or the card.... what do u guys think?
plz help me!!!
reghakr
Hello and welcome to the windows7forums,
You can check here for the latest drivers for your card:
SMC Networks - SUPPORT EN_USA
Look in Device Manager for any entries with a yellow flag
got the lates drivers, firmware....
there are no yellow flags in device manager.
i can connect to my router, only if i am close to it.....
reghakr
Do you know whether there is a firmware update for your router?
Is this the exact setup you had before instlling Windows 7?
i don't know how to update the router....(hasn't really done it....) ^^ good if u could explain it to me..?
i had this problem form the beginning. i have updated all the drivers..
reghakr
Do you have a router with networked computers or just a single modem?
I'd need to know the exact make and model.
