Windows 7 Acpi.sys BSOD Please Help!
alecstheone
Hello guys!
I recently got 2 BSOD referring to Acpi.sys. I couldn't found out what were causing these BSOD's and I'm asking for Your support. Just before the BSOD appears, the PC is sluggish.
My computer is a DELL PRECISION T5500, hex core processor XEON 5675, video card: Quadro 4000, 12GB RAM ECC, 1.5 TB HDD and Im running Windows 7-64 bit
I have the latest drivers.
Here's the link of the uploaded BSOD's.
Minidump.rar
If someone can detect the cause I'll be very grateful!
Thank You very much!
Hi -
Is this a fresh OS install?
Windows 7 Service Pack 1 needs to be installed along with other outstanding Windows Updates -
www.update.microsoft.com
Learn how to install Windows 7 Service Pack 1 (SP1)
One dump named "hardware" as the probable cause. Dumps are incapable of naming the exact piece of hardware that is failing.
RAM is one possibility here - run memtest86+
Memory Diagnostics
Regards. . .
jcgriff2
BSOD SUMMARY
[font=lucida console]
Debug session time: Sat Jan 12 18:08:30.507 2013 (GMT-5)
Loading Dump File [C:\Users\PalmDesert\SysnativeBSODApps\011213-48282-01.dmp]
Built by: 7600.17118.amd64fre.win7_gdr.120830-0334
System Uptime: 0 days 1:06:01.395
Probably caused by : ntkrnlmp.exe ( nt!KiPageFault+260 )
BugCheck D1, {0, 2, 1, fffffa8006d336e0}
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000D1]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/url]
Bugcheck code 000000d1
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffffa8006d336e0, address which referenced memory
BUGCHECK_STR:  0xD1
PROCESS_NAME:  chrome.exe
FAILURE_BUCKET_ID:  X64_0xD1_nt!KiPageFault+260
BiosVersion = V3.11
BiosReleaseDate = 05/24/2011
SystemManufacturer = MICRO-STAR INTERNATIONAL CO.,LTD
SystemProductName = MS-7576
Debug session time: Sat Jan 12 17:01:01.679 2013 (GMT-5)
Loading Dump File [C:\Users\PalmDesert\SysnativeBSODApps\011213-29842-01.dmp]
System Uptime: 0 days 0:35:01.567
Probably caused by : hardware ( nt!MiUnlinkPageFromLockedList+10e )
BugCheck A, {fffff7ffe275a7c8, 2, 0, fffff80002cf136e}
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000000A]IRQL_NOT_LESS_OR_EQUAL (a)[/url]
Bugcheck code 0000000A
Arguments:
Arg1: fffff7ffe275a7c8, memory referenced
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002cf136e, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID:  X64_IP_MISALIGNED
BiosVersion = V3.11
Debug session time: Fri Jan 11 15:41:49.257 2013 (GMT-5)
Loading Dump File [C:\Users\PalmDesert\SysnativeBSODApps\011113-32947-01.dmp]
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
System Uptime: 0 days 12:40:13.771
Probably caused by : USBPORT.SYS ( USBPORT!USBPORT_Core_UsbMapDpc_Worker+53 )
BugCheck D1, {fffff880241770c0, 2, 8, fffff880241770c0}
Arguments:
Arg1: fffff880241770c0, memory referenced
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: fffff880241770c0, address which referenced memory
BUGCHECK_STR:  0xD1
PROCESS_NAME:  System
FAILURE_BUCKET_ID:  X64_0xD1_CODE_AV_BAD_IP_USBPORT!USBPORT_Core_UsbMapDpc_Worker+53
BiosVersion = V3.11
       [color=#000033]J. C. Griffith, Microsoft MVP (jcgriff2)[/color]
           [url=http://mvp.microsoft.com/profiles/Griffith][color=#000055][u][url]http://mvp.microsoft.com/profiles/Griffith[/url][/u][/color][/url]
[/font]
It's not a fresh OS install.
I have Service Pack 1 installed.
I ran memtest a few months ago so I'm guessing its not from RAM...
It only happened since 2 days, since I moved my pc in the guestroom and attached it to a LED TV. I changed the resolution from 1280x1024 to 1920x1080. So maybe it's from the graphic card, or (better) from the graphic card drivers.
As I told You before it happened just after a small lag.
Isn't there a possibility to extract more (detailed) information from those minidumps?
Thank You for Your time!
May or may not be something wrong with your Graphics Card/Drivers, though for the first stage of debugging I'd blame the drivers (if I had to).
Many people who post BSOD help threads don't read (and this is a little thing in the back of my mind almost every single time - not that I'm saying that you did the wrong thing) the first thread in the Sub-Forum --- "How to ask for help with a BSOD problem".
http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html
Download the W7F Tool (and install it).
Grab:
-- Minidumps
-- MSINFO 32
-- SYSINFO
-- DXDIAG
Instead of grabbing all (or you could grab them all if you're lazy, but I barely read through the rest)
Get them all, zip them up and upload it to your original post.
Through the SYSINFO we can see -
-- Amount of memory available
-- Service Pack/Windows Version
-- Amount of Windows Updates installed, and which ones
-- Bunch of other stuff
Through MSINFO32 we can see -
-- How much space is available on each drive
-- Possible hardware problems
-- Possible problems with programs
Through DXDIAG we can see -
-- Your Audio and Graphics Card
- Name/Hardware Version
- Driver Version
- Problems with either/or
And, of course, the minidumps. I don't have my minidump analyzer (as in the analyzer I usually use, I still have the basic Windows Debugger) with me (for another 8 or 9 days), but I may be able to help there.
Top Bottom
