Activex doesn't work!
Do you have the same problem?
  • Total voters
    2
Hello,
On my PC (Windows 7 build 7100, ultimate) On Internet Explorer 8 Activex doesnt work anymore.
I tried these things:
  • Reset Internet Explorer 8
  • Reinstall Java
  • I am an Administrator so i have the rights
Could anywone give me help!
Greetings Silas
Windows Forum Admin
Microsoft MVP
Hi Silas,
if you checkout my screenshot you'll see the settings for active x. Just in case you didn't know these are accessed via internet options, security and custom level. You can then scroll down and either enable or click to prompt you on each setting in question.
Post back if the above is no help..
no
Hello,
This doesnt work. I get this when trying:
Windows Forum Admin
Microsoft MVP
Yup, thats right but if you read my post above thats how you fix it... You have to open the custom level security options and change the Active x settings... Look at my screenshot and you'll see where you have to go..
i treid
Hello,
I treid that but doesn't work i did those custum settings and all of that but it will show an activex bar:(
Windows Forum Admin
Microsoft MVP
If you've gone through all the activeX settings found there and it still doesn't work then I suggest running a virus/spyware scan.
#7
no virus
Hello,
I haven't any viruses, but is there maybe an way that i can install the newest IE8 or reinstall this wone.
:confused:
silas
Windows Forum Admin
Microsoft MVP
#8
If you open 'Turn windows features on or off' (see screenshot) you can disable IE8. I'd then reboot and then re-install it (reverse the process) it might be the fix!?
#9
Oke
Oke i will try that first, when this doesn't work we have to ask microsoft if they can fix it
#10
nope!
nope it didnt work!!!!, is there maybe away to uninstall all activex comptenents??? like systemrequirments lab is one of the activex things i instaled by nvidia.
Windows Forum Admin
Microsoft MVP
#11
I'm really at a loss at to what could be causing the problem especially after going through the stuff we did... I think if it was me I'd just re-install...
#12
reinstall windows for a browser? Just install Firefox
Windows Forum Admin
Microsoft MVP
#13
Yup, you could try that.... One question though, did you upgrade or do a fresh install when you first tried 7?
#14
AxInstSV
I saw on the start programms that this service is stopped auto when running W7: activex installer (AxInstSV) so maybe it that the problem. But i will installl build 7600 because i have lost CD of build 7100.
#15
os sorry
o sorry i had a clean install from XP
Windows Forum Admin
Microsoft MVP
#16
So your gonna try a fresh install?
#17
Yess
i have to and i have more problems with Windows 7
#18
you got it
i dont know if you have an download?
Windows Forum Admin
Microsoft MVP
#19
You got more problems?... Sounds like you need that install soon..
#20
YEs!!!!!
i need it as fast as possible a new windows 7 becuase with out an OS i cant make things for school and stuff
