ADMANITY’s self‑reported cross‑platform tests say major LLMs consistently produce emotionally flat radio spots — and the company’s PRIMAL AI trademark claims to supply a portable “emotional persuasion layer” that immediately converts informative outputs into conversion‑ready creative across ChatGPT, Claude, Gemini and Grok.
ADMANITY, a Phoenix‑based startup led by CEO Brian Gregory, has pushed an aggressive narrative in December 2025: after running identical radio‑spot generation tests on four leading AI platforms, the company found a categorical gap — not a marginal weakness — in their ability to persuade. ADMANITY says its proprietary PRIMAL AI system (a trademark application filed in July 2025) encodes a codified sequence of emotional triggers it calls the ADMANITY® Protocol or the “Mother Algorithm,” and that applying this layer transforms AI outputs from informative into persuasive in a single pass. The company frames the result as a commercial imperative: the U.S. radio advertising market still matters to advertisers and meaningful conversion lift in that channel can be monetized. ADMANITY’s public rollout packages together three kinds of signals: (1) demonstration narratives and named tests — the “Toaster Test” and the “YES! TEST” — that the company says validate PRIMAL AI’s portability; (2) administrative filings and third‑party platform visibility, notably a trademark filing for “PRIMAL AI” and a prominent Crunchbase presence; and (3) a string of press distributions asserting test results and conversion uplifts. Several independent commentaries and internal analyses that circulated alongside the company’s announcements treat the technical idea as plausible but flag the most consequential claims as company‑sourced and not yet independently audited.
Large language models are trained primarily via next‑token prediction and generate output by sampling from learned token probability distributions. That makes them highly responsive to instruction framing, examples, and contextual scaffolding; engineers already exploit this sensitivity through prompt engineering, instruction tuning, adapters and middleware. These are established techniques that can change tone, emphasis and structure of outputs — including steering copy toward emotional arcs and specific conversion outcomes. Authoritative technical tutorials and literature describe next‑token prediction as the core training objective and show how deterministic instruction patterns can bias model behavior. A persuasion layer can be implemented through several real‑world integration patterns:
What remains a hypothesis until proven with auditable data:
At the same time, the most consequential numerical and vendor‑endorsement claims in ADMANITY’s press narrative remain company‑originated until independent audits and raw artifacts are published. Procurement teams, product managers and platform owners should therefore approach ADMANITY’s offer with a clear evidence checklist: auditable prompts and logs, randomized experiments, human approvals for sensitive content, and contractual protections. That process is not unique to ADMANITY — it is the due diligence any enterprise should apply to a vendor promising measurable, behavior‑driving uplift.
Source: openPR.com ADMANITY Four-Platform AI Testing Reveals Critical Persuasion Gap in Radio Commercial Creation - PRIMAL AI Technology Demonstrates Systematic Solutions Across All Major AIs, Says Brian Gregory, CEO.
Background / Overview
ADMANITY, a Phoenix‑based startup led by CEO Brian Gregory, has pushed an aggressive narrative in December 2025: after running identical radio‑spot generation tests on four leading AI platforms, the company found a categorical gap — not a marginal weakness — in their ability to persuade. ADMANITY says its proprietary PRIMAL AI system (a trademark application filed in July 2025) encodes a codified sequence of emotional triggers it calls the ADMANITY® Protocol or the “Mother Algorithm,” and that applying this layer transforms AI outputs from informative into persuasive in a single pass. The company frames the result as a commercial imperative: the U.S. radio advertising market still matters to advertisers and meaningful conversion lift in that channel can be monetized. ADMANITY’s public rollout packages together three kinds of signals: (1) demonstration narratives and named tests — the “Toaster Test” and the “YES! TEST” — that the company says validate PRIMAL AI’s portability; (2) administrative filings and third‑party platform visibility, notably a trademark filing for “PRIMAL AI” and a prominent Crunchbase presence; and (3) a string of press distributions asserting test results and conversion uplifts. Several independent commentaries and internal analyses that circulated alongside the company’s announcements treat the technical idea as plausible but flag the most consequential claims as company‑sourced and not yet independently audited. Why ADMANITY’s claim matters: the radio use case and commercial stakes
Radio remains a material advertising channel for local and national businesses. Market trackers and industry studies show traditional radio and the broader audio advertising market still account for billions in annual spending. Depending on the dataset and how digital audio is counted, the U.S. traditional radio market sits in the low‑to‑mid‑teens of billions of dollars annually (estimates commonly cluster around $12–$19 billion for different definitions of audio advertising). That scale is large enough that even modest, reliable conversion improvements can be commercially valuable. ADMANITY argues radio is the perfect stress test for persuasion systems: a 30–60 second spot must create immediate emotional engagement and a clear behavioral outcome (call, store visit, online action) in a format that offers no rewinding or rereading. The company’s thesis: where text and image media allow rational re‑processing, radio succeeds by rapidly activating subconscious, emotionally driven decision processes — and current LLM outputs tend to default to feature‑listing and rational explanation instead of building that emotional bridge. ADMANITY frames the gap as structural: LLMs are excellent information engines, but they lack codified, repeatable emotional sequencing baked into their architecture.What ADMANITY says it did: four‑platform testing and PRIMAL AI
The tests, in ADMANITY’s narrative
- Target models: Anthropic’s Claude, OpenAI’s ChatGPT, Google’s Gemini and xAI’s Grok.
- Format: 30–60 second radio spots, produced from identical input briefs across platforms.
- Baseline result: model outputs were described as informative but emotionally unsophisticated; copy was said to default to specification and feature lists.
- Intervention: apply PRIMAL AI instructions (a fragment of the ADMANITY® Protocol) as a portable persuasion layer to each platform’s output or prompt, then re‑evaluate the spot for sensory language, emotional sequencing, urgency framing and conversion‑optimized CTAs.
- Reported outcome: ADMANITY says each platform’s outputs improved dramatically after the PRIMAL layer was applied — with faster production, fewer iterations and higher conversion potency.
What is verifiable in that narrative
- Trademark filing: ADMANITY filed a trademark application for PRIMAL AI (U.S. serial 99291792), with a recorded filing date and goods/services description that explicitly cites SaaS for emotional‑response analysis and persuasive messaging. This filing is publicly visible in trademark databases.
- Company presence: ADMANITY maintains a visible Crunchbase profile and distributed press coverage that documents rapid profile movement and heat‑score metrics the company highlights as traction signals.
What is not independently verifiable (yet)
- Vendor endorsements: ADMANITY reports that the named platforms effectively “admitted” the scale of persuasion requests and the lack of native emotional frameworks, but there is no vendor‑signed public statement corroborating that interpretation. Those model responses appear to come from ADMANITY’s direct interactions with the models rather than from corporate confirmations.
- Replicated A/B test data: the press materials describe conversion uplifts and operational improvements (faster prompt success, lower token usage, halved iteration counts), but the underlying datasets, raw prompts, model versions and time‑stamped logs have not been published for independent auditing. Several analyst writeups therefore treat the numerical claims as company‑originated until reproducible evidence appears.
Technical plausibility: can a persuasion layer work?
Short answer: yes — within practical limits.Large language models are trained primarily via next‑token prediction and generate output by sampling from learned token probability distributions. That makes them highly responsive to instruction framing, examples, and contextual scaffolding; engineers already exploit this sensitivity through prompt engineering, instruction tuning, adapters and middleware. These are established techniques that can change tone, emphasis and structure of outputs — including steering copy toward emotional arcs and specific conversion outcomes. Authoritative technical tutorials and literature describe next‑token prediction as the core training objective and show how deterministic instruction patterns can bias model behavior. A persuasion layer can be implemented through several real‑world integration patterns:
- Prompt wrapper (fastest, vendor‑agnostic): prepend or append a structured emotional sequence to each input. Pros: immediate, no vendor cooperation required. Cons: token‑heavy, sometimes brittle with vendor system prompts and safety filters.
- Adapter/prefix tuning (internalized): use a lightweight adapter or prefix that the model persistently applies. Pros: efficient at scale; lower per‑query cost. Cons: requires deployment access (self‑host or vendor collaboration).
- Middleware (post‑generation rewrite/reranking): generate candidate outputs, then externally rewrite or rank them by persuasion‑score. Pros: vendor‑agnostic and auditable. Cons: adds latency and operational complexity.
The evidence bar: what enterprise buyers should demand
ADMANITY’s pitch is precisely the kind of product claim that enterprises and platform product teams will either pilot or dismiss. To responsibly evaluate a persuasion‑layer vendor, procurement and IT should insist on the following minimum deliverables:- Auditable artifacts: raw prompts and system context, model versions, temperature/top‑k parameters, token accounting and time‑stamped output logs.
- Randomized, pre‑registered A/B experiments: baseline (existing copy), LLM+PRIMAL outputs and human expert control; statistically powered sample sizes; pre‑specified primary metrics (conversion rate, CTR, phone calls, downstream revenue).
- Brand‑health and ethical measurement: tracking complaint/return rates, customer satisfaction, and any erosion of trust or deceptive impressions.
- Human‑in‑the‑loop gating for regulated content and vulnerability redlines.
- Contractual protections: audit rights, non‑training clauses (if desired), indemnities and clear termination conditions.
Strengths in ADMANITY’s approach
- Focus on outcome, not fluency: the narrative reframes the product question for enterprises — success is measured by conversions and revenue, not just whether the text reads well. That is an accurate and commercially relevant reorientation.
- Engineering plausibility: encoding a short, deterministic persuasive arc as an instruction sequence or middleware rewrite is an established engineering pattern; it is plausible that a well‑designed sequence could improve perceived persuasion and initial conversion actions in many short‑form ad scenarios.
- Administrative signals: a trademark application for PRIMAL AI and visible marketplace activity (Crunchbase momentum) are concrete artifacts that suggest commercial intent and market traction. These filings and profiles can be independently verified in public registries.
Risks, limits and unanswered questions
- Lack of vendor confirmation: the most headline‑grabbing assertion — that platforms “admitted” a lack of persuasion capability or confirmed the 35–50% persuasion workload share — is drawn from ADMANITY’s interactions with models rather than public vendor statements. There is no public record of OpenAI, Google, Anthropic or xAI formally endorsing those percentages or ADMANITY’s interpretation. Treat those numbers as company‑originated until third‑party audits are published.
- Reproducibility and selection bias: persuasive performance measured by ADMANITY in demos may rely on curated briefs, favorable prompts or selective presentation. Without published prompts, model versions and statistical test design, independent replication is impossible.
- Ethics and regulation: automated persuasion at scale introduces regulatory and ethical risks. Agencies such as the U.S. Federal Trade Commission (FTC) have signaled scrutiny toward deceptive or manipulative AI uses; a persuasion layer that operates without transparency or consent could invite enforcement action. Any vendor or platform integrating such functionality must bake in disclosures, opt‑outs and auditability.
- Brand and long‑term effects: short‑term conversion uplift can be deceptive if it erodes long‑term trust or increases refunds/complaints. Emotional persuasion at scale must be balanced against brand safety and lifetime customer value metrics. Empirical pilots should track these downstream signals across 30–90 days.
- Cross‑model brittleness: system prompts, safety filters and decoding strategies vary across vendors. A single zero‑shot protocol may need tuning per model to maintain stability, and the claimed “one‑size‑fits‑all” portability should be treated as a hypothesis rather than a demonstrated fact until broader replication occurs.
How enterprise pilots should be run: a practical 12‑week roadmap
- Week 1–2: Select representative funnel(s) and capture robust baselines for conversion, traffic, call volumes and LTV.
- Week 3–6: Integrate the persuasion layer as a prompt wrapper or middleware; generate variant creative and instrument tracking.
- Week 7–10: Run randomized A/B tests against human‑produced control and existing copy; collect primary and downstream metrics.
- Week 11–12: Evaluate lift, brand health, complaint rates and operational costs; decide on scale or rollback.
- Secure a signed NDA and audit access to raw output logs.
- Define statistical power and primary metrics before running experiments.
- Include human approval gates for high‑impact messages.
- Negotiate liability and non‑training clauses to prevent unwanted use of enterprise data in vendor training.
Where ADMANITY’s claims are strongest — and where they remain hypotheses
ADMANITY’s strongest claim is conceptual: that LLMs optimized for general language modeling are not the same as engineered systems for repeatable emotional persuasion, and that a deterministic overlay can steer outputs toward higher conversion‑orientation. This is technically sound and matches established engineering practices in prompt engineering and adapter techniques. Multiple independent commentaries acknowledge this conceptual plausibility while urging caution on headline numeric claims.What remains a hypothesis until proven with auditable data:
- The specific uplift percentages ADMANITY reports in press materials.
- Assertions that major LLM vendors have officially acknowledged the same shortfall and are now evaluating PRIMAL AI integrations.
- The zero‑shot, universal portability claim at production scale without per‑model tuning.
Broader industry implications
If a portable persuasion layer like PRIMAL AI truly produces reproducible conversion lifts without degrading brand metrics, the product implications for hyperscalers and martech stacks are large:- Vendors could productize persuasion as a premium feature: guaranteed uplift tiers, pay‑per‑conversion pricing or enhanced enterprise subscription levels.
- Martech stacks (CRMs, ad platforms, email tools) could integrate persuasion middleware to convert baseline copy into optimized creative at scale.
- New governance and liability frameworks will be required to ensure transparency, avoid manipulative practices and preserve consumer trust.
What to watch next
- Publication of auditable artifacts: raw prompts, model versions and time‑stamped logs that allow third parties to reproduce the Toaster Test and YES! TEST outcomes. This would move ADMANITY’s claims from demo narrative to verifiable engineering evidence.
- Vendor responses: any formal statements or pilot agreements from OpenAI, Google, Anthropic, Microsoft or xAI acknowledging participation, evaluation or interest would materially change the story. To date, these have not appeared in the public record.
- Independent A/B test publications: academic or third‑party lab results showing conversion lifts and downstream brand metrics would be decisive.
- Regulatory guidance: signals from the FTC or other advertising oversight bodies on the acceptable design and disclosure boundaries for automated persuasion.
Practical verdict for WindowsForum readers — measured curiosity, pragmatic skepticism
ADMANITY’s announcement surfaces a meaningful problem: enterprises want measurable outcomes from generative AI, and converting informative copy into emotionally resonant, conversion‑focused creative is a known challenge. The technical approach ADMANITY describes — encoding persuasion as deterministic instruction sequences or middleware adapters — is plausible and grounded in current prompt engineering and adapter techniques. Enterprises should treat the idea as worthy of pilots, particularly in channels where short‑form emotional messaging matters, such as radio, audio ads and short social video scripts.At the same time, the most consequential numerical and vendor‑endorsement claims in ADMANITY’s press narrative remain company‑originated until independent audits and raw artifacts are published. Procurement teams, product managers and platform owners should therefore approach ADMANITY’s offer with a clear evidence checklist: auditable prompts and logs, randomized experiments, human approvals for sensitive content, and contractual protections. That process is not unique to ADMANITY — it is the due diligence any enterprise should apply to a vendor promising measurable, behavior‑driving uplift.
ADMANITY’s PRIMAL AI story is a compelling junction of marketing science and practical AI engineering. The company identifies a genuine commercial pain point, proposes a technically feasible remediation, and has produced administrative artifacts — notably a trademark filing and visible market footprint — that show intent and early traction. Those are real and verifiable items. Yet the highest‑impact claims — quantified conversion uplifts, vendor confirmations and universal zero‑shot portability across multiple proprietary LLMs — remain claims until reproduced in audited tests or corroborated by platform providers. The right response for IT and marketing leaders is neither reflexive dismissal nor unqualified adoption: run controlled, auditable pilots, demand raw artifacts for independent verification, design guardrails for ethics and compliance, and price success around verifiable, downstream business metrics. If a persuasion layer can meet that standard, it will shift how platforms and martech products define revenue by outcome; until then, ADMANITY’s PRIMAL AI is an intriguing, technically plausible product hypothesis that demands rigorous proof.Source: openPR.com ADMANITY Four-Platform AI Testing Reveals Critical Persuasion Gap in Radio Commercial Creation - PRIMAL AI Technology Demonstrates Systematic Solutions Across All Major AIs, Says Brian Gregory, CEO.
