TKR99
- Joined
- Jun 6, 2009
- Messages
- 156
- Thread Author
- #1
Sorry - ignore - Mods can delete post as I just found the answer
Put the search in quotes!
Hi all
I unfortunately "hard" deleted a folder I really needed but have thankfully managed to recover almost all of the files in it (nearly 2000 of them!!). The problem now is that in the process I have quite a few duplicates and with so many to work with, it would take me days if not weeks of wading through trying to spot them for deleting again.
As the vast majority have been renamed xxx_1.jpg I'd hoped it would be a matter of simply looking for all the files with a _1 suffix but unfortunately not - because many of the files were already named as numbers (all graphics) the searches are just bringing up everything with a #1 in the fliename. Admittedly it does cut the volume down from maybe 700 odd to 500 or so, but still way too many for me to spend time on.
So I wondered if there's a better way of doing the search or alternatively if you know of any other program I could download to try on it?
Thanks
Hi all
Thanks
