Only 98 updates since SP1 - most systems have 130 to 140. Please visit Windows Update and get all available updates.
Your D: drive only has 21 gB free space - it should have 15% free (about 60 gB) for optimum performance. As the drive fills, it's performance will degrade - getting to a point where it's impossible to move/copy larger files.
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program,
then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration):
[DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012):
DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link:
Disc-Tools.com Manual procedure here:
Link Removed - Invalid URL The memory dump blames NETw1v64.sys - a driver component of your Intel Wireless Networking card.
Link Removed - Invalid URL Please:
- download a fresh copy of the driver package from
http://downloadcenter.intel.com - un-install the current copy of the drivers from your system
- install the freshly downloaded drivers
- monitor for further BSOD's
Also, Please update these older drivers. Links are included to assist in looking up the source of the drivers. If unable to find an update, please remove (un-install) the program responsible for that driver. DO NOT manually delete/rename the driver as it may make the system unbootable! :
ATK64AMD.sys Fri Oct 27 08:45:25 2006 (4541FF65) ATK Hotkey ATK0101 ACPI UTILITY Driver
Link Removed - Invalid URL If unable to locate an update for this, please un-install it from your system - it's way too old to keep!
L1C62x64.sys Wed Apr 1 01:09:17 2009 (49D2F6FD) Atheros NIC driver
http://www.carrona.org/drivers/driver.php?id=L1C62x64.sys rimspe64.sys Wed Jul 1 19:54:49 2009 (4A4BF749) Ricoh Memory Card Reader driver
Link Removed - Invalid URL rixdpe64.sys Sat Jul 4 06:27:00 2009 (4A4F2E74) Ricoh Memory Card Reader driver
Link Removed - Invalid URL NETw1v64.sys Mon Jul 20 18:33:35 2009 (4A64F0BF) Intel(R) Wireless WiFi Link 1000 Series Adapter Driver for Windows Vista 64 Bit
Link Removed - Invalid URL HECIx64.sys Thu Sep 17 15:54:16 2009 (4AB293E8)
Intel Management Engine Interface
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys Analysis: The following is for information purposes only. Code:
[font=lucida console]**************************Thu Oct 11 16:54:14.874 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\101112-14320-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 7:57:11.341[/B]
BugCheck Code: [B]BugCheck A, {0, 2, 0, fffff80002e1a477}[/B]
*** WARNING: Unable to verify timestamp for NETw1v64.sys
*** ERROR: Module load completed but symbols could not be loaded for NETw1v64.sys
Probably caused by :[B]NETw1v64.sys ( NETw1v64+54ed )[/B]
BugCheck Info: [B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_NETw1v64+54ed[/B]
CPUID: "Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz"
MaxSpeed: 2400
CurrentSpeed: [B]2400[/B]
BIOS Version 208
BIOS Release Date 08/16/2010
Manufacturer ASUSTeK Computer Inc.
Product Name G60JX
[/font]
3rd Party Drivers: The following is for information purposes only. Any drivers in red should be updated or removed from your system. And should have been discussed in the body of my post. Code:
[COLOR=RED][B]ATK64AMD.sys Fri Oct 27 08:45:25 2006 (4541FF65)[/B][/COLOR]
[COLOR=RED][B]L1C62x64.sys Wed Apr 1 01:09:17 2009 (49D2F6FD)[/B][/COLOR]
[COLOR=RED][B]rimspe64.sys Wed Jul 1 19:54:49 2009 (4A4BF749)[/B][/COLOR]
[COLOR=RED][B]rixdpe64.sys Sat Jul 4 06:27:00 2009 (4A4F2E74)[/B][/COLOR]
intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
[COLOR=RED][B]NETw1v64.sys Mon Jul 20 18:33:35 2009 (4A64F0BF)[/B][/COLOR]
amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
MpNWMon.sys Tue Sep 14 20:19:30 2010 (4C901112)
[COLOR=RED][B]dtsoftbus01.sys Fri Jan 13 08:45:46 2012 (4F10358A)[/B][/COLOR]
nvhda64v.sys Tue Jul 3 11:25:04 2012 (4FF30ED0)
nvlddmkm.sys Thu Aug 30 11:50:16 2012 (503F8BB8)
[/font]
Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=L1C62x64.sys Link Removed - Invalid URL Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=intelppm.sys Link Removed - Invalid URL http://www.carrona.org/drivers/driver.php?id=HECIx64.sys http://www.carrona.org/drivers/driver.php?id=amdxata.sys http://www.carrona.org/drivers/driver.php?id=MpFilter.sys http://www.carrona.org/drivers/driver.php?id=MpNWMon.sys http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sys http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
