cybercore
@Link Removed - Invalid URL,
I got your pm:
kuchomik said:Hi,
I've read topic about constant BSODs on Win7PRO x64 caused by amdppm.sys... I've experienced it twice, in two consecutive days. Can u pls help me solving this problem?
What's surprising, it is brand new built PC...
Under following URL u can find my DMP files from both crashes.
Will be very grateful for ur help!
Cheers,
Kuchomik
Set the hardware clocks right with the setup defaults in the bios. Do not overclock.
[B]BugCheck 1E, {ffffffffc0000005[/B], fffff880041706e7, 0, ffffffffffffffff}
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s
Probably caused by : [B]amdppm.sys[/B] ( amdppm!ReadIoMemRaw+33 )
So I suggest:
1. No overclocking with AMD Overdrive, and no overclocking at all:
AODDriver.sys Thu Mar 04 05:58:24 2010
2. Uninstall or update Gygabite drivers, tools and utilities:
GVTDrv64.sys Tue Sep 05 03:10:02 2006
gdrv.sys Thu Mar 12 23:22:29 2009
3. Update motherboard driver for USB 3.0:
nusb3xhc.sys Fri Nov 20 05:16:01 2009
4. If blue screens persist, uninstall Avast and replace it with MSE:
avast! Uninstall Utility
Link Removed due to 404 Error
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\011511-20623-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (6 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e19000 PsLoadedModuleList = 0xfffff800`03056e50
Debug session time: Fri Jan 14 20:28:48.049 2011 (UTC - 5:00)
System Uptime: 0 days 2:34:00.000
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 1E, {ffffffffc0000005, fffff880041706e7, 0, ffffffffffffffff}
Probably caused by : amdppm.sys ( amdppm!ReadIoMemRaw+33 )
Followup: MachineOwner
2: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff880041706e7, The address that the exception occurred at
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
FAULTING_IP:
fffff880`041706e7 c3 ret
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800030c10e0
ffffffffffffffff
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
BUGCHECK_STR: 0x1E_c0000005
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
CURRENT_IRQL: 0
EXCEPTION_RECORD: fffff88002f8ca28 -- (.exr 0xfffff88002f8ca28)
ExceptionAddress: fffff880041706e7 (amdppm!ReadIoMemRaw+0x0000000000000033)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME: fffff88002f8cad0 -- (.trap 0xfffff88002f8cad0)
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000004014
rdx=0000000000004014 rsi=0000000000000000 rdi=0000000000000000
rip=fffff880041706e7 rsp=fffff88002f8cc68 rbp=0000000000000000
r8=0000000000000008 r9=fffffa80082c1458 r10=000000000001738d
r11=fffffa8006a21988 r12=0000000000000000 r13=0000000000000000
iopl=0 nv up di pl zr na po nc
amdppm!ReadIoMemRaw+0x33:
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002ec3a39 to fffff80002e89740
STACK_TEXT:
fffff880`02f8c258 fffff800`02ec3a39 : 00000000`0000001e ffffffff`c0000005 fffff880`041706e7 00000000`00000000 : nt!KeBugCheckEx
fffff880`02f8c260 fffff800`02e88d82 : fffff880`02f8ca28 00000000`00000001 fffff880`02f8cad0 fffff880`02f64180 : nt!KiDispatchException+0x1b9
fffff880`02f8c8f0 fffff800`02e8768a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatch+0xc2
fffff880`02f8cad0 fffff880`041706e7 : f7fff880`0417072d 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiGeneralProtectionFault+0x10a
fffff880`02f8cc68 f7fff880`0417072d : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : amdppm!ReadIoMemRaw+0x33
fffff880`02f8cc70 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000001 : 0xf7fff880`0417072d
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: amdppm!ReadIoMemRaw+33
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: amdppm
IMAGE_NAME: amdppm.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc0fd
FAILURE_BUCKET_ID: X64_0x1E_c0000005_amdppm!ReadIoMemRaw+33
Drivers:
start end module name
fffff880`04000000 fffff880`0403e000 1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00ee6000 fffff880`00f3d000 ACPI ACPI.sys Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c02000 fffff880`02c8c000 afd afd.sys Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`07200000 fffff880`07216000 AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`0416e000 fffff880`04183000 amdppm amdppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00c2a000 fffff880`00c35000 amdxata amdxata.sys Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`0c673000 fffff880`0c6a4000 AODDriver AODDriver.sys Thu Mar 04 05:58:24 2010 (4B8F9250)
fffff880`04140000 fffff880`04148000 AppleCharger AppleCharger.sys Mon Apr 26 23:54:05 2010 (4BD65FDD)
fffff880`09693000 fffff880`0969c000 aswFsBlk aswFsBlk.SYS Fri Dec 31 14:56:29 2010 (4D1E356D)
fffff880`09659000 fffff880`09693000 aswMonFlt aswMonFlt.sys Fri Dec 31 14:56:39 2010 (4D1E3577)
fffff880`02c8c000 fffff880`02c96000 aswRdr aswRdr.SYS Fri Dec 31 14:56:51 2010 (4D1E3583)
fffff880`040f7000 fffff880`04140000 aswSP aswSP.SYS Fri Dec 31 15:00:41 2010 (4D1E3669)
fffff880`019ab000 fffff880`019bb000 aswTdi aswTdi.SYS Fri Dec 31 14:59:26 2010 (4D1E361E)
fffff880`0c715000 fffff880`0c720000 asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00ff1000 fffff880`00ffa000 atapi atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00c00000 fffff880`00c2a000 ataport ataport.SYS Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`00970000 fffff960`009d1000 ATMFD ATMFD.DLL unavailable (00000000)
fffff880`018ff000 fffff880`01906000 Beep Beep.SYS Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`040e6000 fffff880`040f7000 blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`09400000 fffff880`0941e000 bowser bowser.sys Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00600000 fffff960`00627000 cdd cdd.dll unavailable (00000000)
fffff880`018cc000 fffff880`018f6000 cdrom cdrom.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cbc000 fffff880`00d7c000 CI CI.dll Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01866000 fffff880`01896000 CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c5e000 fffff880`00cbc000 CLFS CLFS.SYS Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0117e000 fffff880`011f1000 cng cng.sys Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`06dec000 fffff880`06dfc000 CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0996f000 fffff880`0997d000 crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04045000 fffff880`040c8000 csc csc.sys Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`040c8000 fffff880`040e6000 dfsc dfsc.sys Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`019d2000 fffff880`019e1000 discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01235000 fffff880`0124b000 disk disk.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`094fa000 fffff880`0951c000 drmk drmk.sys Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`02d36000 fffff880`02d79000 dtsoftbus01 dtsoftbus01.sys Wed Dec 22 05:19:28 2010 (4D11D0B0)
fffff880`099a4000 fffff880`099ad000 dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`09998000 fffff880`099a4000 dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`099ad000 fffff880`099c0000 dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`09938000 fffff880`09944000 Dxapi Dxapi.sys Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`06c27000 fffff880`06d1b000 dxgkrnl dxgkrnl.sys Mon Nov 01 22:51:31 2010 (4CCF7CB3)
fffff880`06d1b000 fffff880`06d61000 dxgmms1 dxgmms1.sys Mon Nov 01 22:50:56 2010 (4CCF7C90)
fffff880`0c751000 fffff880`0c787000 fastfat fastfat.SYS Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`0110c000 fffff880`01120000 fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010c0000 fffff880`0110c000 fltmgr fltmgr.sys Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000 Fs_Rec Fs_Rec.sys Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01086000 fffff880`010c0000 fvevol fvevol.sys Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0148b000 fffff880`014d5000 fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`09dee000 fffff880`09df7000 gdrv gdrv.sys Thu Mar 12 23:22:29 2009 (49B9D175)
fffff880`06db7000 fffff880`06dc4000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff880`096ea000 fffff880`096f4000 GVTDrv64 GVTDrv64.sys Tue Sep 05 03:10:02 2006 (44FD22CA)
fffff800`033f5000 fffff800`0343e000 hal hal.dll Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`06d61000 fffff880`06d85000 HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`099ce000 fffff880`099e7000 HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`099e7000 fffff880`099ef080 HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`099c0000 fffff880`099ce000 hidusb hidusb.sys Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`09522000 fffff880`095ea000 HTTP HTTP.sys Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`014ed000 fffff880`014f6000 hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`00fd1000 fffff880`00ff1000 jraid jraid.sys Wed Jan 27 03:58:17 2010 (4B600029)
fffff880`080f3000 fffff880`08102000 kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`099f0000 fffff880`099fe000 kbdhid kbdhid.sys Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bcd000 fffff800`00bd7000 kdcom kdcom.dll Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`08113000 fffff880`08156000 ks ks.sys Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000 ksecdd ksecdd.sys Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01460000 fffff880`0148b000 ksecpkg ksecpkg.sys Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`0951c000 fffff880`09521200 ksthunk ksthunk.sys Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`09600000 fffff880`09615000 LHidFilt LHidFilt.Sys Tue Aug 24 13:21:36 2010 (4C73FFA0)
fffff880`096bd000 fffff880`096d2000 lltdio lltdio.sys Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`09622000 fffff880`09636000 LMouFilt LMouFilt.Sys Tue Aug 24 13:21:43 2010 (4C73FFA7)
fffff880`09636000 fffff880`09659000 luafv luafv.sys Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c3d000 fffff880`00c4a000 mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`09944000 fffff880`09952000 monitor monitor.sys Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`08102000 fffff880`08111000 mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`09615000 fffff880`09622000 mouhid mouhid.sys Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00dd8000 fffff880`00df2000 mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0941e000 fffff880`09436000 mpsdrv mpsdrv.sys Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`09436000 fffff880`09463000 mrxsmb mrxsmb.sys Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`09463000 fffff880`094b1000 mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`01896000 fffff880`018b9000 mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01964000 fffff880`0196f000 Msfs Msfs.SYS Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f46000 fffff880`00f50000 msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01120000 fffff880`0117e000 msrpc msrpc.sys Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`019c7000 fffff880`019d2000 mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`015ec000 fffff880`015fe000 mup mup.sys Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014fa000 fffff880`015ec000 ndis ndis.sys Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`08057000 fffff880`08063000 ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`08063000 fffff880`08092000 ndiswan ndiswan.sys Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`081d9000 fffff880`081ee000 NDProxy NDProxy.SYS Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d0a000 fffff880`02d19000 netbios netbios.sys Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02c96000 fffff880`02cdb000 netbt netbt.sys Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01400000 fffff880`01460000 NETIO NETIO.SYS Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`0196f000 fffff880`01980000 Npfs Npfs.SYS Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`019bb000 fffff880`019c7000 nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e19000 fffff800`033f5000 nt ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`0124f000 fffff880`013f2000 Ntfs Ntfs.sys Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`018f6000 fffff880`018ff000 Null Null.SYS Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`08168000 fffff880`0817f000 nusb3hub nusb3hub.sys Fri Nov 20 05:15:57 2009 (4B066C5D)
fffff880`06d85000 fffff880`06db5000 nusb3xhc nusb3xhc.sys Fri Nov 20 05:16:01 2009 (4B066C61)
fffff880`07df5000 fffff880`07df6180 nvBridge nvBridge.kmd Tue Nov 09 11:30:43 2010 (4CD97733)
fffff880`08000000 fffff880`08029000 nvhda64v nvhda64v.sys Tue Sep 07 16:08:40 2010 (4C869BC8)
fffff880`07218000 fffff880`07df4f00 nvlddmkm nvlddmkm.sys Tue Nov 09 11:36:26 2010 (4CD9788A)
fffff880`02ce4000 fffff880`02d0a000 pacer pacer.sys Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`06c00000 fffff880`06c1d000 parport parport.sys Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`00f90000 fffff880`00fa5000 partmgr partmgr.sys Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f50000 fffff880`00f83000 pci pci.sys Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fba000 fffff880`00fc1000 pciide pciide.sys Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fc1000 fffff880`00fd1000 PCIIDEX PCIIDEX.SYS Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000 pcw pcw.sys Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`09c01000 fffff880`09ca7000 peauth peauth.sys Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`094bd000 fffff880`094fa000 portcls portcls.sys Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c4a000 fffff880`00c5e000 PSHED PSHED.dll Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`08033000 fffff880`08057000 rasl2tp rasl2tp.sys Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`08092000 fffff880`080ad000 raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`080ad000 fffff880`080ce000 raspptp raspptp.sys Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`080ce000 fffff880`080e8000 rassstp rassstp.sys Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02da8000 fffff880`02df9000 rdbss rdbss.sys Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`080e8000 fffff880`080f3000 rdpbus rdpbus.sys Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01949000 fffff880`01952000 RDPCDD RDPCDD.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01952000 fffff880`0195b000 rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0195b000 fffff880`01964000 rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0104c000 fffff880`01086000 rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`096d2000 fffff880`096ea000 rspndr rspndr.sys Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01800000 fffff880`01857000 Rt64win7 Rt64win7.sys Mon Mar 22 05:57:14 2010 (4BA73EFA)
fffff880`096fe000 fffff880`09937080 RTKVHD64 RTKVHD64.sys Tue Apr 06 06:17:30 2010 (4BBB0A3A)
fffff880`00e00000 fffff880`00e2f000 SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`09ca7000 fffff880`09cb2000 secdrv secdrv.SYS Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`06de0000 fffff880`06dec000 serenum serenum.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02d19000 fffff880`02d36000 serial serial.sys Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`014e5000 fffff880`014ed000 spldr spldr.sys Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`09d58000 fffff880`09dee000 srv srv.sys Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`09cf1000 fffff880`09d58000 srv2 srv2.sys Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`09cb2000 fffff880`09cdf000 srvnet srvnet.sys Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`08111000 fffff880`08112480 swenum swenum.sys Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01602000 fffff880`017ff000 tcpip tcpip.sys Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`09cdf000 fffff880`09cf1000 tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`0199e000 fffff880`019ab000 TDI TDI.SYS Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01980000 fffff880`0199e000 tdx tdx.sys Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02d94000 fffff880`02da8000 termdd termdd.sys Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00410000 fffff960`0041a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`04148000 fffff880`0416e000 tunnel tunnel.sys Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`08156000 fffff880`08168000 umbus umbus.sys Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`09952000 fffff880`0996f000 usbccgp usbccgp.sys Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`06db5000 fffff880`06db6f00 USBD USBD.SYS Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`06dcf000 fffff880`06de0000 usbehci usbehci.sys Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0817f000 fffff880`081d9000 usbhub usbhub.sys Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`06dc4000 fffff880`06dcf000 usbohci usbohci.sys Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0418c000 fffff880`041e2000 USBPORT USBPORT.SYS Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0997d000 fffff880`09998000 USBSTOR USBSTOR.SYS Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`00f83000 fffff880`00f90000 vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01906000 fffff880`01914000 vga vga.sys Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01914000 fffff880`01939000 VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`014d5000 fffff880`014e5000 vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00fa5000 fffff880`00fba000 volmgr volmgr.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d7c000 fffff880`00dd8000 volmgrx volmgrx.sys Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01000000 fffff880`0104c000 volsnap volsnap.sys Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02d79000 fffff880`02d94000 wanarp wanarp.sys Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01939000 fffff880`01949000 watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e33000 fffff880`00ed7000 Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ed7000 fffff880`00ee6000 WDFLDR WDFLDR.SYS Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02cdb000 fffff880`02ce4000 wfplwf wfplwf.sys Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000e0000 fffff960`003f0000 win32k win32k.sys unavailable (00000000)
fffff880`04183000 fffff880`0418c000 wmiacpi wmiacpi.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f3d000 fffff880`00f46000 WMILIB WMILIB.SYS Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0969c000 fffff880`096bd000 WudfPf WudfPf.sys Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`0c720000 fffff880`0c751000 WUDFRd WUDFRd.sys Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`0c6a4000 fffff880`0c715000 spsys.sys
Checksum: 00000000
ImageSize: 00071000
fffff880`01896000 fffff880`018a4000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`018a4000 fffff880`018b0000 dump_ataport
Checksum: 00000000
ImageSize: 0000C000
fffff880`018b0000 fffff880`018b9000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
fffff880`018b9000 fffff880`018cc000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
Sincerely,
- cybercore. : )
