And again ! BSoD one afte the other - really desperating! Please help!
Well, here I am again - and my Data-Files.
I've done all Updates I could find for my Motherboard and did them all. I've completed my Profile with the dates I could find.
Yesterday the system came up normaly and worked the whole day about 15 hours without any problem.
Today - it starts again "blue" and it stopped. After reboot I started with "normal" Window-Mode and after 5 min - the next BSOD.
It always appears at once after the start up - today twice. After then the system works without any problems, I used it today more then 10 hours without a break.
I write this now in "Secure Mode" and made the files for the "system-info" in this modus. My CPU-Z-Application won't start anymore, maybe there's something depending on the BSoD. I've added the logfile.
Hope you can help, please have a look at the files.
Here are some more informations which may be important to know for searching for reasons.
I use a Medion HDDDrive2Go - external HDD, connect it normally via USB, and had no problems till today.
I work with 3 17"Monitors connected with a TripleHead2Go analog. I use only the actual NVIDIA-Driver for my Graphic-Card (GTX460) and have not installed any Matrox-Drivers for the TH2G. Matrox doesn't support Win7 64 for the analog Version. It works very nice the window spanned via all 3 Monitors.
Edited after 8 Hours working:
I've now installed the MATROX driver and application served on their homepage described for Win7 64 and the Analogue Version.
(v64_gxm-tha_2_07_00_031_whql)
I'm really desperated, because me myself has no chance to find anything in such a system. Let me know if there are more informations necessary to know.
Hopeful greetings
Martin
Elmer
Hi Martin.
STOP 0x00000005: INVALID_PROCESS_ATTACH_ATTEMPT
Usual causes:
Specific known issue with XP SP2/Server 2003 and certain Antivirus or Firewall programs
Your latest dump file lists ntkrnlmp.exe as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
Uninstall Trend Micro. How To and Removal Tools...
Replace with Microsoft Security Essentials
AsIO.sys Tue Aug 24 02:53:02 2010 ASUS Probe Utility - Has issues with Windows 7. Uninstall.
AsUpIO.sys Tue Aug 03 03:47:59 2010 ASUS hardware monitoring utility. Possible issues with Windows 7. Uninstall.
Drivers with Updates:
nusb3hub.sys Fri Dec 10 04:50:35 2010
nusb3xhc.sys Fri Dec 10 04:50:35 2010
Go to your Motherboard Mfr. Support website (or NEC/Renesas) and update your USB 3.0 drivers. A June 2011 set are available Here.
Rt64win7.sys Wed Dec 29 11:44:36 2010 Realtek PCIe GBE Family Controller v7.049 If you're unsure about manually installing drivers then choose the Win7 and WinServer 2008 R2 Auto Installation Program (SID:1477671) option to download.
Bugcheck Analysis:
BugCheck 5, {fffffa80066ec040, fffffa80066ec040, 0, fffffa800676db60}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+5920d )
Followup: MachineOwner
4: kd> !analyze -v
INVALID_PROCESS_ATTACH_ATTEMPT (5)
Arguments:
Arg1: fffffa80066ec040
Arg2: fffffa80066ec040
Arg3: 0000000000000000
Arg4: fffffa800676db60
Debugging Details:
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x5
PROCESS_NAME:  System
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff8000330f0cf to fffff8000328cc40
STACK_TEXT:
fffff880`03754b68 fffff800`0330f0cf : 00000000`00000005 fffffa80`066ec040 fffffa80`066ec040 00000000`00000000 : nt!KeBugCheckEx
fffff880`03754b70 fffff800`03527fee : 00000000`00000000 fffffa80`0676db60 00000000`00000080 fffffa80`066ec040 : nt! ?? ::FNODOBFM::`string'+0x5920d
fffff880`03754c00 fffff800`0327e5e6 : fffff880`0356d180 fffffa80`0676db60 fffff880`035780c0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`03754c40 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`0330f0cf cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+5920d
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4e02aaa3
FAILURE_BUCKET_ID:  X64_0x5_nt!_??_::FNODOBFM::_string_+5920d
Drivers:
fffff880`0f489000 fffff880`0f4c7000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00fa1000 fffff880`00ff8000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`01400000 fffff880`01489000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`031cc000 fffff880`031e2000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`013e3000 fffff880`013ee000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`04007000 fffff880`0400d000   AsIO     AsIO.sys     Tue Aug 24 02:53:02 2010 (4C7325FE)
fffff880`04000000 fffff880`04007000   AsUpIO   AsUpIO.sys   Tue Aug 03 03:47:59 2010 (4C57835F)
fffff880`00e20000 fffff880`00e29000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00c76000 fffff880`00ca0000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`01ac1000 fffff880`01ac8000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`041ed000 fffff880`041fe000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`04d0c000 fffff880`04d17000   btath_bus btath_bus.sys Thu Jun 24 07:17:43 2010 (4C22F887)
fffff880`01dd5000 fffff880`01dff000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00e2e000 fffff880`00eee000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01a50000 fffff880`01a80000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00d11000 fffff880`00d6f000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0156e000 fffff880`015e0000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`031bc000 fffff880`031cc000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`01a80000 fffff880`01a8e000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`041cf000 fffff880`041ed000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`041c0000 fffff880`041cf000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01a3a000 fffff880`01a50000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0609f000 fffff880`060c1000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`01a8e000 fffff880`01a9a000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01aa5000 fffff880`01ab8000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`01a9a000 fffff880`01aa5000   dump_msahci dump_msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`030a6000 fffff880`0319a000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`10149000 fffff880`1018f000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`014fc000 fffff880`01510000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`014b0000 fffff880`014fc000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`017d2000 fffff880`017dc000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01a00000 fffff880`01a3a000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01ce2000 fffff880`01d2c000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`037f9000 fffff800`03842000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`1018f000 fffff880`101b3000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`101b3000 fffff880`101c4000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`01dcc000 fffff880`01dd5000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`101d5000 fffff880`101f3000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01049000 fffff880`013e3000   iaStor   iaStor.sys   Tue Apr 26 19:06:18 2011 (4DB7099A)
fffff880`0319a000 fffff880`031a6000   ICCWDT   ICCWDT.sys   Wed Aug 18 09:27:45 2010 (4C6B9981)
fffff880`031a6000 fffff880`031bc000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`03067000 fffff880`03076000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`00bc9000 fffff800`00bd3000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`04cc9000 fffff880`04d0c000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`017a6000 fffff880`017c1000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01981000 fffff880`019ac000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`060c1000 fffff880`060c6200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`00cae000 fffff880`00cfd000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`04cb8000 fffff880`04cc7000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`00c5c000 fffff880`00c76000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`00ca0000 fffff880`00cab000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`01800000 fffff880`0180b000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e09000 fffff880`00e13000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`01510000 fffff880`0156e000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`041b5000 fffff880`041c0000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01dba000 fffff880`01dcc000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0182e000 fffff880`01921000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`031e2000 fffff880`031ee000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`04c33000 fffff880`04c62000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`04d9c000 fffff880`04db1000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`0404f000 fffff880`0405e000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`01000000 fffff880`01045000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01921000 fffff880`01981000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`0180b000 fffff880`0181c000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`041a9000 fffff880`041b5000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03210000 fffff800`037f9000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01603000 fffff880`017a6000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01ab8000 fffff880`01ac1000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`04d83000 fffff880`04d9c000   nusb3hub nusb3hub.sys Fri Dec 10 04:50:35 2010 (4D01B19B)
fffff880`0f456000 fffff880`0f487000   nusb3xhc nusb3xhc.sys Fri Dec 10 04:50:35 2010 (4D01B19B)
fffff880`04db1000 fffff880`04dde000   nvhda64v nvhda64v.sys Thu Jul 07 17:21:14 2011 (4E15DCFA)
fffff880`0f4d2000 fffff880`10149000   nvlddmkm nvlddmkm.sys Sat Oct 15 07:07:55 2011 (4E99233B)
fffff880`04029000 fffff880`0404f000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00da2000 fffff880`00db7000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00d6f000 fffff880`00da2000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00dcc000 fffff880`00ddc000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`017c1000 fffff880`017d2000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`06062000 fffff880`0609f000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00cfd000 fffff880`00d11000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00ddc000 fffff880`00e00000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`04c62000 fffff880`04c7d000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04c7d000 fffff880`04c9e000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`04c9e000 fffff880`04cb8000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`04158000 fffff880`041a9000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`019e1000 fffff880`019ea000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`019ea000 fffff880`019f3000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`019f3000 fffff880`019fc000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01d80000 fffff880`01dba000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`03000000 fffff880`03067000   Rt64win7 Rt64win7.sys Wed Dec 29 11:44:36 2010 (4D1B1F24)
fffff880`040a8000 fffff880`040d7000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`101f3000 fffff880`101ff000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`0405e000 fffff880`0407b000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`01d78000 fffff880`01d80000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`04cc7000 fffff880`04cc8480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01ade000 fffff880`01ce2000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`0181c000 fffff880`01829000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`017dc000 fffff880`017fe000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`04144000 fffff880`04158000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`040ee000 fffff880`0410d000   tmactmon tmactmon.sys Tue Jul 12 12:12:34 2011 (4E1C2C22)
fffff880`0407b000 fffff880`040a8000   tmcomm   tmcomm.sys   Tue Jul 12 12:12:24 2011 (4E1C2C18)
fffff880`040d7000 fffff880`040ee000   tmevtmgr tmevtmgr.sys Tue Jul 12 12:12:20 2011 (4E1C2C14)
fffff880`04128000 fffff880`04144000   tmtdi    tmtdi.sys    Wed Jun 29 11:26:34 2011 (4E0AFDDA)
fffff880`03080000 fffff880`030a6000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`04d17000 fffff880`04d29000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`0f487000 fffff880`0f488f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`101c4000 fffff880`101d5000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04d29000 fffff880`04d83000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`0f400000 fffff880`0f456000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`00e13000 fffff880`00e20000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01ac8000 fffff880`01ad6000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`019ac000 fffff880`019d1000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00db7000 fffff880`00dcc000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01d2c000 fffff880`01d78000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`0410d000 fffff880`04128000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`019d1000 fffff880`019e1000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00eee000 fffff880`00f92000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f92000 fffff880`00fa1000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`01489000 fffff880`01492000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`0f4c7000 fffff880`0f4d0000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00e00000 fffff880`00e09000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
Elmer
Also, once in normal mode:
Download and run CPU-Z. Take screenshots**/snips of the Mainboard tab, Memory tab and all the slot #'s under the SPD tab.
Go to Post Reply, click on the Go Advanced button and attach the screenshots**/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
**If screenshots, please crop.
Please be sure to get all the slot numbers under the SPD tab.
(I don't think CPU-z will run in safe mode, regardless).
Many tnx for your help. Tomorrow morning the PC startet and got down again, but no bluescreen and with automatic restart on its own. Selection "Windows Help Programm" or "Start Windows normal".
After selecting "Win normal" the system runs since tomorrow morning and I did all you've recommended.
The CPU-Z-File is added and I will watch the scene.
Thank's so much, I hope it will getting better...
Martin
Uninstall Trend Micro ---> DONE
Replace with Microsoft Security Essentials ---> DONE
AsIO.sys Tue Aug 24 02:53:02 2010 ASUS Probe Utility - Uninstall ---> Didn't find this!! Where to look for? How to uninstall?
AsUpIO.sys Tue Aug 03 03:47:59 2010 ASUS hardware monitoring utility. Uninstall. --> the same
nusb3hub.sys Fri Dec 10 04:50:35 2010/nusb3xhc.sys Fri Dec 10 04:50:35 2010
update your USB 3.0 drivers. A June 2011 set are available Here. ------> DONE
Rt64win7.sys Wed Dec 29 11:44:36 2010 Realtek PCIe GBE Family Controller v7.049 Win7 and WinServer 2008 R2 Auto Installation Program (SID:1477671) -----------> DONE
Hi!
First: In my last thread I meant "this morning the PC startet.." and not "tomorrow".
Well, a few Hours later the next crash, after having done all instructed activities.
The PC was executing my FlightSimulater since about 1 hour, only in standby mode, not really active.
It never happened till now during a program was executing. Normally at once after booting or a few minutes later.
Do we have any chance to solve this? I think over to change back to WinXP 64 to avoid a coming nervous breakdown. Is there any experience with Win7 Professional compared to the Home Premium? Do you think this could make it easier?
But I trust in your excellent skills and go on trying...
Added the actual SystemInfoCode.
Martin
Elmer
STOP 0x00000109: CRITICAL_STRUCTURE_CORRUPTION
Usual causes:
Device driver, Breakpoint set with no debugger attached, Hardware (Memory in particular).
Your latest dump file lists Memory_Corruption as the probable cause which usually indicates out of date Drivers, incorrectly configured Memory Timings, mismatched Memory or Bad Memory.
AsIO.sys
AsUpIO.sys
The software related to these should be listed in Programs and Features. Most Like as Asus ***** Utility. If you can't find them, then you can disable drivers through the Device Manager or by renaming them.
Renaming drivers:
Create a System Restore Point. GoTo C:\Windows\System32\Drivers, locate the driver files and rename them from .sys to say, .bak.
This will break the driver and prevent it from running after the next reboot. Once you've established that having that driver in a none running state hasn't caused any adverse side effects, it will then be safe to delete it.
As a Priority:
Can you go into your bios and check that XMP is enabled for your ram?
XMP stands for extreme memory profile and is only supported if your memory says it fine to use. On the memory boards there's a spd chip. XMP makes it use the fastest setting that's allowed by the memory. It auto sets memory timings and memory voltages so you don't have to.
Using the Intel® Driver Update Utility (in Internet Explorer gives me the best results). Check for any updates for your motherboard (chipsets) etc..
Drivers still to update:
RTKVHD64.sys Tue Nov 02 11:25:59 2010 Realtek HD Audio R2.67
Bugcheck Analysis:
BugCheck 109, {a3a039d8998d950c, b3b7465eec0b7346, fffff880018f0210, 1}
Probably caused by : memory_corruption
Followup: memory_corruption
6: kd> !analyze -v
CRITICAL_STRUCTURE_CORRUPTION (109)
This bugcheck is generated when the kernel detects that critical kernel code or
data have been corrupted. There are generally three causes for a corruption:
1) A driver has inadvertently or deliberately modified critical kernel code
 or data. See http://www.microsoft.com/whdc/driver/kernel/64bitPatching.mspx
2) A developer attempted to set a normal kernel breakpoint using a kernel
 debugger that was not attached when the system was booted. Normal breakpoints,
 "bp", can only be set if the debugger is attached at boot time. Hardware
 breakpoints, "ba", can be set at any time.
3) A hardware corruption occurred, e.g. failing RAM holding kernel code or data.
Arguments:
Arg1: a3a039d8998d950c, Reserved
Arg2: b3b7465eec0b7346, Reserved
Arg3: fffff880018f0210, Failure type dependent information
Arg4: 0000000000000001, Type of corrupted region, can be
    0 : A generic data region
    1 : Modification of a function or .pdata
    2 : A processor IDT
    3 : A processor GDT
    4 : Type 1 process list corruption
    5 : Type 2 process list corruption
    6 : Debug routine modification
    7 : Critical MSR modification
Debugging Details:
BUGCHECK_STR:  0x109
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff8000327ec40
STACK_TEXT:
fffff880`0375b498 00000000`00000000 : 00000000`00000109 a3a039d8`998d950c b3b7465e`ec0b7346 fffff880`018f0210 : nt!KeBugCheckEx
STACK_COMMAND:  kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !ndis
    fffff880018f0297 - ndis!ndisWildCardStringMatch+87
    [ 75:65 ]
1 error : !ndis (fffff880018f0297)
MODULE_NAME: memory_corruption
IMAGE_NAME:  memory_corruption
FOLLOWUP_NAME:  memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MEMORY_CORRUPTOR:  ONE_BIT
FAILURE_BUCKET_ID:  X64_MEMORY_CORRUPTION_ONE_BIT
Drivers:
fffff880`04000000 fffff880`0403e000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00ee4000 fffff880`00f3b000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`01640000 fffff880`016c9000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`0f4a0000 fffff880`0f4b6000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`013a4000 fffff880`013af000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`031d2000 fffff880`031d8000   AsIO     AsIO.sys     Tue Aug 24 02:53:02 2010 (4C7325FE)
fffff880`031cb000 fffff880`031d2000   AsUpIO   AsUpIO.sys   Tue Aug 03 03:47:59 2010 (4C57835F)
fffff880`07bcc000 fffff880`07bd7000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00fd2000 fffff880`00fdb000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00e00000 fffff880`00e2a000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`01a33000 fffff880`01a3a000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`031ba000 fffff880`031cb000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`04536000 fffff880`04554000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`05e1c000 fffff880`05e83000   btath_a2dp btath_a2dp.sys Thu Sep 16 12:34:42 2010 (4C9200D2)
fffff880`04cce000 fffff880`04cd9000   btath_bus btath_bus.sys Thu Jun 24 07:17:43 2010 (4C22F887)
fffff880`05ee6000 fffff880`05ef5000   btath_flt btath_flt.sys Thu Jun 24 07:17:38 2010 (4C22F882)
fffff880`05e83000 fffff880`05ee6000   btath_hcrp btath_hcrp.sys Tue Jun 29 10:30:43 2010 (4C29BD43)
fffff880`05ef5000 fffff880`05f08000   btath_lwflt btath_lwflt.sys Mon Sep 13 09:26:54 2010 (4C8DE04E)
fffff880`01db5000 fffff880`01dd9e00   btath_rcp btath_rcp.sys Thu Jun 24 07:17:21 2010 (4C22F871)
fffff880`062f8000 fffff880`0633f000   btfilter btfilter.sys Fri Oct 22 07:40:47 2010 (4CC131EF)
fffff880`063ef000 fffff880`063ff000   BthEnum  BthEnum.sys  Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`04d45000 fffff880`04d5c000   bthmodem bthmodem.sys Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`04ddf000 fffff880`04dff000   bthpan   bthpan.sys   Tue Jul 14 01:07:00 2009 (4A5BCC24)
fffff880`06357000 fffff880`063e3000   bthport  bthport.sys  Thu Apr 28 04:55:07 2011 (4DB8E51B)
fffff880`0633f000 fffff880`06357000   BTHUSB   BTHUSB.sys   Thu Apr 28 04:54:56 2011 (4DB8E510)
fffff960`00660000 fffff960`00687000   cdd      cdd.dll      unavailable (00000000)
fffff880`01a00000 fffff880`01a2a000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00cd0000 fffff880`00d90000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`01d85000 fffff880`01db5000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00c72000 fffff880`00cd0000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01754000 fffff880`017c6000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`101e4000 fffff880`101f4000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`04424000 fffff880`0442d000   cpuz135_x64 cpuz135_x64.sys Wed Sep 21 09:23:41 2011 (4E799F0D)
fffff880`05f16000 fffff880`05f24000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0319c000 fffff880`031ba000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`0318d000 fffff880`0319c000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01d6f000 fffff880`01d85000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`04c00000 fffff880`04c22000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05f24000 fffff880`05f30000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`05f3b000 fffff880`05f4e000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`05f30000 fffff880`05f3b000   dump_msahci dump_msahci.sys Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`063e3000 fffff880`063ef000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`04042000 fffff880`04136000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04136000 fffff880`0417c000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`062b5000 fffff880`062eb000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`00dec000 fffff880`00e00000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`013af000 fffff880`013fb000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`017d7000 fffff880`017e1000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01d35000 fffff880`01d6f000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01c42000 fffff880`01c8c000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff800`037eb000 fffff800`03834000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`0417c000 fffff880`041a0000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`041a0000 fffff880`041b1000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`06293000 fffff880`062ac000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`062ac000 fffff880`062b4080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`06285000 fffff880`06293000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0446d000 fffff880`04536000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`01d2c000 fffff880`01d35000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`10189000 fffff880`101a7000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0100a000 fffff880`013a4000   iaStor   iaStor.sys   Tue Apr 26 19:06:18 2011 (4DB7099A)
fffff880`101c2000 fffff880`101ce000   ICCWDT   ICCWDT.sys   Wed Aug 18 09:27:45 2010 (4C6B9981)
fffff880`101ce000 fffff880`101e4000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`101a7000 fffff880`101b6000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff800`00ba2000 fffff800`00bac000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`04c8b000 fffff880`04cce000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`01739000 fffff880`01754000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`01860000 fffff880`0188b000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`04c22000 fffff880`04c27200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`05f92000 fffff880`05fa7000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`05f4e000 fffff880`05f71000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c0f000 fffff880`00c5e000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`05f08000 fffff880`05f16000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`04c7a000 fffff880`04c89000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`062eb000 fffff880`062f8000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00fb8000 fffff880`00fd2000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`0188b000 fffff880`018bc000   MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`07b33000 fffff880`07b43000   MpNWMon  MpNWMon.sys  Wed Apr 06 21:07:23 2011 (4D9CC7FB)
fffff880`04554000 fffff880`0456c000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0456c000 fffff880`04599000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`04599000 fffff880`045e7000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`04400000 fffff880`04424000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`00fdb000 fffff880`00fe6000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`017ea000 fffff880`017f5000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f44000 fffff880`00f4e000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`016db000 fffff880`01739000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`03182000 fffff880`0318d000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01d1a000 fffff880`01d2c000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`018cc000 fffff880`019bf000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`101f4000 fffff880`10200000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`03024000 fffff880`03053000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`04d60000 fffff880`04d75000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`030ca000 fffff880`030d9000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`015a3000 fffff880`015e8000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01800000 fffff880`01860000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`07b43000 fffff880`07b5b000   NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`01600000 fffff880`01611000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03176000 fffff880`03182000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`03202000 fffff800`037eb000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01400000 fffff880`015a3000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01a2a000 fffff880`01a33000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`041c2000 fffff880`041f3000   nusb3xhc nusb3xhc.sys Fri Dec 10 04:50:35 2010 (4D01B19B)
fffff880`04d75000 fffff880`04da2000   nvhda64v nvhda64v.sys Thu Jul 07 17:21:14 2011 (4E15DCFA)
fffff880`0f4bc000 fffff880`10133000   nvlddmkm nvlddmkm.sys Sat Oct 15 07:07:55 2011 (4E99233B)
fffff880`030a4000 fffff880`030ca000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00f8e000 fffff880`00fa3000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00f4e000 fffff880`00f81000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00fe6000 fffff880`00ff6000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`017c6000 fffff880`017d7000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`078ae000 fffff880`07954000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`04da2000 fffff880`04ddf000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c5e000 fffff880`00c72000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`03000000 fffff880`03024000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`03053000 fffff880`0306e000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0306e000 fffff880`0308f000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`04c60000 fffff880`04c7a000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03125000 fffff880`03176000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`019f4000 fffff880`019fd000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`018bc000 fffff880`018c5000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`017e1000 fffff880`017ea000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01ce0000 fffff880`01d1a000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`04c28000 fffff880`04c54000   rfcomm   rfcomm.sys   Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`05fa7000 fffff880`05fbf000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0f400000 fffff880`0f4a0000   Rt64win7 Rt64win7.sys Tue Sep 27 15:50:33 2011 (4E81E2B9)
fffff880`06000000 fffff880`06269800   RTKVHD64 RTKVHD64.sys Tue Nov 02 11:25:59 2010 (4CCFF547)
fffff880`07954000 fffff880`0795f000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`101b6000 fffff880`101c2000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`030d9000 fffff880`030f6000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`01cd8000 fffff880`01ce0000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`07a9b000 fffff880`07b33000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`07800000 fffff880`07869000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0795f000 fffff880`07990000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`04c89000 fffff880`04c8a480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01a3e000 fffff880`01c42000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`07990000 fffff880`079a2000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`01633000 fffff880`01640000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01611000 fffff880`01633000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`03111000 fffff880`03125000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00490000 fffff960`0049a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`031d8000 fffff880`031fe000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`04cd9000 fffff880`04ceb000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`041f3000 fffff880`041f4f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`041b1000 fffff880`041c2000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`04ceb000 fffff880`04d45000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`10133000 fffff880`10189000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`0626a000 fffff880`06285000   USBSTOR  USBSTOR.SYS  Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`00f81000 fffff880`00f8e000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`01ded000 fffff880`01dfb000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`019bf000 fffff880`019e4000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00fa3000 fffff880`00fb8000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00d90000 fffff880`00dec000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01c8c000 fffff880`01cd8000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`030f6000 fffff880`03111000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`019e4000 fffff880`019f4000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e31000 fffff880`00ed5000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ed5000 fffff880`00ee4000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`016c9000 fffff880`016d2000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00010000 fffff960`00324000   win32k   win32k.sys   unavailable (00000000)
fffff880`041f5000 fffff880`041fe000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f3b000 fffff880`00f44000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`05f71000 fffff880`05f92000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`07b5b000 fffff880`07bcc000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01db5000 fffff880`01dc3000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01dc3000 fffff880`01dcf000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01dcf000 fffff880`01dda000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`01dda000 fffff880`01ded000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`04d45000 fffff880`04d60000   nusb3hub.sys
    Checksum:  00000000
    ImageSize:  0001B000
Pffffffff!
Game over!
After receiving your post I restarted the PC and interrupted it to come to the BIOS.
I've looked there for the XMP, found it and it was to "Auto", not enabled. I did NOTHING ELSE !!!
Left the Boot-Menue with "exit without saving".
The PC startet - and a black screen came up, a line "Windows is loading files...:" and it starts a repair program.
Well, this program ran for hours and showed nothing. When I tried interrupt - it don't let me do that!
The only chance is to kill it completely.
I think I'm getting not too old with this OS - I think I have to re-install the whole system and first try to find a former installation point. And if I've done that - we can go on with solving blue screens....
I'm afraid I have to come back......
Martin
very, very sad
Elmer
#8
Sorry to here that.
There's a little program called Double Driver. It backs up all your installed drivers for a re-install. I usually only do the non MS drivers. Handy. Saves starting from scratch.
#9
Good morning, my helping friend!
I did it again! Restored my system from a "refreshing point" from 01/11/2012.
Tried to use all new informations I've got from this date. BIOS update, Chipset updates and all the good things.
The PC comes up this morning and it makes me "blue" again.
Here are the news of the day from Martin - would you try it again?
By the way: the switch in my Bios was on "Auto". Should it be so or should I change it to "X.M.P." ?
Edited 2 Hours after sending the post:
After starting the PC works now with my FSX Simulator without problems.
It must have to do anything with the starting process...
Greetings
Martin
Thanks
Elmer
#10
I'd turn it to XMP, it should take care of all the rams settings for you then.
Without looking further as yet, both were memory corruption which could be bad settings so definitely try XMP.
Elmer
#11
Update these again:
Nip to Intel, see if its anything to offer: Use the Intel® Driver Update Utility (in Internet Explorer gives me the best results). Update any and all drivers available.
Rename these again:
And that's about it driver wise.
#12
Good Morning, my helper!
It seems to be solved, but tomorrow morning........blue again.
But it was a little bit more different to the BSoDs I got before. During start at once blue, then started again itself and then running for hours. Could it be the coldness?
I have a extern HDD from Medion, it was connected during start. When I look on their website for a driver, it shows me only one for W98. Could this be the reason? Tomorrow morning I try to start without it, we will see.
Nevertheless, I send you my new datas, its another BCCode today: fc - never seen before....
Wish you an interest day.
Martin
Elmer
#13
Your FC stop basically says a driver is at fault.
Can you disable these two? They're still loading:
See how it goes. This is a process of elimination. :)
BTW, those are the only 'naughty' drivers I've spotted at the moment.
Only you can prove/dis-prove this. Start without it connected, start with it connected, see what happens. At a distance, my friend, you need to do some of the work!! :)
If you can give full specifications of your external, model number etc. We will help you,
Well, "good" morning - blue again :)
It's a little bit funny, because I thought it's done.
I have the driverscanner running every start-up-process, it shows me none not-actual driver, everything's ok.
I didn't find the described "AsIO.sys" or "AsUpIO.sys" to rename them - looked everywhere.
I had de-connected my extern drive before start-up.
Well - blue again............ What's up? Maybe you can show another way? Another OS? Another user :)
But: after this blue beginning the systems works without any problems the whole day, nearly 15-20 hours.
It's only the start-up..
Greetings
Martins
Elmer
#15
BugCheck 109, {a3a039d89c97c55a, b3b7465eef15a394, fffff880015291d0, 1}
[COLOR=#ff0000][B]Probably caused by : memory_corruption[/B][/COLOR]
Please run Memtest. Before running Memtest though, make sure all internal cable connections are good and that the ram etc. is seated properly.
Run Memtest86+ overnight, after your computer has been off for about an hour or two so it has a cold start. Ideally let it run for at least 7 passes / 6-8 hours. If errors appear before that you can stop that particular test.
Note!! Any time Memtest86+ reports errors, it can be either bad RAM or a bad Mobo slot. Test RAM sticks individually. When you find a good one then test it in all slots. Post back with the results.
Locations to manually look for the ASIO/ASupIO drivers: C:\Windows\System32\drivers, C:\Windows\System32, C:\Windows\SysWOW64, C:\Windows. Also search for Asus in Program Files and Program Files (x86).
Hi Elmer,
Memtest done - both RAM-Modules seem to be ok, no error occured.
And I searched my whole System - nowhere anything for these *.sys -Dats.
Greetings
Martin
PS: today start without BSoD....we wait for tomorrow :)
Elmer
#17
Just a thought. Can you see the systems hidden files and folders?
Open Folder Options (In an open window, on the Menu bar >> Tools >> Folder options... >> Select View tab)
(a) Select Show hidden files, folders, and drives.
(b) Uncheck the Hide protected operating system files box. Click on Yes to confirm.
(c) Click on Apply and then OK your way out.
Thanks for the idea - but I always operate with these options. There is nothing hidden.
I even ran through the device manager, on EVERY feature I made "Properties->Drivers->Driver Details" and looked whether there is anything like that.
It must be still away. But what matters, I can't find it....
That the status.
Today morning:
I started like everyday and had 1 short bluescreen - I decided to start Windows (follow the question) normal and it came up without problems. I looked in the folder "Minidump" and there was nothing with the date of today.
Since this time till now it worked.
Only every morning. I think I let the machine run an run and don't switch it off.....
Thanks for your support
Martin
#19
Hi again!
it's curious - every day in the morning the same "blue". But since nearly 3 days it came up at once in the starting phase, gets down again and boots without any other problems. There was another minidump today and due to the starting period I have another suggestion:Could it be one of the "RUN"-Programs in the "RunInfoLocal"-Folder?
Can I de-activate those programs without losing any functions?
Nice to hear from you again - I think it's getting better....
Martin
Elmer
#20
Hi Martin, Welcome back :(
:D :D :D
STOP 0x000000D1: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Usual causes:
Device driver
Your latest dump file lists tcpip.sys as the probable cause.
Along your lines of thinking, none of these need to run at Start Up. After disabling in MSConfig, see if the relevant programs have an option to stop them from starting with Windows.
SunJavaUpdateSched
Adobe ARM
DriverScanner
These two are still annoying the hell out of me!! Supposed Locations;
AsIO.sys C:\Windows\System32\drivers, possibly a sub-folder in Program Files
AsUpIO.sys C:\Windows\System32\drivers.
Can you do me a favour? Download a program called Everything. Do a search for those drivers using that, see if it finds them.
nusb3hub.sys Fri Apr 23 02:34:35 2010
nusb3xhc.sys Fri Apr 23 02:34:36 2010
Rt64win7.sys Tue Sep 27 15:50:33 2011 Realtek PCIe GBE Family Controller v7.050 If you're unsure about manually installing drivers then choose the Win7 and WinServer 2008 R2 Auto Installation Program (SID:1477671) option to download.
Bugcheck Analysis:
BugCheck D1, {24, 2, 1, fffffa80075c8c40}
Probably caused by : tcpip.sys ( tcpip!IppPacketizeDatagrams+3e6 )
Drivers:
