Annoying pretty random BSOD
Great start of the new year (happy new year all by the way :)). BSOD.
I've got a dump, see attachment. View attachment 010111-20124-01.dmp
Sounds worse, right? Millions of 'errors' in the dump..
Anyway, I hope this can be fixed :).
Thanks,
Dennis
Thanks for followaing the instructions on how to ask for BSOD help, now a gift for you, right?
Your crash was caused by the Daemon Tools driver - uninstall DT and its driver:
DuplexSecure - FAQ
You have Avira and PC Tools Firewall - if crashes persist (they will), uninstall both and replace with MSE:
www.microsoft.com/security_essentials/
Update or remove Starforce drivers:
sfhlp02.sys Wed Jun 14 10:58:06 2006
Software Protection. Update Remove Driver
Update or remove Microsoft Virtual Server 2005 R2 SP1:
VMNetSrv.sys Wed Jan 24 07:05:46 2007
Update:
RTKVHD64.sys Mon Sep 21 05:58:17 2009
Realtek Audio
Realtek
yk62x64.sys Mon Jun 15 12:49:34 2009
Marvell Yukon Ethernet Controller
Your memory timings look right 9-9-9-24 ddr667.
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\010111-20124-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e0f000 PsLoadedModuleList = 0xfffff800`0304ce50
Debug session time: Sat Jan  1 07:33:20.260 2011 (UTC - 5:00)
System Uptime: 0 days 1:32:34.040
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 7A, {fffff6fc40008bf0, ffffffffc0000185, 24511860, fffff8800117e93c}
Unable to load image \SystemRoot\System32\Drivers\sptd.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for sptd.sys
*** ERROR: Module load completed but symbols could not be loaded for sptd.sys
GetPointerFromAddress: unable to read from fffff800030b7220
Probably caused by : memory_corruption
Followup: memory_corruption
0: kd> !analyze -v
KERNEL_DATA_INPAGE_ERROR (7a)
The requested page of kernel data could not be read in.  Typically caused by
a bad block in the paging file or disk controller error. Also see
KERNEL_STACK_INPAGE_ERROR.
If the error status is 0xC000000E, 0xC000009C, 0xC000009D or 0xC0000185,
it means the disk subsystem has experienced a failure.
If the error status is 0xC000009A, then it means the request failed because
a filesystem failed to make forward progress.
Arguments:
Arg1: fffff6fc40008bf0, lock type that was held (value 1,2,3, or PTE address)
Arg2: ffffffffc0000185, error status (normally i/o status code)
Arg3: 0000000024511860, current process (virtual address for lock type 3, or PTE)
Arg4: fffff8800117e93c, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
Debugging Details:
ERROR_CODE: (NTSTATUS) 0xc0000185 - The I/O device reported an I/O error.
DISK_HARDWARE_ERROR: There was error with disk hardware
BUGCHECK_STR:  0x7a_c0000185
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
PROCESS_NAME:  System
CURRENT_IRQL:  0
TRAP_FRAME:  fffff88002fa84e0 -- (.trap 0xfffff88002fa84e0)
rax=fffff88001176500 rbx=0000000000000000 rcx=fffffa80048ba050
rdx=fffffa8004147e10 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8800117e93c rsp=fffff88002fa8678 rbp=fffffa8003b0f407
 r8=0000000000000007  r9=fffffa80048ba1a0 r10=0000000000000000
r11=fffff88002fa8620 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz ac po cy
ataport!ChannelQueryDeviceRelations:
fffff880`0117e93c ff              ???
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002ef4168 to fffff80002e7f740
STACK_TEXT:
fffff880`02fa81c8 fffff800`02ef4168 : 00000000`0000007a fffff6fc`40008bf0 ffffffff`c0000185 00000000`24511860 : nt!KeBugCheckEx
fffff880`02fa81d0 fffff800`02e7152b : fffffa80`03ae1af0 fffff880`02fa8340 fffff800`0300c440 fffff800`00000000 : nt! ?? ::FNODOBFM::`string'+0x34c0e
fffff880`02fa82b0 fffff800`02e9a5c4 : 00000000`00000000 00000000`00000008 ffffffff`ffffffff 00000000`0000002a : nt!MiIssueHardFault+0x28b
fffff880`02fa8380 fffff800`02e7d82e : 00000000`00000008 fffffa80`04710000 fffff880`02fa8500 00000000`0000000b : nt!MmAccessFault+0x11c4
fffff880`02fa84e0 fffff880`0117e93c : fffff880`0117c4ce fffffa80`04718000 fffff880`02fa8800 fffffa80`04147e10 : nt!KiPageFault+0x16e
fffff880`02fa8678 fffff880`0117c4ce : fffffa80`04718000 fffff880`02fa8800 fffffa80`04147e10 00000000`00000001 : ataport!ChannelQueryDeviceRelations
fffff880`02fa8680 fffff880`00ef4599 : fffff880`00f2b010 fffff880`02fa87c0 fffffa80`04710000 fffffa80`04320000 : ataport!IdePortDispatchPnp+0x22
fffff880`02fa86b0 fffff880`00f2b010 : fffff880`02fa87c0 fffffa80`04710000 fffffa80`04320000 fffffa80`03a1c0b8 : sptd+0x41599
fffff880`02fa86b8 fffff880`02fa87c0 : fffffa80`04710000 fffffa80`04320000 fffffa80`03a1c0b8 fffffa80`06c32000 : sptd+0x78010
fffff880`02fa86c0 fffffa80`04710000 : fffffa80`04320000 fffffa80`03a1c0b8 fffffa80`06c32000 fffffa80`03a1dc80 : 0xfffff880`02fa87c0
fffff880`02fa86c8 fffffa80`04320000 : fffffa80`03a1c0b8 fffffa80`06c32000 fffffa80`03a1dc80 fffffa80`03a2d048 : 0xfffffa80`04710000
fffff880`02fa86d0 fffffa80`03a1c0b8 : fffffa80`06c32000 fffffa80`03a1dc80 fffffa80`03a2d048 fffffa80`00000000 : 0xfffffa80`04320000
fffff880`02fa86d8 fffffa80`06c32000 : fffffa80`03a1dc80 fffffa80`03a2d048 fffffa80`00000000 fffffa80`03a1dcf0 : 0xfffffa80`03a1c0b8
fffff880`02fa86e0 fffffa80`03a1dc80 : fffffa80`03a2d048 fffffa80`00000000 fffffa80`03a1dcf0 00000000`00000090 : 0xfffffa80`06c32000
fffff880`02fa86e8 fffffa80`03a2d048 : fffffa80`00000000 fffffa80`03a1dcf0 00000000`00000090 fffffa80`039e9040 : 0xfffffa80`03a1dc80
fffff880`02fa86f0 fffffa80`00000000 : fffffa80`03a1dcf0 00000000`00000090 fffffa80`039e9040 00000000`00000000 : 0xfffffa80`03a2d048
fffff880`02fa86f8 fffffa80`03a1dcf0 : 00000000`00000090 fffffa80`039e9040 00000000`00000000 fffffa80`04320001 : 0xfffffa80`00000000
fffff880`02fa8700 00000000`00000090 : fffffa80`039e9040 00000000`00000000 fffffa80`04320001 fffffa80`03a1c0b8 : 0xfffffa80`03a1dcf0
fffff880`02fa8708 fffffa80`039e9040 : 00000000`00000000 fffffa80`04320001 fffffa80`03a1c0b8 fffffa80`00000090 : 0x90
fffff880`02fa8710 00000000`00000000 : fffffa80`04320001 fffffa80`03a1c0b8 fffffa80`00000090 fffffa80`039d4900 : 0xfffffa80`039e9040
STACK_COMMAND:  kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !ataport
    fffff8800117e000-fffff8800117e007  8 bytes - ataport!DeviceAtaPassThroughIoctl+1a0
	[ 85 4a 08 75 b3 83 7a 0c:00 00 00 00 00 00 00 00 ]
    fffff8800117e009-fffff8800117e010  8 bytes - ataport!DeviceAtaPassThroughIoctl+1a9 (+0x09)
	[ 74 ad 81 7a 0c e0 a5 01:00 00 00 00 00 00 00 00 ]
    fffff8800117e012-fffff8800117e03e  45 bytes - ataport!DeviceAtaPassThroughIoctl+1b2 (+0x09)
	[ 77 a4 3b f7 76 10 2b f7:00 00 00 00 00 00 00 00 ]
    fffff8800117e040-fffff8800117e046  7 bytes - ataport!DeviceAtaPassThroughIoctl+1e0 (+0x2e)
	[ 48 8d 4c 24 38 41 b8:00 00 00 18 00 00 00 ]
    fffff8800117e04b-fffff8800117e086  60 bytes - ataport!DeviceAtaPassThroughIoctl+1eb (+0x0b)
	[ 48 8b d3 e8 bd 4f ff ff:18 00 00 00 18 00 00 00 ]
    fffff8800117e088-fffff8800117e090  9 bytes - ataport!DeviceAtaPassThroughIoctl+228 (+0x3d)
	[ 49 8d 0c 04 41 3b 96 9c:00 00 00 18 00 00 00 18 ]
    fffff8800117e093-fffff8800117e09c  10 bytes - ataport!DeviceAtaPassThroughIoctl+233 (+0x0b)
	[ 0f 87 1f ff ff ff 41 b8:18 00 00 00 18 00 00 00 ]
    fffff8800117e09f-fffff8800117e0af  17 bytes - ataport!DeviceAtaPassThroughIoctl+23f (+0x0c)
	[ 8b c2 c1 ea 0c 41 23 c8:18 00 00 00 18 00 00 00 ]
    fffff8800117e0b1-fffff8800117e0bb  11 bytes - ataport!DeviceAtaPassThroughIoctl+251 (+0x12)
	[ c1 e9 0c 03 ca 41 3b 8e:00 00 18 00 00 00 18 00 ]
    fffff8800117e0bd-fffff8800117e0d7  27 bytes - ataport!DeviceAtaPassThroughIoctl+25d (+0x0c)
	[ 0f 87 f5 fe ff ff 33 c9:00 00 18 00 00 00 18 00 ]
    fffff8800117e0d9-fffff8800117e0dc  4 bytes - ataport!DeviceAtaPassThroughIoctl+279 (+0x1c)
	[ c0 e9 55 01:00 00 18 00 ]
    fffff8800117e0df-fffff8800117e0e3  5 bytes - ataport!DeviceAtaPassThroughIoctl+27f (+0x06)
	[ 4c 89 b8 80 00:18 00 00 00 18 ]
    fffff8800117e0e6-fffff8800117e0fe  25 bytes - ataport!DeviceAtaPassThroughIoctl+286 (+0x07)
	[ 4c 89 70 08 4c 89 70 10:00 18 00 00 00 18 00 00 ]
    fffff8800117e100-fffff8800117e137  56 bytes - ataport!DeviceAtaPassThroughIoctl+2a0 (+0x1a)
	[ eb 08 48 8b 47 18 49 8d:00 00 00 18 00 00 00 18 ]
    fffff8800117e13a-fffff8800117e13c  3 bytes - ataport!DeviceAtaPassThroughIoctl+2da (+0x3a)
	[ c0 e9 e4:00 18 00 ]
    fffff8800117e13f-fffff8800117e150  18 bytes - ataport!DeviceAtaPassThroughIoctl+2df (+0x05)
	[ 00 4c 8b 64 24 30 4c 8b:18 00 00 00 18 00 00 00 ]
    fffff8800117e153-fffff8800117e15b  9 bytes - ataport!DeviceAtaPassThroughIoctl+2f3 (+0x14)
	[ 41 3b c6 8b d8 0f 8c c6:18 00 00 00 18 00 00 00 ]
    fffff8800117e15e-fffff8800117e178  27 bytes - ataport!DeviceAtaPassThroughIoctl+2fe (+0x0b)
	[ 48 8b d6 49 8b cf e8 67:00 18 00 00 00 18 00 00 ]
    fffff8800117e17b-fffff8800117e184  10 bytes - ataport!DeviceAtaPassThroughIoctl+31b (+0x1d)
	[ 24 5f 3c 03 75 12 8a 86:18 00 00 00 18 00 00 00 ]
    fffff8800117e187-fffff8800117e18d  7 bytes - ataport!DeviceAtaPassThroughIoctl+327 (+0x0c)
	[ 88 47 2e 8a 86 ec 03:18 00 00 00 18 00 00 ]
    fffff8800117e18f-fffff8800117e197  9 bytes - ataport!DeviceAtaPassThroughIoctl+32f (+0x08)
	[ 00 88 47 28 48 8b 86 18:18 00 00 00 18 00 00 00 ]
    fffff8800117e19a-fffff8800117e1a3  10 bytes - ataport!DeviceAtaPassThroughIoctl+33a (+0x0b)
	[ 49 3b c6 74 1f 80 be f1:00 18 00 00 00 18 00 00 ]
    fffff8800117e1a5-fffff8800117e1a9  5 bytes - ataport!DeviceAtaPassThroughIoctl+345 (+0x0b)
	[ 10 72 16 48 8b:00 00 18 00 00 ]
    fffff8800117e1ab-fffff8800117e1b3  9 bytes - ataport!DeviceAtaPassThroughIoctl+34b (+0x06)
	[ 48 89 47 28 48 8b 86 18:18 00 00 00 18 00 00 00 ]
    fffff8800117e1b6-fffff8800117e1c7  18 bytes - ataport!DeviceAtaPassThroughIoctl+356 (+0x0b)
	[ 48 8b 48 08 48 89 4f 20:00 18 00 00 00 18 00 00 ]
    fffff8800117e1c9 - ataport!DeviceAtaPassThroughIoctl+369 (+0x13)
	[ 04:00 ]
    fffff8800117e1cb-fffff8800117e1fe  52 bytes - ataport!DeviceAtaPassThroughIoctl+36b (+0x02)
	[ 00 89 47 08 41 80 fd 01:18 00 00 00 18 00 00 00 ]
    fffff8800117e200-fffff8800117e205  6 bytes - ataport!DeviceAtaPassThroughIoctl+3a0 (+0x35)
	[ 48 8b d7 41 b8 18:00 00 00 18 00 00 ]
    fffff8800117e207 - ataport!DeviceAtaPassThroughIoctl+3a7 (+0x07)
	[ 00:18 ]
    fffff8800117e209-fffff8800117e241  57 bytes - ataport!DeviceAtaPassThroughIoctl+3a9 (+0x02)
	[ 48 8b cb e8 ff 4d ff ff:00 00 18 00 00 00 18 00 ]
    fffff8800117e243-fffff8800117e285  67 bytes - ataport!DeviceAtaPassThroughIoctl+3e3 (+0x3a)
	[ 00 49 3b ce 74 08 33 d2:18 00 00 00 18 00 00 00 ]
    fffff8800117e287-fffff8800117e293  13 bytes - ataport!IdeInitAtaPassThroughIrb+23 (+0x44)
	[ 00 48 8b fa 48 8b e9 45:18 00 00 00 18 00 00 00 ]
    fffff8800117e295-fffff8800117e298  4 bytes - ataport!IdeInitAtaPassThroughIrb+31 (+0x0e)
	[ 8a 81 58 04:00 00 18 00 ]
    fffff8800117e29b-fffff8800117e29f  5 bytes - ataport!IdeInitAtaPassThroughIrb+37 (+0x06)
	[ 41 88 80 ee 03:18 00 00 00 18 ]
    fffff8800117e2a2-fffff8800117e2a5  4 bytes - ataport!IdeInitAtaPassThroughIrb+3e (+0x07)
	[ 8a 81 59 04:00 18 00 00 ]
    fffff8800117e2a7-fffff8800117e2ac  6 bytes - ataport!IdeInitAtaPassThroughIrb+43 (+0x05)
	[ 00 41 88 80 ef 03:18 00 00 00 18 00 ]
    fffff8800117e2af-fffff8800117e2b7  9 bytes - ataport!IdeInitAtaPassThroughIrb+4b (+0x08)
	[ 8b 42 0c 41 89 80 fc 03:18 00 00 00 18 00 00 00 ]
    fffff8800117e2b9-fffff8800117e2c3  11 bytes - ataport!IdeInitAtaPassThroughIrb+55 (+0x0a)
	[ f6 42 02 02 74 08 41 83:00 00 18 00 00 00 18 00 ]
    fffff8800117e2c6-fffff8800117e2d3  14 bytes - ataport!IdeInitAtaPassThroughIrb+62 (+0x0d)
	[ 40 f6 42 02 04 74 09 41:00 18 00 00 00 18 00 00 ]
    fffff8800117e2d5-fffff8800117e2e0  12 bytes - ataport!IdeInitAtaPassThroughIrb+71 (+0x0f)
	[ 07 f6 42 02 08 74 08 41:00 00 18 00 00 00 18 00 ]
    fffff8800117e2e3-fffff8800117e2ef  13 bytes - ataport!IdeInitAtaPassThroughIrb+7f (+0x0e)
	[ 08 f6 42 02 20 75 08 41:18 00 00 00 18 00 00 00 ]
    fffff8800117e2f1-fffff8800117e2fc  12 bytes - ataport!IdeInitAtaPassThroughIrb+8d (+0x0e)
	[ 10 f6 42 02 01 74 0a 41:00 00 18 00 00 00 18 00 ]
    fffff8800117e2ff-fffff8800117e307  9 bytes - ataport!IdeInitAtaPassThroughIrb+9b (+0x0e)
	[ 01 eb 08 41 83 a0 f8 03:18 00 00 00 18 00 00 00 ]
    fffff8800117e309-fffff8800117e314  12 bytes - ataport!IdeInitAtaPassThroughIrb+a5 (+0x0a)
	[ fe f6 42 02 10 74 08 41:00 00 18 00 00 00 16 00 ]
    fffff8800117e317-fffff8800117e31c  6 bytes - ataport!IdeInitAtaPassThroughIrb+b3 (+0x0e)
	[ 02 41 83 88 f8 03:0a 00 00 00 05 00 ]
    fffff8800117e31f-fffff8800117e321  3 bytes - ataport!IdeInitAtaPassThroughIrb+bb (+0x08)
	[ 20 ba 12:01 00 00 ]
    fffff8800117e325-fffff8800117e329  5 bytes - ataport!IdeInitAtaPassThroughIrb+c1 (+0x06)
	[ 41 c6 80 f1 03:00 00 00 00 00 ]
    fffff8800117e32c-fffff8800117e340  21 bytes - ataport!IdeInitAtaPassThroughIrb+c8 (+0x07)
	[ 12 8d 4a f2 41 b8 49 64:00 00 00 00 00 00 00 00 ]
    fffff8800117e343-fffff8800117e349  7 bytes - ataport!IdeInitAtaPassThroughIrb+df (+0x17)
	[ 48 3b c6 75 0a be 9a:00 00 00 00 00 00 00 ]
    fffff8800117e34b-fffff8800117e34f  5 bytes - ataport!IdeInitAtaPassThroughIrb+e7 (+0x08)
	[ 00 c0 e9 b1 00:29 00 00 00 28 ]
WARNING: !chkimg output was truncated to 50 lines. Invoke !chkimg without '-lo [num_lines]' to view  entire output.
3767 errors : !ataport (fffff8800117e000-fffff8800117efff)
MODULE_NAME: memory_corruption
IMAGE_NAME:  memory_corruption
FOLLOWUP_NAME:  memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MEMORY_CORRUPTOR:  LARGE_4096
FAILURE_BUCKET_ID:  X64_MEMORY_CORRUPTION_LARGE_4096
Drivers:
fffff880`043ab000 fffff880`043e9000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`050e6000 fffff880`0512b000   a94l3weo a94l3weo.SYS Tue Jul 14 17:12:55 2009 (4A5CF4D7)
fffff880`00d90000 fffff880`00de7000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`05271000 fffff880`05289000   adfs     adfs.SYS     Thu Jun 26 16:52:37 2008 (48640195)
fffff880`02a24000 fffff880`02aae000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`051c1000 fffff880`051d7000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`041c5000 fffff880`041da000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`01195000 fffff880`011a0000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`01157000 fffff880`01160000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01160000 fffff880`0118a000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`0573b000 fffff880`0575b000   AtihdW76 AtihdW76.sys Thu Jul 15 08:46:49 2010 (4C3F0339)
fffff880`0461d000 fffff880`04dd8000   atikmdag atikmdag.sys Wed Aug 25 21:47:22 2010 (4C75C7AA)
fffff880`04000000 fffff880`0404a000   atikmpag atikmpag.sys Wed Aug 25 21:20:56 2010 (4C75C178)
fffff880`017da000 fffff880`017e2000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff960`00840000 fffff960`008a1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`0567d000 fffff880`0569a000   avgntflt avgntflt.sys Thu Feb 11 10:12:02 2010 (4B741E42)
fffff880`0417d000 fffff880`0419f000   avipbb   avipbb.sys   Mon Feb 22 05:08:50 2010 (4B8257B2)
fffff880`015f1000 fffff880`015f8000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`0416c000 fffff880`0417d000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0535d000 fffff880`0537b000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00780000 fffff960`007a7000   cdd      cdd.dll      unavailable (00000000)
fffff880`0161e000 fffff880`01648000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00ca1000 fffff880`00d61000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`017aa000 fffff880`017da000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c43000 fffff880`00ca1000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01411000 fffff880`01484000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`05149000 fffff880`05159000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`05289000 fffff880`05292000   cpuz133_x64 cpuz133_x64.sys Tue May 11 05:58:57 2010 (4BE92A61)
fffff880`057ba000 fffff880`057c8000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0414e000 fffff880`0416c000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`0413f000 fffff880`0414e000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01794000 fffff880`017aa000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05798000 fffff880`057ba000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05e00000 fffff880`05e0c000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`057c8000 fffff880`057db000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`05ff5000 fffff880`06000000   dump_msahci dump_msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`057db000 fffff880`057e7000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0424d000 fffff880`04341000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`04341000 fffff880`04387000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`011ec000 fffff880`01200000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`011a0000 fffff880`011ec000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01495000 fffff880`0149f000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0175a000 fffff880`01794000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`02b3a000 fffff880`02b84000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`04200000 fffff880`0420d000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`033eb000 fffff800`03434000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04387000 fffff880`043ab000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`05600000 fffff880`05619000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`05619000 fffff880`05621080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`057e7000 fffff880`057f5000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`05295000 fffff880`0535d000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01751000 fffff880`0175a000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`050aa000 fffff880`050c8000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`050c8000 fffff880`050d7000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00b99000 fffff800`00ba3000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`05178000 fffff880`051bb000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013b8000 fffff880`013d2000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`013d2000 fffff880`013fd000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`051bb000 fffff880`051c0200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`041da000 fffff880`041ef000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05159000 fffff880`05160000   lmimirr  lmimirr.sys  Tue Apr 10 18:32:45 2007 (461C108D)
fffff880`053c0000 fffff880`053d3000   LMIRfsDriver LMIRfsDriver.sys Mon Jul 14 12:26:56 2008 (487B7E50)
fffff880`0565a000 fffff880`0567d000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`05160000 fffff880`05167000   ManyCam_x64 ManyCam_x64.sys unavailable (00000000)
fffff880`00c22000 fffff880`00c2f000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`040f5000 fffff880`0413ea00   mfehidk  mfehidk.sys  Fri Jul 31 17:59:58 2009 (4A73695E)
fffff880`0564c000 fffff880`0565a000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`050d7000 fffff880`050e6000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05624000 fffff880`05631000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`01133000 fffff880`0114d000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0537b000 fffff880`05393000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05393000 fffff880`053c0000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`05200000 fffff880`0524e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0524e000 fffff880`05271000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`0118a000 fffff880`01195000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02b1e000 fffff880`02b29000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fe2000 fffff880`00fec000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01000000 fffff880`0105e000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03e5d000 fffff880`03e68000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0173f000 fffff880`01751000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0149f000 fffff880`01591000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`05000000 fffff880`0500c000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`040e2000 fffff880`040f5000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`0500c000 fffff880`0503b000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`05726000 fffff880`0573b000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03f0f000 fffff880`03f1e000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03e9b000 fffff880`03ee0000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01591000 fffff880`015f1000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`02b29000 fffff880`02b3a000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03e51000 fffff880`03e5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e0f000 fffff800`033eb000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01215000 fffff880`013b8000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`043f1000 fffff880`043f9000   NTIDrvr  NTIDrvr.sys  Tue Mar 24 23:09:39 2009 (49C9A073)
fffff880`01648000 fffff880`01651000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`03ee9000 fffff880`03f0f000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`01096000 fffff880`010ab000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`01063000 fffff880`01096000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0111c000 fffff880`01123000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`01123000 fffff880`01133000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02baf000 fffff880`02bff000   pctgntdi64 pctgntdi64.sys Wed Jan 06 19:59:33 2010 (4B4531F5)
fffff880`04600000 fffff880`04617000   pctNdis64 pctNdis64.sys Wed Jan 06 19:21:38 2010 (4B452912)
fffff880`09788000 fffff880`097a3000   pctNdis_PacketFilter64 pctNdis-PacketFilter64.sys Mon Jan 11 17:05:05 2010 (4B4BA091)
fffff880`097a3000 fffff880`097ce000   pctplfw64 pctplfw64.sys Tue Jan 12 16:28:44 2010 (4B4CE98C)
fffff880`02a00000 fffff880`02a24000   PctWfpFilter64 PctWfpFilter64.sys Wed Jan 06 20:07:09 2010 (4B4533BD)
fffff880`01484000 fffff880`01495000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`0901e000 fffff880`090c4000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0575b000 fffff880`05798000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c2f000 fffff880`00c43000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`051d7000 fffff880`051fb000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04218000 fffff880`04233000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04dd8000 fffff880`04df9000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04233000 fffff880`0424d000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03e00000 fffff880`03e51000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`02b03000 fffff880`02b0c000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02b0c000 fffff880`02b15000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02b15000 fffff880`02b1e000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01705000 fffff880`0173f000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`03fd6000 fffff880`03fee000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05e0d000 fffff880`05ff4580   RTKVHD64 RTKVHD64.sys Mon Sep 21 05:58:17 2009 (4AB74E39)
fffff880`00d61000 fffff880`00d90000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`090c4000 fffff880`090cf000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`016ee000 fffff880`01705000   sfdrv01  sfdrv01.sys  Tue Feb 03 10:37:48 2009 (498864CC)
fffff880`016d6000 fffff880`016ee000   sfdrv01a sfdrv01a.sys Tue Feb 03 10:40:11 2009 (4988655B)
fffff880`016ce000 fffff880`016d6000   sfhlp02  sfhlp02.sys  Wed Jun 14 10:58:06 2006 (449023FE)
fffff880`016af000 fffff880`016ce000   sfvfs02  sfvfs02.sys  Thu Feb 08 12:47:18 2007 (45CB6226)
fffff880`016a8000 fffff880`016af000   speedfan speedfan.sys Sun Sep 24 09:26:48 2006 (45168798)
fffff880`016a0000 fffff880`016a8000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`00eb3000 fffff880`00fd9000   sptd     sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
fffff880`096f2000 fffff880`09788000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`0910e000 fffff880`09175000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`090cf000 fffff880`090fc000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`05167000 fffff880`05177d00   STREAM   STREAM.SYS   Mon Jul 13 20:06:18 2009 (4A5BCBFA)
fffff880`0503b000 fffff880`0503c480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`03c00000 fffff880`03dfd000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`090fc000 fffff880`0910e000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02ba2000 fffff880`02baf000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02b84000 fffff880`02ba2000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03fc2000 fffff880`03fd6000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00460000 fffff960`0046a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`0419f000 fffff880`041c5000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`043e9000 fffff880`043f1000   UBHelper UBHelper.sys Mon Apr 27 04:48:19 2009 (49F57153)
fffff880`040d0000 fffff880`040e2000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`05622000 fffff880`05623f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`05099000 fffff880`050aa000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`056cc000 fffff880`05726000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`0420d000 fffff880`04218000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`05043000 fffff880`05099000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`05631000 fffff880`0564c000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`03f92000 fffff880`03fc1f00   VBoxDrv  VBoxDrv.sys  Fri Oct 08 09:52:29 2010 (4CAF221D)
fffff880`040ae000 fffff880`040cfb80   VBoxNetAdp VBoxNetAdp.sys Fri Oct 08 09:52:34 2010 (4CAF2222)
fffff880`03e68000 fffff880`03e8e7c0   VBoxNetFlt VBoxNetFlt.sys Fri Oct 08 09:52:29 2010 (4CAF221D)
fffff880`03f86000 fffff880`03f918c0   VBoxUSBMon VBoxUSBMon.sys Fri Oct 08 09:52:34 2010 (4CAF2222)
fffff880`00fec000 fffff880`00ff9000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01400000 fffff880`0140e000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02ace000 fffff880`02af3000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`03f39000 fffff880`03f86000   vmm      vmm.sys      Fri May 15 08:28:12 2009 (4A0D5FDC)
fffff880`05134000 fffff880`05149000   VMNetSrv VMNetSrv.sys Wed Jan 24 07:05:46 2007 (45B74B9A)
fffff880`010ab000 fffff880`010c0000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`010c0000 fffff880`0111c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01654000 fffff880`016a0000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03f1e000 fffff880`03f39000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02af3000 fffff880`02b03000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e00000 fffff880`00ea4000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ea4000 fffff880`00eb3000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03ee0000 fffff880`03ee9000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a0000   win32k   win32k.sys   unavailable (00000000)
fffff880`0512b000 fffff880`05134000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fd9000 fffff880`00fe2000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`0569a000 fffff880`056bb000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`097ce000 fffff880`097ff000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
fffff880`0404a000 fffff880`040ae000   yk62x64  yk62x64.sys  Mon Jun 15 12:49:34 2009 (4A367B9E)
Unloaded modules:
fffff880`09600000 fffff880`09671000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`017e2000 fffff880`017f0000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`017f0000 fffff880`017fc000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01600000 fffff880`0160b000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`0160b000 fffff880`0161e000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0114d000 fffff880`01157000   sfsync02.sys
    Checksum:  00000000
    ImageSize:  0000A000
Thanks for your fast response :D.
I'm not really that experienced in those stuff - and I need to know how to remove drivers. I'm not sure if Daemon Tools it's uninstaller did removed the drivers.
About MSE - I need a good working and live-in-action scanner, with detects virusses (and stuff) as they land on my computer without scanning every file manually (I got some odd virus in C:/ a year ago, luckily didn't open it). Including a good firewall where I can allow certain ports' connections - as I transfer files using Peer to Peer). Does this work with MSE?
I'm still messing around to figure out what I need to update my drivers (The last three things). Seems like W7's driver update isn't working properly so I better don't use that (It downgrades my graphic card's drivers enormously).
Thanks for your support,
Dennis
Starforce thing tells me that everything is up-to-date.
sdtd.sys removal is done.
Daemon tools is uninstalled now.
Littttle big question; You told be that Daemon Tools was the causer, why do I need to update/change other things and virus stuff actually?
Thanks for your help again,
Dennis
If crashes reoccur, do not try to update the starforce drivers - REMOVE them.
#7
Ok, thanks, until now no crash occured :).
#8
Great, let's hope. : )
If your system runs without crashes for a couple of weeks, feel free then to replace MSE with any Antivirus of your preference - JUST DON"T INSTALL MORE THAN 1 BRAND.
Same way, if your system runs without crashes for a couple of weeks, feel free to install the LATEST VERSION of Daemon Tools.
#9
I've read something more about Daemon Tools and heard a lot of complaints about BSOD caused by that - They recommend using MagicISO instead. I'll do so, that will cause no problem for me. First I'll wait some time to make sure it's running right.
PC Tools Firewall is just a firewall, Avira Antivir is just a virus scanner without firewall - means it's separated.. That's fine, right?
#10
If you don't need to emulate copy-protected disks, yes you can do without Daemon Tools. The alternatives for ISO emulation are MagicISO, PowerISO, UltraISO.
Nothing wrong with DT, but have it uninstalled for as long as you're troubleshooting bsods.
Do not use Avira and PCtools alongside in one system.
#11
Nice timing of reply :p.
I just need to read .iso files, and get everything out what is inside. I don't really need an extra drive for everything and nothing.
I also had massive problems with ZoneAlarm firewall, with I tried before PCTools' one - ZoneAlarm's caused BSOD's once it was running. Then it was very clear that ZoneAlarm was the causer of the earlier ones.
Again thanks for help :).
#12
You are welcome.
