Windows 7 Applications do not fit the screen
pHeoz
Hello,
When I try to play a game in windowed mode, I always get the same problem. Basically, the bottom of the game is being hidden by the taskbar. It does not fit well on the screen. There are no buttons 'maximize' on top-right of the window, just a minimize and exit.
I want the bottom of the game to be on the upper side of the task bar. How to do that ?
Thanks.
Edit: forgot to post the screenshots. Here it is: ImageShack -
I would have to say it's because you've resized your taskbar.
Does your game have an "always on top" settings anywhere?
Hmm.. this is strange. Can you test the game on another computer with a higher resolution or hook up your computer to another monitor?
I didn't find the page you asked me to fill, but here are my computer's specifications:
Link Removed - Invalid URL
I don't think this will help. It's probably a problem in some settings.
Note that I didn't have this problem on my previous version of windows (Windows XP).
The issue does not come from the game I showed on the first screenshot, since I have the same thing happening with every game.
